    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 06-13-2015, 01:07 AM   #12121
KalEl63's Avatar
I ran Kevin Kings SDRC 2.0 set up today with a couple of minor changes and all I can say it the car was great so thank you Kevin for sharing it.
now to get the RT6 working like the RB6 on my local track
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 06-13-2015, 04:53 PM   #12122
gism17's Avatar
Trader Rating: 21 (100%+)
Wats the best shock oil to used on my rb6? Will b Building shocks today
RB6
LUKE 4:18
gism17 is offline   Reply With Quote
Old 06-13-2015, 05:14 PM   #12123
oPAULo's Avatar
Pick a brand that is locally readily available and stick with it. My small town hobby shop stocks Losi so that's what I run. Lots run Associated.
oPAULo is offline   Reply With Quote
Old 06-13-2015, 05:56 PM   #12124
alex4r's Avatar
Send a message via AIM to alex4r
Has anyone successfully mounted a motor fan? I saw there are some 3D printed waterfalls with fan mounts for the B5m and 22 but didn't see any for the RB6.
Alex Kennedy
Shifty's RC
Sanwa M12S | Kyosho RB6.6 | Kyosho ZX6.6 | Kyosho RT6 | Kyosho MP9 TKi4
alex4r is offline   Reply With Quote
Old 06-13-2015, 06:10 PM   #12125
oPAULo's Avatar
Kiddo and I each put it on the box today. Him in novice and me in 2wd mod. The front end is getting some play in it but dang this thing can take a beating. Was fast and smooth all day. I got faster as the track dried out and got slicker. I would up with 24/76 gearing with a Tekin 8.5. The motor was quite warm after a 10 minute main but you could still hold your fingers on it.
Old 06-14-2015, 12:10 AM   #12126
joecool's Avatar
Trader Rating: 19 (100%+)
Default step by step 3 Gear build pt.1
For anyone interested in building a 3 gear trans for their RB6 before Kyosho releases their own I have a few good photos of how I built mine. It may not be perfect but I run mine with a 6.5 Mod on carpet and have had no issues. You will be using the 3 gear rear motor case included in the kit for this mod.
The first photo shows whats going to end up being your left side of the 3 gear trans case. In the picture I have the original case on the left and the shaved down version on the right. The bosses just need to be Dremeled carefully flush with the case. Then trim the first step of plastic off where the top shaft perturbed.
The second photo again shows the original case with the modded version to the right. The hole where the top shaft was originally needs to be blocked the from the inside of the trans case with approximately a 1.5mm or 2mm shim. I found that the plastic slipper spacer UM603B glued in with tire glue works perfectly.
The third photo is showing the top shaft. Unfortunately the top shaft has to be shimmed away from the bearing a little bit or the teeth of the gear chew into the case. I used just one plastic front axle spacer UM714 to keep it spinning free.
The fourth photo shows the right side of the trans case. A body reamer was used to make a hole where the top shaft will exit from.
The final photo shows the spacer UM508C and how I cut it into pieces to adapt to the new reverse orientation it will be in.
Kyosho Ultima RB6 & RB6.6 Car Thread-img_1406.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-img_1407.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-img_1408.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-img_1409.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-img_1410.jpg
Joe Cool
Kyosho America, Team Orion, Ko Propo
joecool is offline   Reply With Quote
Old 06-14-2015, 12:13 AM   #12127
joecool's Avatar
Default step by step 3 Gear build pt.2
The cut up motor spacer supports the bearing and is still keyed into the motor plate. Next you need to shim the motor plate 6mm from the trans case. W0142GM spacers work really well here and match the color of all the other aluminum bits on the car. You need a lot of them, I used 20 total.
Tighten everything down and be sure everything spins smooth and free.
I was lucky to find a gear cover that is 3d printed and sold by a cool guy on Facebook.
Mount everything up in your buggy, hit the track and air it out!
Kyosho Ultima RB6 & RB6.6 Car Thread-img_1411.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-img_1412.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-img_1414.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-11430122_10101554464238377_3854468739416934585_n.jpg
Joe Cool
Old 06-14-2015, 12:33 AM   #12128
Suspended
Originally Posted by joecool View Post
For anyone interested in building a 3 gear trans for their RB6 before Kyosho releases their own...
Umm, what transmission case did you start with? Seems like some pertinent info to include. Oh, you run on carpet, makes sense.
Mantis Toboggan is offline   Reply With Quote
Old 06-14-2015, 10:47 AM   #12129
Jpdanger's Avatar
Any word on when Kyosho will be releasing the optional three gear mid motor tranny?
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is online now   Reply With Quote
Old 06-14-2015, 04:38 PM   #12130
symmetricon's Avatar
Trader Rating: 27 (100%+)
Just finished up the Dash 4 Cash race in Houston. First time running my new RB6, had the Zachary Rogers setup on and it was awesome! A2 I finished 4th right behind some really fast guys! This is the best 2wd I've driven by a long shot...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 06-14-2015, 06:36 PM   #12131
oPAULo's Avatar
Looks to me like you ARE one of the fast guys!!
Congrats!
Old 06-14-2015, 08:23 PM   #12132
Suspended
Good job. Those are some big names. If you would have had some 19's instead of those couple 22's you could have beat JR.
Old 06-15-2015, 06:14 AM   #12133
Yeah, I had a couple bobbles but I have no complaints about the car. Locally guys make fun of me because I change cars every other month trying to find a car that suits me best, this one definitely is for me.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 06-15-2015, 09:26 PM   #12134
Pics of my RB6 at Houston's Club R/C Dash for Cash race.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 06-15-2015, 09:28 PM   #12135
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Yesterday 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
