    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-28-2015, 10:57 AM   #12631
madweazl's Avatar
Originally Posted by K_King View Post
The arms should have 3 on one side and 2 on the other. The rear bulkhead will have 2 mounting locations on the rear for a swaybar the original didn't. If you see 2 holes on the chassis that are next to each other in the middle then you have the new one as well. Many of these parts came out when the truck was released so it's been a running change for awhile. The only newer part are the arms.
Thanks for the info. On another note, let Campos know he still sucks the next time you see 'em.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 10-28-2015, 12:43 PM   #12632
Regional Moderator
RobsRacin's Avatar
Ok for anyone who bought the 3 gear conversion, have any step by step? I tried but got play in the top shaft and its a little bindy. Am I just a blithering idiot??
RobsRacin is offline   Reply With Quote
Old 10-28-2015, 12:57 PM   #12633
Regional Moderator
RobsRacin's Avatar
I figured it out, just need to step away for a second and clear my mind haha
Old 10-28-2015, 01:29 PM   #12634
madweazl's Avatar
Tower replied today and the mistake was mine, not theirs. Sucks paying more for the previous version of the buggy; sucks to be me. Guess somebody will get a good deal.
RadioPost
Old 10-28-2015, 02:38 PM   #12635
Trader Rating: 18 (100%+)
I told you I'd give you $100 for it right now. Just send pp info.
Chris Brown is offline   Reply With Quote
Old 10-28-2015, 02:44 PM   #12636
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
With my latest, old part numbered kit, I only had to purchase new arms and springs to get it up to the new spec. I don't use the new inside hole on the arm myself and the springs at 20 bucks a pop would still be cheaper than selling the kit and losing money. Just a thought.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 10-28-2015, 02:58 PM   #12637
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
I looked at my kit. I was given the original kit but Kyosho America packed the springs arms and wings as the updated parts. The rest was part of the original kit already.
So basically
Rear Arms
Gold rear springs
Step 3.0 wing
The rest is a running change.
K_King is offline   Reply With Quote
Old 10-28-2015, 03:21 PM   #12638
madweazl's Avatar
I dont mind the springs, arms, and the wing; those are things I'd probably change/break anyways I have a set of BB Avid springs I can play with (along with many others I've collected over the years) to get an idea of where I need to be. Like I said, it was really a matter of principle for me.
Is this the original or updated chassis?
RadioPost
Old 10-28-2015, 07:35 PM   #12639
Regional Moderator
RobsRacin's Avatar
Well finished building my stock car. Dont remember my other RB6 taking 7 hours to build but this one did. Probably do to milling the chassis off the bat as well as 3 gear and also drilled my own holes to relocate the battery posts.
Old 10-28-2015, 07:36 PM   #12640
K_King's Avatar
That's the updated chassis.
Old 10-28-2015, 08:09 PM   #12641
madweazl's Avatar
Cool, I'll just grab the updated arms then.
RadioPost
Old 10-29-2015, 05:51 AM   #12642
Regional Moderator
RobsRacin's Avatar
Also maybe its just my reedy motor, but anybody have clearance issues for the soldering tabs running a 3 gear. I grinded the waterfall down alot so the motor could slide all the way forward but its still tight
Old 10-29-2015, 06:57 AM   #12643
rider313's Avatar
Trader Rating: 94 (100%+)
My 24K was tight but its vertical tabs left enough room to get it wired without any grinding.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 10-29-2015, 07:38 AM   #12644
madweazl's Avatar
The Sonics are a pain when it comes to wiring in this car.
RadioPost
Old 10-29-2015, 11:43 AM   #12645
symmetricon's Avatar
Trader Rating: 27 (100%+)
I did the same exact thing...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
JAE, mupchu
