    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 09-14-2015, 06:08 PM   #12421
toast.'s Avatar
Trader Rating: 14 (100%+)
Went through more setups on PetitRC and dont see the 2 - seems like the popular setup is -1 for front and back - thanks.
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SCT410, SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 09-14-2015, 11:26 PM   #12422
Trader Rating: 82 (100%+)
Originally Posted by toast. View Post
I have two mid motor setup RB6 that I am learning to setup.
Is there a 'general' camber setting that I should start with. I've been looking at setup sheets and they seem to range from -2 up to 2.
I usually run on a small clay track (Tony's Hobbies) or OCRC.
Thanks in advance.
Camber on the RB6 is 99% -1 front and back for clay. Look at kevin King or Jared Tebo setups (OCRC or SDRC) from 2014 as a lot of that is with stock chassis & inline battery.
"Tinkering with Toy Cars that go around in circles"
OCRC | Club R/C | Mike's Gulf Coast | Kyosho RB6 ZX6 MP9E
Kuya_Kimo is offline   Reply With Quote
Old 09-15-2015, 04:58 AM   #12423
Whats the best esc for MM, last winter season i ran a tekin RS in 17.5 class on med sized carpet this year i'm running mod and wanted something with a fan is the RSX too much?
BiLL77 is offline   Reply With Quote
Old 09-15-2015, 02:12 PM   #12424
I blew up my Hobbywing v3.1 running mod last week so I picked up a Team Powers Radon Version 2. Throttle response is as smooth as the Hobbywing, and the brakes are even smoother. I run a Tekin in my RT6 and it's not as smooth as the Hobbywing or the Team Powers
Fast Little Car is offline   Reply With Quote
Old 09-15-2015, 02:57 PM   #12425
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
That a subjective question, one of which I'm sure there'll be many, many answers to.
Couple things to consider. Price and size (as the MM layout can be a little on the tight side for the elec. component placement). If price isn't really an issue, the. Size of the ESC could be the thing you'll need to focus on more of. If either of those aren't a big issue for you, the. It's about what you like the name of, feel of, or which has features you want in the ESC. I'd say most of the current top end ESC's will be more than up to the task to get the job done.
Any of the newest:
Orion
Reedy
LRP
Hobby wing
Tekin
Any of those will be more than up to par to do the job.
Personally I like the Oirion for the dual sensor ports the most. Makes ESC placement a bit easier knowing you can use either port to route the sensor wire to. im not a fan of having to possibly remove the ESC just to change a sensor wire. But that's just me.
All of the above mentioned ESC's have things I like or don't like either in price or features, so it just comes down to which will fit your needs the most I guess.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 09-15-2015, 04:08 PM   #12426
Size matters not the price last year i ran the Tekin Rs between the motor and battery with the pack inline, I'd like to keep the same basic setup the car was really hooked up on that track. I wonder if the gen 1 Rs would do the job with an 8.5 motor.
Old 09-15-2015, 05:11 PM   #12427
Size wise,
The Tekin Rs series is probably your best bet for its small size and it's pretty light too. The gen1 Rs should run a 8.5 with little heat issues, unless you're boosting it to the moon. Only down side for the Rs line is the lack of a fan for the ESC, but you probably shouldn't have an overheating issue if you keep,the ESC settings more on the conservative side and don't get all crazy with it.
I only mentioned the price because it does matter to some and could be something that affects the end users decision of which to buy.
Outside of the Rs series from Tekin, I think most all the other ESC's out have a similar footprint, so if one will fit in the space you have, it's likely the others would as well. I had my Orion setup between the motor and battery for a while and it does fit, but it's tight for sure (I even had the fan mounted on it for a while too).
There's no lack of ESC choices right now, that's for sure.
J.Mikoliczyk
RB6 - MBX7R Eco
Old 09-15-2015, 07:01 PM   #12428
oPAULo's Avatar
I went with Orion R10 pro in both my car and my sons. Picked up both used for under 100 each and couldn't be happier with them. Simple and easy programming. Cheap. Runs cool.
oPAULo is offline   Reply With Quote
Old 09-16-2015, 03:36 AM   #12429
eper's Avatar
hands down orion. they are pretty issue proof. cost more but then its a done deal and your set for a coupe years. im usuing one thats been in a car sice they first released them and havent had a single issue
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 09-16-2015, 04:54 AM   #12430
Thanks guy's Orion R10 sounds like the one, I tried the sideways pack last year and put down slower laps, i drive an OS powered MP9 all spring summer fall and i'm kinda new to 2wd buggy i probably had the wrong setup for the sideways pack???
Old 09-16-2015, 08:48 AM   #12431
tef
I'm back to inline battery, sideways is not for everyone.
Thanks to my sponsors Kyosho America*O.S. Engines*TrakPower*Pro-Line Racing*Futaba*O'Donnell fuel*Team Scream Racing
tef is offline   Reply With Quote
Old 09-16-2015, 08:59 AM   #12432
oPAULo's Avatar
I'd like to try it but I want to be able to quickly move the battery forward and back by moving foam. I couldn't get enough weight over the rear on Saturday. If I had time to switch to rear motor I would have.
Old 09-16-2015, 10:36 AM   #12433
tef
I run the thick weight on the rear bulkhead, think its 15g.
Old 09-16-2015, 11:20 AM   #12434
oPAULo's Avatar
I had 2 ounces strapped to the waterfall. My shock package was way off too. We'd been running slicks but it finally got cold out and the track dried up.
I was just way off base on everything.
Old 09-16-2015, 04:35 PM   #12435
[[john]]'s Avatar
Trader Rating: 24 (100%+)
Here's a 3D Printed waterfall, its made to fit a 25x25mm fan. Summers coming here in Melbourne, and I expect there will be many race day's around 35*C, I'm gonna need as much cooling as I can get!
It was drawn by B. Portelli, and produced by HyperRC
Kyosho Ultima RB6 & RB6.6 Car Thread-12032388_1097302490287947_711341419_n.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-12033644_1097302513621278_1845923146_n.jpg
[[john]] is offline   Reply With Quote
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Yesterday 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
