    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-01-2015, 03:36 AM   #12481
eper's Avatar
Trader Rating: 14 (100%+)
Originally Posted by J@y$0nB View Post
RB6 ALUMINUM REAR UPPER BULKHEAD Ver.2 for MID MOTOR (RED)
http://tresrey.com/yaiba/products/YRG093_eng.html
do u kjnow if the ballstud height is the same as the stock. may be an option im interested in. its a nice looking peice. also u know the weight difference?
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 10-01-2015, 04:01 AM   #12482
Super Moderator
Originally Posted by scoobyrs25 View Post
I'm considering building a 3 gear trans. I'm wondering which side to put the motor on. Which motor position aids rear traction?
The motor side doesn't matter as far as rear traction goes. To change rear traction (and give up a bit of on power traction/steering) the motor rotation relative to the car needs to be changed, that's what a 4 gear trans does differently compared to a 3 gear.
Dave H is offline   Reply With Quote
Old 10-01-2015, 08:21 AM   #12483
I suppose you are correct. So, why bother building the trans the hard way? Looking at the case halves side by side, it seems like you can simply build it rear motor, flip it and install. Change motor wires, done. Why all of the custom work?
scoobyrs25 is offline   Reply With Quote
Old 10-01-2015, 08:30 AM   #12484
oPAULo's Avatar
You would need a motor that had enough adjustment to retard the timing so it would be advanced timing when running backwards. I'm still not sure it's that simple but maybe.
oPAULo is offline   Reply With Quote
Old 10-01-2015, 09:22 AM   #12485
Super Moderator
Yes, reworking the 3 gear to keep the pinion and spur on the right side avoids needing to deal with a reversed motor setup. Difficulty of a reverse motor depends mostly on the speed control used, but it would be nice to avoid the issue if possible/practical.
Old 10-01-2015, 09:59 AM   #12486
Gayosaka's Avatar
And most of the timing boost + turbo is not available on a reverse software setup.
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Old 10-01-2015, 10:40 AM   #12487
Or an ESC that will allow you to reverse motor direction in the programming...
Fast Little Car is offline   Reply With Quote
Old 10-01-2015, 11:13 AM   #12488
So, as long as I can twist the endbell of the motor equally in both directions, swapping two wires on the motor solves it.
That said, which motor direction is advantageous for rear traction?
Old 10-01-2015, 11:23 AM   #12489
oPAULo's Avatar
Pinion and spur on the drivers side, or left side. Motor torques the chassis to the rear.
If your fighting for rear traction really bad then try rear motor setup.
Old 10-01-2015, 11:35 AM   #12490
RCMamba's Avatar
What's a good base setup on a loose dirt track?
RCMamba is offline   Reply With Quote
Old 10-01-2015, 12:05 PM   #12491
Gayosaka's Avatar
The motor has to spin the same way as rear wheels, as in a 4-gear setup.
Old 10-01-2015, 03:08 PM   #12492
Super Moderator
Only switch wires is it's a unsensored setup. With sensored systems the A-A, B-B, C-C wiring must be maintained.
Old 10-01-2015, 09:20 PM   #12493
Well that settles that. Ever since doing the Zack Rogers setup, I really have had no issues of any kind. I used to have tons of rear grip issues before. I would like to see it actually wheelie. My ZX6 has been so fun, I haven't spent much time with the RB.
Old 10-01-2015, 10:23 PM   #12494
likea45's Avatar
Has anyone used the MIP 17.5 pucks dif and out drives in the RB6? If so was it worth it? Did you notice smoother acceleration and braking as it claims?
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 10-02-2015, 05:52 AM   #12495
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Seeing some very interesting pics popping up from the Worlds,
Lay down tranny, new chassis, rear hubs, and a few other tidbits.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22938 Today 01:29 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
