    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 10-08-2012, 02:44 PM   #1231
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by racer x 1 View Post
I do believe i just got the last rb6 speedtech has!!!! its the sign of a good day lol
You are in for a treat of a build, my friend! Bags and parts a bit mixed here and there, but if you've built any standard kit, it's no problem. Fit and finish is absolutely top shelf.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-08-2012, 02:49 PM   #1232
t8rtot's Avatar
Trader Rating: 14 (94%+)
spot on
I've owned several different brands before and nothing equals what i just pulled out out that well packaged box.
i'm still jones'n just looking at this thing on the table. its incredible.
Sfida
t8rtot is offline   Reply With Quote
Old 10-08-2012, 04:21 PM   #1233
Trader Rating: 138 (100%+)
Originally Posted by t8rtot View Post
spot on
Tomorrow cannot come soon enough. A first full day of testing setup changes and finally breaking in my week old tires with 4 runs on them. Gonna be loving life.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, B64D (Temporary 4 wheel) YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-08-2012, 05:02 PM   #1234
Trader Rating: 1069 (100%+)
Originally Posted by Rfury View Post
I broke a shock shaft once. It was a VERY hard hit. Ripped off the entire left rear suspension on my SC-R. It can be done but you have to do something really stupid to do it.
As I was building my 6 I was like if you break something on this car its totally your fault or the guy that hit you's fault. Still have some wiring to clean up and setup to do, but its built!
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 10-08-2012, 05:36 PM   #1235
gelshocker's Avatar
Originally Posted by Cpt.America View Post
I have yet to see a single kyosho buggy ever bend or need a shock shaft replacement... and don't get ceramic diff balls, you should run carbides in a kyosho diff. Id run ceramics in the thrust though.
I think John C. meant suspension shafts that go in the arms.
The battery posts are different to rb5.
The strc alum front suspension holder (and front hinge pin holder) are for rb5. Probably compatible, if you want to build a rb5 front.
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 10-08-2012, 05:47 PM   #1236
silvalis's Avatar
Trader Rating: 29 (100%+)
Originally Posted by John.C View Post
Kyosho Hopups
- Alum Battery Post Set
- Alum Rear Hub Carrier Set (0.5 degrees)
- Vented Slipper Disk Set
- Alum Wide Rear Outer Susp Holder
- Alum Wide Rear Inner Susp Holder
- 'Type B' Middle Suspension Arm Set
Kyosho Spares
- Front Susp Arms
- Rear Susp Arms
- Front Hub Carrier Set
- Front Knuckle Set
- Front Shock Stay
- Rear Shock Stay
- Crank Arm Set
- Front/Rear Inner Susp Shafts (44mm)
- Front Outer Susp Shaft (25mm)
3rd party Hopups/Hardware
- Blue shims/spacers (various sizes)
- Blue lock nuts (various sizes)
- Ceramic diff balls
- Lunsford 1 1/8" Ti Turnbuckles
- STRC Alum Front Bulkhead
1) If you buy the metal suspension holders, buy the white delrin suspension shaft bushings. Don't use the metal ones. The black plastic ones work ok but wear quicker.
2) Don't buy ceramic diff balls like cpt america said above. If you some some spare diff stuff, buy the bfast rb5/rt5 kits as they're much better. I like the ones with the carbide diff balls and ceramic thrust balls.
3) Shock towers/arms/front carriers are nice to have, but I wouldn't buy multiple sets. They're pretty tough.
4) Buy a couple of sets of rear hubs. These are what broke on my RB5/RT5/ZX5 when I mucked up. Someone said that the new ones are supposed to be beefier though, so maybe they won't break (I haven't actually looked). If you're going alu I guess that's fine.
5) I was thinking that a few of the ball studs were a bit short when I assembled it, since I was putting spacers in. The bump steer spacers/studs come to mind.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 10-08-2012, 05:53 PM   #1237
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
+1 in the bfast!
