    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 10-12-2015, 10:32 AM   #12526
Originally Posted by thecman26 View Post
Black grease on the pucks, but really never had to even replace my pucks after an entire season. A few have had issues but none around here!
Anyone else had experience with the pucks? I used them on my TLR 22SCT with a 13.5 and the pucks wore out super fast. Thinking of trying them on my RB6 with a boosted 17.5. Black grease on the orange puck works?
MrLean is offline   Reply With Quote
Old 10-12-2015, 02:15 PM   #12527
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I use black grease on the stock components and they have lasted a lot longer then if they were not covered in it. I don't see why it wouldn't work with pucks.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 10-12-2015, 02:27 PM   #12528
oPAULo's Avatar
I've been putting just a touch of silicone diff grease on them. Pucks are so cheap and easy to replace I don't bother giving them much service. My setup was all used when I got it and I know I have over 200 runs on them. Only replaced them twice. The end at the axle still looks great. Outdrives still look great. I'm certain the pucks reduce wear in other components. Takes the metal to metal shock out of it.
Kiddo is running 17.5 with his RB6 now and I'm thinking of trying the all aluminum setup. He's not super smooth just yet and still puts it in the pipe some times so I may just stick with the steel for now.
oPAULo is offline   Reply With Quote
Old 10-12-2015, 04:52 PM   #12529
eper's Avatar
Trader Rating: 14 (100%+)
Originally Posted by oPAULo View Post
Did you space the top of the shocks back the same amount to keep them in the same position?
actually i had a set of red aluminum exotek shock mounts from someone that i wont run because i dont run aluminum on aluminum. so i cut them with a cut off wheel and used the nut.they are wider and i liked the red for this buggy. also i hve these black plastic shock mounts from the rb5 that have a built in 2mm spacer that i like to use. with this the shock i at a straight up and down angle
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 10-12-2015, 11:02 PM   #12530
likea45's Avatar
I recently went with the entire MIP kit for the RB6 including the dif and I've been pretty impressed with it thus far. Black greased the snot out of the pucks and reapply it after every race day. I've talked to a few guys that do this maintenance regularly and have driven over a year on the same pucks still with virtually no wear to the out drives. Seems good to me.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 10-13-2015, 07:39 AM   #12531
yodace's Avatar
R/C Tech Charter Subscriber
Where is a good place to get a lcg/lay Down tranny case
yodace is offline   Reply With Quote
Old 10-13-2015, 10:03 AM   #12532
Regional Moderator
RobsRacin's Avatar
I dont know of anybody making them. I believe it was a 1 off prototype from kyosho for the worlds
RobsRacin is offline   Reply With Quote
Old 10-13-2015, 12:12 PM   #12533
https://www.facebook.com/redworkshopracing?fref=ts
RaceToTheBottom is offline   Reply With Quote
Old 10-13-2015, 03:20 PM   #12534
oPAULo's Avatar
Anyone ever tried zero antisquat?
Old 10-13-2015, 03:40 PM   #12535
Regional Moderator
RobsRacin's Avatar
Originally Posted by Troy Mckune View Post
This is the battery brace and chassis stiffener developed with Tanner Day and Thomas Tran. It allows you to mill down your chassis to run a shorty sideways without making the chassis to weak.
This is a shorter version on the lay down tranny RB6.
Is this in reference to the new 2015 chassis? I have the older chassis and was told it was okay to mill down the sides of it and it will be ok. I'm thinking I want to do the same when I get the new car built but know I will need a stiffener at that point.
Old 10-13-2015, 04:00 PM   #12536
Trader Rating: 16 (100%+)
Originally Posted by eper View Post
if anyone is interested i build my 17.5 car last week and i mounted the rear shock tower using 4, 2mm spacers to move the tower forward so that i could change the inner ballstud height. (losi allen driven ballstuds) this mod makes it so u do not need t disassemble the entire rear of the car to make a change. i also used 4, 2mm spacers to space the wing mount back so that its in its original position because i would be farther forward with the tower spaced forward. it held up fine and did not change the handling of the car much if at all. i dont find that i move that ballstud location often but i do like to be able to have that option open tome and anything that makes the car easier to tune is a upgrade in my opinion. hope everyone is loving their rb 6 as much as myself and good luck to all the red samurai drvers out there
I am interested in seeing this? can you post pics?
rocdog is offline   Reply With Quote
Old 10-13-2015, 04:25 PM   #12537
LiL CeeZ's Avatar
Trader Rating: 15 (100%+)
Pucks aren't made for 13.5 motors, specifically states 17.5
Team Associated B6D
LiL CeeZ is offline   Reply With Quote
Old 10-13-2015, 04:36 PM   #12538
oPAULo's Avatar
17.5 aluminum pucks system are for 17.5 motors.
Shiny pucks system are steel and for everything else.
Old 10-13-2015, 05:26 PM   #12539
Yep, I'm just talking about the orange part...obv need diff dogbones for mod motors. I got like 2 race days before the orange wore out of my brand new system, I ended up tearing up the out drive because I didn't notice the puck worn out already. It went metal on metal
Old 10-13-2015, 08:47 PM   #12540
I run full puck system on my RB6 17.5 stock setup and ran them on my previous SCR-SP with 10.5 mod and boosted setup. The RB6 works great and with little maintenance last a very long time before having to change out the orange pucks. On my SC truck with 10.5 mod motor, I was replacing orange pucks every 3rd race at best. You have to keep an eye on them at all times. No matter what you run them on. Soon as you see a bit of play between the orange puck and outdrive cup, you need to replace pucks. If not it will take very little for the small screws holding the pucks on to start wearing the aluminum outdrive cups.
MIP just released a new shinny puck system. I just got them a few days ago. Not sure if they have even advertised it yet. But it is made for mod setups. It uses their metal shinny setup but uses a softer metal round puck that rides in the drive cups. Suppose to last 10 times longer than the orange pucks do. I installed into my new SC6 truck with 10.5 mod motor. Looks awesome.
Like everyone had mentioned, you need to run grease on the pucks. Even these new metal ones.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 Yesterday 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
