    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 08-02-2015, 07:06 PM   #12286
oPAULo's Avatar
Digging all that green bling. You should get a batch of white wheels and dye them.
oPAULo is offline   Reply With Quote
Old 08-02-2015, 09:14 PM   #12287
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
DE Racing makes some green ones, I believe.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 08-03-2015, 03:33 AM   #12288
eper's Avatar
Trader Rating: 14 (100%+)
thanks.. i wanted to do something a little different.. waiting on a new servo then ill clean up the wiring in the front. but honestly i need to get to the track..im missing it a lot right now and work is crazy busy which is good and bad at the same time
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 08-03-2015, 08:54 AM   #12289
Michael#81's Avatar
Trader Rating: 254 (100%+)
See I may still be way off base.
I'm running a 20/84. Speed seems good compared to others though. No long straights on our local track. Pretty tight layout.
I currently have,
Tekin gen2 8.5 with 30 degrees timing.
Zero boost
5 degrees turbo
Still learning about reciever voltage also.
Is a Savox 1258 a high voltage servo?
Read some about reciever capacitors but with a fan and transponer I'm out of ports. I could plug the fan straight to the SC or even the battery.
Almost makes me miss spec slash class. Almost. I can see how people might get discouraged with all the tech. Lots to learn.
I would switch to 24/76 gearing for Paul's place. Also you can take most all the timing out of the motor and only run about 8-12*. The motor timing and gearing is where your over heating issue is coming from.
Also no need to run any turbo at all for the small track you are racing on.
Depending on what rx you have the savox servo might require a capacitor.
You shouldn't need a fan on the motor if all your gearing issues and timing issues are taken care of. I ran 4 battery packs down there the other night almost all back to back and never got over 140*.
Michael Malott
Michael#81 is offline   Reply With Quote
Old 08-03-2015, 09:05 AM   #12290
oPAULo's Avatar
Thanks man!!
I'll try that exactly.
We're running a Spektrum DX3S and not sure on the reciever. Not high end stuff.
I'm still learning the timing stuff. Boost, punch, turbo, slope, lag, guhhh... someday I'll have it figured. Someday.
Old 08-03-2015, 03:45 PM   #12291
Trader Rating: 42 (98%+)
Send a message via AIM to RockStar_199 Send a message via MSN to RockStar_199 Send a message via Yahoo to RockStar_199
I have the exotic wide rear and broke a outdrive because they were on the very end........anyone make a longer swing shaft than the stock ones at 65.5?
Mark C. Math
Kyosho TKI4
Triton Engines: L4 2108
J&T Bearing Co.
RC Pro TX10280
RockStar_199 is offline   Reply With Quote
Old 08-03-2015, 06:10 PM   #12292
mourinho's Avatar
Trader Rating: 42 (100%+)
You can run the 3 line axle KYOUM510-02 and shim the assembly inwards.
mourinho is offline   Reply With Quote
Old 08-04-2015, 05:03 AM   #12293
MODELTECH22's Avatar
Trader Rating: 20 (100%+)
Hey guys and gals, need some set-up help. I just got a RB6 and I am going to run it for first time this Saturday. Need a good set-up for medium to low wet some of the time and dry some of the time outdoor dirt.
22 3.0 Hobbywing
22 2.0 W/exotek chassis TEKIN
22T 2.0 Lrp Flow
SCT 22 2.0 Hobbywing
MODELTECH22 is offline   Reply With Quote
Old 08-04-2015, 08:57 AM   #12294
Regional Moderator
RobsRacin's Avatar
I have a similar track where I run. Ill fill out a setup sheet and post it up
RobsRacin is offline   Reply With Quote
Old 08-04-2015, 09:11 AM   #12295
Regional Moderator
RobsRacin's Avatar
Here you go. Don't have the car in front of me but I'm almost positive this is what I ran.
EDIT: Just noticed a mistake I made, running AE 1.6 pistons front and rear not AE 1.5's.
Old 08-04-2015, 10:46 AM   #12296
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Thumbs up
Are you using these?
ASC91308
Thanks in advance!
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 08-04-2015, 12:49 PM   #12297
skrichter's Avatar
Send a message via AIM to skrichter
For the Tebo setups, does anyone know what brand oil he uses? AE, TLR, or KYO? Big difference between them all.
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 08-04-2015, 02:28 PM   #12298
Regional Moderator
RobsRacin's Avatar
ASC91308
Thanks in advance!
Yes I am!
Old 08-04-2015, 07:11 PM   #12299
13Maschine's Avatar
THANKS ROB! Has anyone had any experience with the RC Shox Dual Stage piston setups? If so what kit did you go with? I've been running the VRP products dual stage setup in my D413 and it rocks but I like the adjustable part of the RC shox setup better at least looking at it and reading about it.
Old 08-04-2015, 07:22 PM   #12300
i beleive he used TLR. not sure what he uses now since kyo america has started importing their own oils
glenng is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 10-20-2017 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
