    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 08-16-2015, 03:20 PM   #12331
Regional Moderator
RobsRacin's Avatar
Originally Posted by tef View Post
I would imagine your talking front arms which makes sense to run gullys for more steering. Kevin is refering to the rear arms which on the RB6 help the car rotate in certain situations. My experience with rear flats are they square up faster and are better if you have to run a softer setup for bumpy tracks without giving up on power steering. When i try to run gullys with a soft suspension the car gets really tight on exit.
Ah yes I thought he was referring to the front, thank you for the info though on the characteristics of the arms. I look forward to trying them on the car
RobsRacin is offline   Reply With Quote
Old 08-16-2015, 08:39 PM   #12332
LIVipers's Avatar
Trader Rating: 38 (100%+)
Anyone here running mod and the 3 gear...can you comment on how it feels compared to the 4 gear? I'm in the middle of building my new RB6 and debating waiting for the 3 gear release from kyosho or building it with the 4 gear. Thanks in advance
LIVipers is offline   Reply With Quote
Old 08-17-2015, 04:37 AM   #12333
eper's Avatar
Trader Rating: 14 (100%+)
hey tef i was up there last week and the car was pretty good i think you may want to play with the axle shim and the suspesion mounts t widen the car. bring some longer bones and 3 line axles with you. please let me know what you find and if you want tell me if you heading out for practice would like to get some time in w you. hope your doing well
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 08-17-2015, 09:10 AM   #12334
3 gear has more overall rear traction and much more rip out of the corners. You dont have to wait on kyosho for 3 gear ( you might be waiting for along time) there are steps on pettitrc on how to make one.
mhuse6969 is offline   Reply With Quote
Old 08-17-2015, 12:22 PM   #12335
tef
Thanks for the heads up, ill add that to my list of things to try. Yeah ill Def. let you know how it goes, might go a week from this Saturday to test stuff. I have to run a few laps to learn the surface and then ill get my car sorted based on the attributes of turf.
Turf does look like fun tho, cant wait to try it!!
Thanks to my sponsors Kyosho America*O.S. Engines*TrakPower*Pro-Line Racing*Futaba*O'Donnell fuel*Team Scream Racing
tef is offline   Reply With Quote
Old 08-17-2015, 05:15 PM   #12336
eper's Avatar
k ill try and get up there then
new milford ct,
Old 08-18-2015, 06:16 AM   #12337
twindad98's Avatar
Trader Rating: 18 (100%+)
Default 3 gear
I thought I have heard that the 3 gear has less forward traction. But if it has more traction then great. I have the case mods done I just don't have the spacers yet.
I just recently picked up a used RB6 but I've had a RT6 and SC6 for a while. The short time that I have driven it I really like the feel of it. I basically have Zack Roger's setup on it with a few twists.
I just turned the battery sideways and I'm going to try it this weekend.
twindad98 is offline   Reply With Quote
Old 08-18-2015, 08:56 AM   #12338
symmetricon's Avatar
Trader Rating: 27 (100%+)
In a 3 gear config the motor rotates toward the front of the car. You will get less weight transfer to the rear on power and under braking there will be less weight transfer forward... The car will basically stay flatter under braking and acceleration... So yes, you will have less forward traction.....
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 08-19-2015, 05:44 AM   #12339
The 3 gear does produce less forward drive / traction from a standing start / low speed but because it keeps the front end loaded you can carry higher corner speed so you make less demands on the available traction out of the corners so it can feel like there is more traction overall.
Unless it's very low bite I think the 3 gear is generally quicker over a lap if you are a smooth flowing driver.
http://model-car-racer.co.uk/
Today AE .. tomorrow who knows?
RogerM is offline   Reply With Quote
Old 08-19-2015, 12:39 PM   #12340
cnelson3's Avatar
Trader Rating: 66 (100%+)
3 gear is fine. I found a bad wheel bearing and made handling really inconsistent.
Trackside Hobbies & Raceway - Milwaukee, WI
cnelson3 is offline   Reply With Quote
Old 08-20-2015, 02:27 PM   #12341
I am working on my rb6. I just set it up to a mid motor. How do you hold the battery in when you set it sideways? Thank you all again.
katoom007 is offline   Reply With Quote
Old 08-20-2015, 09:09 PM   #12342
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
I went this way,
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 08-21-2015, 04:51 PM   #12343
Trader Rating: 25 (100%+)
I got some thumb screws from a b5 and did it this way
joncmack is offline   Reply With Quote
Old 08-22-2015, 05:41 AM   #12344
Took the car out for a little clubbing,
Fresh layout just went in, but figured I'd try the sideways battery setup.
I really liked the feel of it, even on a green layout. Was pleasantly surprised with how well it was doing. I can see why a lot of people have gone to it. Once the traction comes up, I'll probably do the 3 gear tranny mod too and see if both together work well enough for me so see it as a viable tuning option. Probably be sticking with the sideways for sure. Car wasn't fully dialed in setup wise, so I expect it to get better.
J.Mikoliczyk
RB6 - MBX7R Eco
Old 08-23-2015, 06:09 AM   #12345
eper's Avatar
Default fan mount rb6
i came up with this quicky and free fan set up for my sons 17.5 rb6.. straight forward and easy the way i like it
Kyosho Ultima RB6 & RB6.6 Car Thread-beans-fan.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-jesse-fan.jpg
new milford ct,
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
