    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 09-04-2015, 05:33 PM   #12391
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Originally Posted by cnelson3 View Post
if you don't have the spacer between the inner and outer bearing, that will do it. If you have the spacer, a bearing could be bad or the hex on the wheel might be pressing on hub.
Ok,yea I don't have that spacer between the bearings(law253). I think that's why I keep blowing out the inner bearings. Thanks
hairymuffin is offline   Reply With Quote
Old 09-05-2015, 05:39 AM   #12392
cnelson3's Avatar
Trader Rating: 65 (100%+)
We all learn that lesson the hard way. That spacer is there to put all the load of tightening the axles on the inner race of the bearing. Without that spacer, you are essentially pushing the inner race one way and the outer race the other. Binds up the balls
Kyosho America
Peak Racing
Trackside Hobbies & Raceway - Milwaukee, WI
cnelson3 is offline   Reply With Quote
Old 09-05-2015, 04:13 PM   #12393
oPAULo's Avatar
Went back to the 76 spur as recommended and dropped the timing to 10 on the motor. Zero SC timing. Thing got hot. Way hotter than when I was at 30 degrees timing. Dropped to a 20 pinion and still hot. I was at 84/22 so gearing is back close to where I was. I don't see how less motor timing would make it run hotter.
Something seems off here. Any pics I've seen of these motors have the letters lined up with the solder tabs. Mine are way off at 10 degrees and lined up at 30. I don't remember but did it have 30 out of the box? Guh..
I should be aligned to this notch in the case no? If my timing is actually way retarded that would make it hot I assume.
I actually turned some of my fastest laps today but that had more to do with finally making slicks work.
oPAULo is offline   Reply With Quote
Old 09-06-2015, 06:21 AM   #12394
eper's Avatar
Trader Rating: 14 (100%+)
looks like the glue in the can let loose and something inside shifted. time to send it in
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 09-06-2015, 09:30 AM   #12395
oPAULo's Avatar
Thanks for the reply Eper!!
I didn't even notice it. Yup. The whole end of the can is loose and coming off. Lord knows how long I've been fighting this.
Old 09-06-2015, 10:09 AM   #12396
LiL CeeZ's Avatar
Trader Rating: 15 (100%+)
Just about ready, bodies are being painted and waiting on my power supply to get here and all systems a go! My 6 year old Son is so happy, bugs me everyday.
Team Associated B6D
LiL CeeZ is offline   Reply With Quote
Old 09-06-2015, 10:19 AM   #12397
Hi guys.
Does anybody know who makes gearcover for 3 gear gearbox?
uro76 is offline   Reply With Quote
Old 09-06-2015, 01:24 PM   #12398
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Originally Posted by uro76 View Post
Hi guys.
I just ordered a couple from a guy on FB that was linked or posted back on pg. 815 or something.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 09-06-2015, 04:55 PM   #12399
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
I've just installed the RC Shox dual stage piston set in the rear of my RB6. it seems like the insert needs something to hold it in place. Does anyone have experience using these? Maybe you can post pics of your setup? I have the insert on top and the base on the bottom. I've watched the videos but it's a little hard to see.
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 09-06-2015, 04:57 PM   #12400
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Hi guys.
Chris Mielke on facebook
Jaz406 is offline   Reply With Quote
Old 09-06-2015, 05:22 PM   #12401
Default 3 gear conversion for the rb6, rt6 and sc6
I have a facebook page and group on discussing my 3 gear conversion for the Kyosho line of cars.
go to facebook and search for "3 gear conversion for Kyosho"
Old 09-06-2015, 09:02 PM   #12402
jag5508's Avatar
Looks good just ordered one .
TOYZ 4 BOYZ
jag5508 is offline   Reply With Quote
Old 09-08-2015, 08:19 AM   #12403
13Maschine's Avatar
Let's hear some steering servo suggestions from the group. I'm leaning towards ProTek 170S or Futaba S9352HV. Probably the Futaba as it seems like it will be faster with lower voltage. I'm running this with my Futaba 4PX system. Thanks!
Old 09-08-2015, 09:48 AM   #12404
Regional Moderator
RobsRacin's Avatar
Every single 10th scale car I have ever owned has had Spectrum 6040 put in it, I simply can not kill them whether its 2wd mod buggy, Short course, 4x4 mod buggy, stadium truck... never an issue
RobsRacin is offline   Reply With Quote
Old 09-08-2015, 10:52 AM   #12405
RCmayor's Avatar
Send a message via Yahoo to RCmayor
And to complete the conversion there will soon be this, in several colors. The end of the slipper adjustment will have a rubber over boot that slides on and keys to the groove.
RCmayor is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
alex4r
