    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 09-26-2015, 10:24 PM   #12466
LiL CeeZ's Avatar
Trader Rating: 15 (100%+)
Won my main tonight finally lol. I get so damn nervous..
Can't wait to get this 3 gear tranny installed soon. Also if you guys haven't seen this yet you might be interested..
https://www.facebook.com/chris.bush....2%3A%22O%22%7D
and this..
http://shop.cbscustomrc.com/
I'm ordering a set tonight and putting together my tranny with them and the pucks. Should be accelerating like the big boys very soon
Team Associated B6D
LiL CeeZ is offline   Reply With Quote
Old 09-28-2015, 07:43 AM   #12467
Originally Posted by RobsRacin View Post
Finally installed the brass rear front hanger on the car and love it. Car had the forward bite I needed and now I can dial some more steering into it. Very happy with
Did u have it mid motor with the battery inline or something different ? thanks
Franzchise is offline   Reply With Quote
Old 09-29-2015, 10:03 AM   #12468
Trader Rating: 21 (100%+)
So has anyone come up with a trick to access the rear inner ballstuds when in MM configuration for easy adjustments without having to take the entire rear end off?
I already switched to TLR ballstuds (rather than paying so much for the Lunsford Ti ones) with a 2mm hex thinking I could reach with a hex wrench....but no luck. I am considering attempting to drill a hole down through the shock tower on either side to be able to slide a wrench down it, but I'm not sure there's enough material on the shock tower to avoid weakening it too much.
joncmack is offline   Reply With Quote
Old 09-29-2015, 04:41 PM   #12469
eper's Avatar
Trader Rating: 14 (100%+)
im also interested to see what ideas people have for getting to those little bastards. they are a real pain. i should at least sit here and look at the car and see if i can come up w an idea
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 09-29-2015, 04:44 PM   #12470
eper's Avatar
maybe if we shim the tower 1mm farther forward the allen drive ballstuds would workout
new milford ct,
Old 09-29-2015, 05:20 PM   #12471
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
To get to the ball studs in MM on the rear bulkhead you could try to open up the holes in the ball cups of you have the lunsfords or put a bigger hole in the stock ball cups and try a 2mm ball end driver. It might be doable to get to them easier that way. Most often I haven't had a need to change the settings on that ball stud at all.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 09-29-2015, 06:26 PM   #12472
eper's Avatar
its doable but its a pain in the ass. i havent had to change that much either but i would like to try a change there and i just know its not easy. also if you run turf its a change u will need to make. i ran my dirt car on turf once but because of this obsticle i opted for 2 cars. one for each surface
new milford ct,
Old 09-29-2015, 08:44 PM   #12473
J@y$0nB's Avatar
Default Yaiba
RB6 ALUMINUM REAR UPPER BULKHEAD Ver.2 for MID MOTOR (RED)
http://tresrey.com/yaiba/products/YRG093_eng.html
Kyosho Ultima RB6 & RB6.6 Car Thread-yrg093_01s.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-yrg093_08.jpg
J@y$0nB is offline   Reply With Quote
Old 09-29-2015, 09:38 PM   #12474
Originally Posted by Teufel Racing View Post
If your car setup and driving are on point with everyone else and you're still getting beat the. There's at least one other thing those guys are probably doing that you may not be. And that's a pretty touchy subject with most so I'll leave it there.
Not to stir a subject you believe is a touchy one and wondering what it may be I have to ask. Would you be talking about the current trend of folks racing in 17.5 to ramp up their charging amps to nearly 40? It is seriously getting to the point where racing in mod is becoming the more attractive option for both sanity's sake and the pocket book.
Fasttrak is offline   Reply With Quote
Old 09-29-2015, 10:59 PM   #12475
Yes that would be the subject,
There's a lot of opinions and what not out there on it. While not a huge fan of it, I have done the 30-35a charging and there is something to it, is it good for the barreries or general safety? It could depend on who is asked. The newest gens of LiPo batteries can easily take much higher charge rates than those of just a few years ago. Seems like every new gen of battery is better in that regard. So much so, that a few companies are bringing out HV rated batteries. If you are trying to be at the very top of stock racing, it's one thing you'll likely have to consider doing, as any little advantage could be the difference. Most likely won't go that far, but there are enough that probably do simply because they have heard or seen it done. Kind of monkey see monkey do.
I can't say for sure it's bad for the life span of the batteries to use charge at high amp rates, opinions say yes and no. I have t seen much degrading of the batteries that I was doing that on, but depending on the relative grade of the LiPo used it might not be a big issue or it could be.
Safety wise, there's always an issue when charging at any amp rate. Things happen. At high rates I'd probably be a little more concerned that things are right before hand to the best of my abilities. Won't stop bad things from happening, but might give some piece of mind. Caution should always be used.
I think the more important part is the discharge side, and then keeping the pack warm when recharging as that could help,lower the ir of the pack to give an advantage.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Old 09-29-2015, 11:22 PM   #12476
I appreciate the honest comments, was fairly certain this is what you were referring too but wanted to be sure. Only having returned to the hobby a couple months ago the very first day back to the track it was one of the bits of advice offered to me by one of the racers. Having tons of experience with lipos in helicopters and planes I am pretty comfortable with my practices of charging\discharging but would never put that high of a charge rate through my packs. If I ever get smooth enough with the buggy I need more speed, I might consider it though
Old 09-30-2015, 12:40 AM   #12477
It's all good,
If you're fairly well versed from the heli side of LiPos, you'd probably be ok. Most new LiPos out now can handle a 10-15a charge rate from what I've seen. So charging at a 2c rate should be doable without too much trouble if you'd like to do that. Dirt oval,guys have been doing the high charge rates for a while and they seem to have something figured out. I saw a vid from right after the on road Nats where they took the same car, same driver, same track, and only charged the charging amps (1c, 5-6a, and a 40a rate) and found some interesting results.
If unsure, don't do it, and if your fairly comfortable with the thought, use caution and keep an eye on your stuff
J.Mikoliczyk
ZX6 - RB6 - MP9e
Old 09-30-2015, 05:54 AM   #12478
Perfect.....now where do I get it in the USA?
Old 09-30-2015, 06:06 PM   #12479
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
It's all good,
Not to hijack the thread into conversations about batteries but I have been charging at 30A for quite a few months now. I have been testing this using my iCharger Duo308 and I always balance charge. Not balancing seems to cause the most trouble. My batteries don't get hot, they get slightly warm. I have tested somewhat lower rates like 20 and 25 amp and I haven't noticed much difference. I need to do more testing.
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 09-30-2015, 07:58 PM   #12480
I'm considering building a 3 gear trans. I'm wondering which side to put the motor on. Which motor position aids rear traction?
scoobyrs25 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Headling
