    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 07-13-2015, 08:00 AM   #12196
eper's Avatar
Trader Rating: 14 (100%+)
Hey guys most of u probably haven't seen me on here before but I'd like to proudly say that I have pulled my head out of my ass and am back running kyosho cars I've tried a few and there are some good cars out there but nothing makes me want to go race like my k cars. Thank god I'm back. Anyhow I am building a new rb 6 and am wondering if anyone knows where I can find some green anodized aluminum ballstud shims in .5,1 and 2 mm. Thanks for any help and hopefully I can get back to where I was as far as driving before my stupid move from kyosho.
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 07-13-2015, 09:06 AM   #12197
eper's Avatar
Are most guys running the brass weight in the car or any weight if so how much and where so u can get a descent starting point
new milford ct,
Old 07-13-2015, 06:24 PM   #12198
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
I"m about to pickup an RB6 as my first Kyosho car and I'd like to get a set of Lunsfords turnbuckles with it. If I buy the kit that comes with the lunsford ball cups, will they also fit the longer kyosho cups? Or would I need a somewhat shorter set of turnbuckles for use with the longer cups? Thanks in advance!
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 07-13-2015, 09:49 PM   #12199
13Maschine's Avatar
I believe I have answered my own question but just in case someone else is wondering, there are two lunsford kits. One for use with the stock ball cups and one with their ball cups. The standard punisher kit LNS2687 for use with the stock cups and LNS36102 Super Duty with the Lunsford ball cups. Super Duty is 3.5mm vs Punisher size of 3mm.
Old 07-13-2015, 09:51 PM   #12200
they make a set without the cups and that is what you want if you wanna use kyosho cups. the ones with the cups are 3.5mm super duty which are best used with their titanium ballstuds which are overall better setup because you can remove ballstud with cup still attached via a 2mm hex wrench. so you are not wearing out your ballcups everytime you wanna adjust roll.
glenng is offline   Reply With Quote
Old 07-14-2015, 01:11 AM   #12201
I run the kyosho brass front pivot and the brass rf block. Running out door low to medium grip (proline holeshot type tracks)
Try some of k-kings setups are a good place to start. I'm currently playing with the sideways shortie and 3 line rear axels with the hex spaced out 2mm from the hub.
Tom87 is offline   Reply With Quote
Old 07-14-2015, 04:18 AM   #12202
eper's Avatar
isnt moving the hex out going to give you more on power steerig.. ie loosen the car up but should make it feel more stable.. do you run those weights indoor and do you know how much they weigh off hand id rather try the car with led in it before i buy weights i may not like thanks for the reply
new milford ct,
Old 07-14-2015, 01:07 PM   #12203
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Anytime I went narrow on the rear pivot the car almost wanted to roll too much on itself and the rear end would feel very "spongey" and never really good. Once I pushed the tires out I kept the same roll, but the car was a lot more stable. I didn't really notice a ton of on power steering, I just noticed I was able to drive it harder but kept the same rear traction as before.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 07-15-2015, 02:20 AM   #12204
oPAULo's Avatar
Switched to C-in C-in and got the clearance for the pucks but now I notice the axle is also rubbing the outdrive at full compression. I either need a shock limiter or long eyelets.
GUH...
With all the replacement parts I bought I'm kinda married to this MIP setup. The pucks really are nice though.
oPAULo is offline   Reply With Quote
Old 07-15-2015, 08:31 PM   #12205
The spaced out hex to me gives less side bite and more forward traction. Best of both worlds imo
The brass front bulkhead adds 24g
Not sure on the rf block, I would guess around 30g
Old 07-16-2015, 02:00 AM   #12206
axial makes green ones
rb6kevin is offline   Reply With Quote
Old 07-16-2015, 04:31 AM   #12207
eper's Avatar
thank you guys should be getting my buggy delivered today.. gotta work next 15 days straight but gonna try and have it ready for day 16 and hit the track.. hope everyone enjoys there racing and wrenching
new milford ct,
Old 07-16-2015, 07:04 AM   #12208
Regional Moderator
RobsRacin's Avatar
Built my buggy last night at the track in between club racing. Not too bad of a build just some confusing parts. Just gotta solder it up and throw a setup in it and its ready to go
RobsRacin is offline   Reply With Quote
Old 07-16-2015, 12:23 PM   #12209
mattjk's Avatar
Trader Rating: 78 (100%+)
http://www3.towerhobbies.com/cgi-bin...?&I=LW5181&P=1
$333.96
mattjk is offline   Reply With Quote
Old 07-17-2015, 07:32 PM   #12210
Jpdanger's Avatar
What gear cover do you use for the three gear mid motor tranny?
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 11-22-2017 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
