    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-04-2015, 06:16 PM   #12511
Regional Moderator
RobsRacin's Avatar
Finally decided to take my RB6 full circle to run sideways battery. I just cut the side pods previously to try it out and liked it so I decided to commit to it.
All milled out
Slight gap where I went a little too far cutting off the side pods
Battery fits perfect and sits right against where the side pods got cut, no movement side to side at all
Strap fits good now and doesnt have to be bent
RobsRacin is offline   Reply With Quote
Old 10-04-2015, 10:19 PM   #12512
Trader Rating: 82 (100%+)
I did the same with the side pods and put a small strip of gorilla tape on the grinder chassis and side pod. Makes it look so much better and doesn't stratch the battery!
"Tinkering with Toy Cars that go around in circles"
OCRC | Club R/C | Mike's Gulf Coast | Kyosho RB6 ZX6 MP9E
Kuya_Kimo is offline   Reply With Quote
Old 10-05-2015, 06:07 AM   #12513
Trader Rating: 21 (100%+)
Originally Posted by timannnn6 View Post
Pics?
I can try to take some pics, though they won't really show much.
Originally Posted by eper View Post
didit change any handling? did you compensate for the wing position
Not sure if it really did much to the handling. I had made a couple of other changes this weekend, but I will say, I ran my fastest laps this weekend on our current layout. I didn't do anything with the wing position, could be something to play with however. I race on a fairly tight indoor track. Tire choice is M4 Primes.
joncmack is online now   Reply With Quote
Old 10-05-2015, 10:11 AM   #12514
has anyone tried to mount the rear shocks in the forward position with a mid motor setup? How will it affect the handling of the car?
mnevoso is offline   Reply With Quote
Old 10-05-2015, 10:29 AM   #12515
I am wanting to try the sideways pack in my buggy. I am currently running the lightweight chassis and am concerned with milling the side of the chassis. Has anyone done this with the lightweight chassis? If so is there anything to look out for
Brandon Smith
fanfor18 is offline   Reply With Quote
Old 10-05-2015, 10:58 AM   #12516
After moving the rear shock tower forward 3mm, I was considering giving this a try. May be something I mess with this week.
Old 10-05-2015, 11:44 AM   #12517
Gayosaka's Avatar
It's not possible, the slippers fouls the rear shock.
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Old 10-05-2015, 02:37 PM   #12518
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Only thing I can think of is there could be too much chassis flex on the LW chassis. If you got a battery strap that could double as an upper brace for the chassis it might work. That was my worry with that chassis and why I opted to get a standard chassis that was mostly milled out for the sideways battery mod.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 10-06-2015, 02:59 AM   #12519
eper's Avatar
Trader Rating: 14 (100%+)
okthanks for responding
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is online now   Reply With Quote
Old 10-09-2015, 11:41 AM   #12520
Default Suspension hangers
New to the rb6, I see the narrow and wide hangers listed on 1st page are discontinued and see some exotek and RDRP versions. Quick question, the RDRP version says you can adjust rear toe from 2, 4 & 6 and the exotek is listed as narrow and wide. Are these the same adjustments just worded differently? Thanks.
nordfink is offline   Reply With Quote
Old 10-09-2015, 01:07 PM   #12521
Michael#81's Avatar
Trader Rating: 252 (100%+)
I would go with the Kyosho Aluminum Hangers. They offer a ton of tuning possibilities over any of the aftermarket versions.
http://www.amainhobbies.com/rc-cars-...umw707/p264132
http://www.amainhobbies.com/rc-cars-...umw705/p264129
Michael Malott
Michael#81 is offline   Reply With Quote
Old 10-12-2015, 06:22 AM   #12522
Airlmeier4422's Avatar
Hey all. First time buyer of Kyosho and the RB6. Purchased one from EBay yesterday and was seeing if I need to order anything i.e. Spares, upgrades and anything else. Here are a few pictures. I am already planing on ordering the exotek front bulk head.
Airlmeier4422 is offline   Reply With Quote
Old 10-12-2015, 07:48 AM   #12523
eper's Avatar
if anyone is interested i build my 17.5 car last week and i mounted the rear shock tower using 4, 2mm spacers to move the tower forward so that i could change the inner ballstud height. (losi allen driven ballstuds) this mod makes it so u do not need t disassemble the entire rear of the car to make a change. i also used 4, 2mm spacers to space the wing mount back so that its in its original position because i would be farther forward with the tower spaced forward. it held up fine and did not change the handling of the car much if at all. i dont find that i move that ballstud location often but i do like to be able to have that option open tome and anything that makes the car easier to tune is a upgrade in my opinion. hope everyone is loving their rb 6 as much as myself and good luck to all the red samurai drvers out there
new milford ct,
Old 10-12-2015, 07:58 AM   #12524
oPAULo's Avatar
Did you space the top of the shocks back the same amount to keep them in the same position?
oPAULo is offline   Reply With Quote
Old 10-12-2015, 09:44 AM   #12525
Troy Mckune's Avatar
Trader Rating: 38 (100%+)
Default RB6 Cross Brace
This is the battery brace and chassis stiffener developed with Tanner Day and Thomas Tran. It allows you to mill down your chassis to run a shorty sideways without making the chassis to weak.
This is a shorter version on the lay down tranny RB6.
Mckune Design / facebook page / RC America / XRAY / Lunsford Racing
Mckune Design is a custom manufacturer of CNC machined carbon fiber, G10, & composite laminate parts for RC, Aerospace, medical, and high tech industries.
Troy Mckune is online now   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
eper
