    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-08-2012, 10:00 PM   #1246
Trader Rating: 18 (100%+)
Fresh paint for Mdowney
Ryan Sagisi
Schelleracing.com | Raceaka.com | R1wurks.com
B5M | B44.2 | T4.2 | Top Photon
SAGISI is offline   Reply With Quote
Old 10-08-2012, 11:18 PM   #1247
Carbides or tungsten carbides?
Bluehills315 is offline   Reply With Quote
Old 10-09-2012, 12:10 AM   #1248
Z00M's Avatar
Trader Rating: 15 (100%+)
I run ceramic thrust and diff balls in all my kyosho diffs (2wd and 4wd) and they work great. No slipping/barking and loosen up well once run in. If you overtighten ceramic filled diffs they will dent the rings and the diff will not last.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 10-09-2012, 12:33 AM   #1249
CanyonCarverR1's Avatar
Originally Posted by Cpt.America View Post
Wiring is done, paint is tomorrow and Tuesday, testing is Wednesday, Northwest Gold Cup is Fri-Sun. Can't wait.
Are those Lunsford ball studs?
CanyonCarverR1 is offline   Reply With Quote
Old 10-09-2012, 03:15 AM   #1250
well the RB6 is here, well over there.
wouldn't ya know it came in at no better time than when i happen to be puttn' The Wildfire in it's stage of completion a part is not in its bag nor its box.
so the buggy will be fitted this A.M.
p.s. good read on the diff balls.
Eric Summers is offline   Reply With Quote
Old 10-09-2012, 04:31 AM   #1251
What thrust balls are you using as I have only ever used kit
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 10-09-2012, 08:20 AM   #1252
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
ballstuds? Yes.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-09-2012, 08:26 AM   #1253
ballstuds? Yes.
V nice
Old 10-09-2012, 09:33 AM   #1254
John.C's Avatar
Trader Rating: 36 (100%+)
Thanks for the feedback guys. I'm learning a lot about offroad 2wd buggies from this thread! I've modified my list by adding and removing items based on the recommendations. So far, the build/setup is going very smoothly. However, I've observed/ran into a few things that didn't go exactly as planned and/or wasn't clear in the manual/setup sheet.
1) Some filing/cutting was required on the underside of the "Front Upper Plate" to ensure it sat flush on top of the "Front Bulkhead". I'm not exactly sure why this piece was molded this way. I'm going to assume that I made the right call in removing this piece.
2) I want to confirm that 'Block position: In' = wider front track width and 'Block position: Out' = narrower front track width.
3) There is play/slop between the suspension bushings and the composite suspension holders. I hope that the alum suspension holders and the delrin bushings takes care of this issue.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 10-09-2012, 09:44 AM   #1255
t8rtot's Avatar
Trader Rating: 14 (94%+)
1) correct
2)i'm looking into that
3)that is interesting as i don't have any slop anywhere. i'd check to make sure they are the correct bushing and if they are and it is an unreasonable amount of play, i would look into using this http://www.speedtechhobbies.com/inde...roduct_id=2126
Sfida
t8rtot is offline   Reply With Quote
Old 10-09-2012, 09:45 AM   #1256
Super Moderator
Yes! Sorry that wasn't mentioned, I think a lot of us Kyosho builders are just used that huge piece of flashing being there on all the kits. I just shave my off with an ex-acto blade. You made the right decision
Im not sure what this is referring to, sorry. Ill have to look at the manual and get back to ya. (unless somebody chimes in quicker that knows off hand!)
(edit: what page is this in the manual? I don't see anything about changing front track. I wasn't aware you could, besides shimming/rigging the front axles.)
When using the plastic suspension holders, make sure you are running the metal bushings. When running the metal hangers, run the plastic or derlin bushings. I don't recall seeing much play when running the metal hangers, and the white plastic/derlin bushings.
- RCSpecialties -
Old 10-09-2012, 10:00 AM   #1257
t8rtot's Avatar
its on the setup sheet
Sfida
Old 10-09-2012, 10:02 AM   #1258
fullsyzz's Avatar
Trader Rating: 102 (100%+)
The way I interpret #2 is opposite of how it is described above. To me, if the caster blocks are mounted in (caster insert holes toward the chassis) I get a narrower track width.
fullsyzz is offline   Reply With Quote
Old 10-09-2012, 10:02 AM   #1259
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Hey guys, had a quick question for you, i was looking through some of the rb6 stuff and it looks like the step 2.0 rear wing is really popular. Then i check the price out and its about $14 for one wing...im a AE guy and usually use the JC wings and get 2 for about $8-10. Are the kyosho wings molded out of a thicker lexan, like the LMR wings? Also, just curious, did any of you used to have a B4.1 that could compare the rb6 to? I just saw my first one run this past weekend and it looked awesome. Thanks!
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-09-2012, 10:05 AM   #1260
fullsyzz's Avatar
I think the only way you can get away with changing the front track width by flipping the caster inserts is if you use the "0" insert. If you flip the 2 or 4 insert so the hole is on the outside I think it will screw up the caster, but I'm not sure.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Gayosaka
