    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 06-24-2015, 06:05 PM   #12151
Jpdanger's Avatar
Originally Posted by gism17 View Post
Noob question! Can you use the b5 rear hubs on the rb6? I'm digging the schelle ones...
I had this idea too, but you'll lose the front/rear movement tunability using the AE hubs since they are wider than the Kyo hubs.
You could spend a few bucks on the B5 kit rear hubs (ASC91414) and experiment.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 06-25-2015, 05:23 AM   #12152
twindad98's Avatar
Trader Rating: 16 (100%+)
Those of you that are using Zack Rogers' setup, are you using any anti-squat? I was looking at the setup sheet and I didn't see any noted. I just picked up a used RB6 and I'm going through it and I want to use that setup.
twindad98 is offline   Reply With Quote
Old 06-25-2015, 07:50 AM   #12153
symmetricon's Avatar
Trader Rating: 27 (100%+)
Copy his setup to the T! It's amazing .....
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 06-27-2015, 06:47 PM   #12154
Steve081's Avatar
Originally Posted by joecool View Post
The cut up motor spacer supports the bearing and is still keyed into the motor plate. Next you need to shim the motor plate 6mm from the trans case. W0142GM spacers work really well here and match the color of all the other aluminum bits on the car. You need a lot of them, I used 20 total.
Tighten everything down and be sure everything spins smooth and free.
I was lucky to find a gear cover that is 3d printed and sold by a cool guy on Facebook.
Mount everything up in your buggy, hit the track and air it out!
did you need to use longer bolts to assemble? about to give this a go.
Steve081 is offline   Reply With Quote
Old 06-27-2015, 06:50 PM   #12155
3srcracing's Avatar
Trader Rating: 25 (100%+)
Anyone that needs a dialed Rb6, I know of one! Check Kyosho RC Nation.
3srcracing is offline   Reply With Quote
Old 06-28-2015, 09:22 AM   #12156
alex4r's Avatar
Send a message via AIM to alex4r
Use a .5 shim under the rear hanger.
Alex Kennedy
Bellgate Distributors | Highest RC
Sanwa M12S | Kyosho RB6.6 | Kyosho ZX6.6 | Kyosho MP9 TKi4
alex4r is offline   Reply With Quote
Old 06-28-2015, 09:44 AM   #12157
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
I tried a different front end on my car this last weekend for our series race here. I have really liked my car, but with the new Aluminum 502 pivot coming out that I run on my truck, I wanted to try that front end on my 2W. It was actually pretty good. I thought I would lose some steering but I don't think I lost as much as I thought, but I gained quite a bit of stability allowing me to drive it a little harder. For those looking to try something different, just please note the different droop, axle spacing, and parts used on the front end.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 06-28-2015, 05:22 PM   #12158
ThePanda's Avatar
Trader Rating: 64 (100%+)
I am yet to get a run on dirt with my RB6. It just looks so so nice and clean on the shelf. I have to remember what I bought it for...
ThePanda is offline   Reply With Quote
Old 06-30-2015, 05:50 PM   #12159
oPAULo's Avatar
Question about sag, or droop as it's called nowadays. Seems like 24mm is about the standard front ride height. I have the medium shock ends and with my front suspension fully extended I'm at 24mm. Is zero front droop the norm or should I have a little? I'm still pretty green but driving other buggys and letting others drive mine, it's handling really good. I think I'd like just a little more on power steering though.
oPAULo is offline   Reply With Quote
Old 06-30-2015, 09:12 PM   #12160
gism17's Avatar
Trader Rating: 20 (100%+)
Is Kyosho coming out with there own 3 gear tranny anytime soon or should I just go ahead and built my own? I want to have a extra one all build and ready to go so I can just swap it out on the track, planning on using schelle bearings,MIP diff and out drives,avid aluminum topshaft... Wat are your guys thoughts on this plan?
RB6
LUKE 4:18
gism17 is offline   Reply With Quote
Old 07-01-2015, 05:48 PM   #12161
Scrad's Avatar
Trader Rating: 15 (100%+)
Do the AKA Evo pre mount rims and tires fit the stock axle lengths? I've borrowed some AKA wheels before and the axle nuts didn't get enough threads on the axles for my liking. They could have been for a Losi or whatever I don't remember off hand.
Scrad is offline   Reply With Quote
Old 07-01-2015, 11:49 PM   #12162
Jpdanger's Avatar
I buy the pre mounted AKAs and there's plenty of axle for a serrated nut.
Old 07-03-2015, 05:21 PM   #12163
timannnn6's Avatar
Trader Rating: 124 (100%+)
Finally hopped on the Kyosho bandwagon. After having a b5m for 6mo I wanted to try something different. I picked both of these up used. Needed some TLC but they are now race ready. Sideways battery is my sons running Tebo setup. Inline is mine running ZR.
Can't wait to test out...
Kyosho Ultima RB6 & RB6.6 Car Thread-img_0999.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-img_1001.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-img_1002.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-img_1003.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-img_1004.jpg
timannnn6 is offline   Reply With Quote
Old 07-03-2015, 09:10 PM   #12164
Super clean layout, nice...
I haven't tired any setups other than the Zack Rogers setup and it's excellent, if the tebo setup isn't working try the ZR setup....
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 07-03-2015, 10:47 PM   #12165
oPAULo's Avatar
Those are beautiful timannn!
My son and I had a rough start tonight but he pulled out a win in novice and I won the B and 7th in the A.
So are the carbon composite arm stronger than the regular??
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22953 Today 12:29 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
windellmc