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 10-08-2012, 06:17 PM   #1238
CanyonCarverR1's Avatar
.Why not ceramic diff balls?
CanyonCarverR1 is offline   Reply With Quote
Old 10-08-2012, 06:31 PM   #1239
cnelson3's Avatar
Trader Rating: 65 (100%+)
they are so hard they don't really bite into the diff rings enough. on the up side, when your diff lets out the "honk" all you need is new rings. Ceramic diff balls wont even have the slightest wear.
cnelson3 is offline   Reply With Quote
Old 10-08-2012, 06:32 PM   #1240
silvalis's Avatar
They don't really work well - Have to bolt it down too hard to stop slip.
I'll let Cpt America explain further - he seems to have best knowledge re: ceramic diff balls in the kyosho balldiff.
Old 10-08-2012, 06:35 PM   #1241
racer x 1's Avatar
Trader Rating: 27 (100%+)
LoL im pretty sure i know what im in for, this is my 5 kyosho buggy.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 10-08-2012, 06:38 PM   #1242
RodneyB's Avatar
Did you think that when you saw the steering rack? The rest of the car holds up well but it is not yet as sturdy as the RB5. I am sure it will be eventually.
Kyosho America; Peak Racing; Grandview Hobbies; CRCRC
CRCRC club administrator
Kyosho RB6, Kyosho ZX6, Kyosho SC6, Kyosho MP9e TKI
RodneyB is offline   Reply With Quote
Old 10-08-2012, 07:51 PM   #1243
Few guys asked me to post pictures of my build.
I will be moving the servo wire into the plastic tunnel when I decide which servo I like better (shorty or full size) for weight distribution.
I'll also shorten up the transponder wire so it's not bunched up under the mount.
Jason.Dias is offline   Reply With Quote
Old 10-08-2012, 08:21 PM   #1244
BISBEE 248's Avatar
Hey guys thought I would share.
Did something alittle different with the setup of my RB6 electronics,I wanted to be able to switch back and forth between shorty and full lipo with out switching brackets and I will be trying low profile servo soon too,so here is my RB6 in support of breast cancer..
Uploaded with ImageShack.us
Brent Bisbee #248 AKA:Captain Red cup racing
Speedtechrc.com: The only way to shop
TLRacing.com / ProlineRacing.com / Airtronics.net / Miponline.com / Rcinsider.com / Bartolone Motors / Home of the "Bisbee no tell motel"-on wheels..
BISBEE 248 is offline   Reply With Quote
Old 10-08-2012, 09:17 PM   #1245
Super Moderator
Some diffs work well with ceramic diff balls, and other diffs don't work well at all. For example, the B4 works great with ceramics, as with the schumachers. The kyosho is one of the buggies where the ceramic diff balls don't work.
They don't work well because they don't generate enough grip to keep from slipping (ceramics are SO smooth, they are actually slippery). Even with perfectly roughed up / sanded rings, unless the diff is OVERLY tight, the diff will bark/slip. What you end up with is either a diff that slips and barks and eventually ruins itself, or a diff that is so tight, the car's rotation suffers. Ceramics literally harm the car's ability to handle and get around the track quickly.
If you go with quality b-fast carbides, and make sure you break the diff in properly and NEVER let it slip, you will have a diff that you can run a little looser, helping the car rotate properly, but one that will also grab like a mofo, popping wheelies down the track.
Why the B4's diff works well and doesn't slip with ceramics, but the kyosho's diff doesn't, I'm not sure.... there is something in it's engineering that keeps it from being ideal. Trust me, run carbides in the main gear, and ceramics in the thrust.... you will have a diff that is tough, doesn't slip, that you can loose enough to get the car to rotate however much you want it to. A properly built in carbide kyosho diff will literally out-last / out-maintain an AE diff with ceramics.
-Cpt.
- RCSpecialties -
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Yesterday 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
