    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 08-09-2015, 08:27 PM   #12316
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Do you have both ball bearings in the gear and outdrive?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 08-09-2015, 08:41 PM   #12317
K_King! Thanks for replying!! Yeah they are in. Damndest thing! I'll be sure to share with all if I figure it out!!
Kevin
Leadfinger2012 is offline   Reply With Quote
Old 08-09-2015, 08:44 PM   #12318
K_King's Avatar
Post pics of your assembly.
Old 08-09-2015, 09:56 PM   #12319
rpboggs1's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Leadfinger2012 View Post
Whats Up All!!!
New RB6 owner.
Working my build right now and I've built a bunch of kits but I'm having a hell of a time with the ball diff. Built to the instructions every step of the way down to having the washers in the correct direction but the diff wont diff. I turn it all the way in it gets to lock, I back it out a but and I turn one outdrive the other doesn't move (no diff action). I've carried out the whole process a couple times now and no luck so I thought I'd try you kind folks!
Any input is much appreciated!!!
Kevin
Several years ago I had the same issue... I don't remember exactly what I did to fix it but I think I either had too much grease which prevented the diff rings from seating... Or maybe I just didn't get the rings to fully seat before tightening the diff screw... Or maybe just tightened the diff further than I thought I should to get it to properly seat. It certainly wasn't anything major in my case though. Good luck!
Kyosho RB6 * Kyosho ZX6 * Kyosho RT6
TLR 22SCT * TLR SCTE 2.0
Tekno NB48.3 * Tekno EB48.4 * Tekno EB48.3 * Tekno ET48.3
rpboggs1 is offline   Reply With Quote
Old 08-10-2015, 04:08 PM   #12320
so I'm really late to the party, been really trying to avoid it but i guess I'm going to bite the bullet and try shorty sideways. how big of a difference will 1mm make on the battery height? looking at the chassis it seems that 1mm will get rid of the ridges in the chassis. Im assuming a little more on the edges since it bevels just a touch? I was thinking of may just dremeling the sides and not even touching the middle of the chassis unless i need to. Has anyone done the shorty sideways and not have cared for it?
CaseyD is offline   Reply With Quote
Old 08-10-2015, 04:45 PM   #12321
vikingen's Avatar
Trader Rating: 27 (100%+)
I was also late to the party. recently did shorty sideways mod without touching the chassis, just cut the side pods.
car is definitely BETTER. you will not be disappointed.
vikingen is offline   Reply With Quote
Old 08-10-2015, 05:44 PM   #12322
Whats Up All!!!
New RB6 owner.
Kevin
Hey All,
Well I figured it out and I wish I had something more earth shattering than just re building it and re building over and over did the trick. I'm guessing one of the rings just didn't seat all the way. something to watch for on the first re-build again!!! Thanks Again those who replied to help!!!
Kevin
Old 08-10-2015, 09:15 PM   #12323
GIHOSU's Avatar
Originally Posted by yodace View Post
Does the rb6 2015 allow u to run the battery sideways without milling the chassis?
Try using 2 strips of Z8006 vibration absorption sheet to stick the battery down to the chassis. It works perfectly for me, no chassis mods necessary.
GIHOSU is offline   Reply With Quote
Old 08-13-2015, 07:13 PM   #12324
eper's Avatar
Trader Rating: 14 (100%+)
have any of you guys run the rude bits db2.. i think i want to try one
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 08-16-2015, 09:50 AM   #12325
K_King's Avatar
So who has tried the 521 flat arms recently?
Old 08-16-2015, 10:16 AM   #12326
tef
I was thinking of trying them again. Im attending a JC turf race and figure they might be good on astro, not sure tho as I never raced on carpet or Astro.
Thanks to my sponsors Kyosho America*O.S. Engines*TrakPower*Pro-Line Racing*Futaba*O'Donnell fuel*Team Scream Racing
tef is offline   Reply With Quote
Old 08-16-2015, 10:18 AM   #12327
K_King's Avatar
I ran then once last night, didnt change anything except shock ends to short and 27.5 droop using the inside hole. The rear end felt flatter, almost like you could drive the car a big harder overall. I don't think drilling is required on these arms but its worth a shot if you want to mess with it. I think have to go to a slightly softer rear setup as well. I was 32.5 and golds and I think white's would have been better or 30 wt.
Old 08-16-2015, 12:02 PM   #12328
Regional Moderator
RobsRacin's Avatar
Im not sure about the RB6 but when I ran my B5M on the astro we were going from the flat arms that we run on dirt to gull wings just for more steering. Not sure that applies to the RB6 but I certainly will try both when I go and see what I think
RobsRacin is offline   Reply With Quote
Old 08-16-2015, 01:59 PM   #12329
tef
Good info, thanks. Im going to have them with me and if its not going good ill be sure to turn the weekend into testand tune and try the flats.
Old 08-16-2015, 02:05 PM   #12330
tef
I would imagine your talking front arms which makes sense to run gullys for more steering. Kevin is refering to the rear arms which on the RB6 help the car rotate in certain situations. My experience with rear flats are they square up faster and are better if you have to run a softer setup for bumpy tracks without giving up on power steering. When i try to run gullys with a soft suspension the car gets really tight on exit.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
