    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 06-06-2015, 08:26 AM   #12091
oPAULo's Avatar
Bent one of the traxxas shafts on the first practice. They appear to be inferior. I dunno. Imma try to break it when we get home. Pray the other one lasts the day. Prob not the ideal car to share with my son in novice class but we do what can.
oPAULo is offline   Reply With Quote
Old 06-06-2015, 12:07 PM   #12092
Teufel Racing's Avatar
Trader Rating: 27 (100%+)
It happens, more so with just about any novice driver behind the wheel, but if you son is having fun it's worth it. At least you know how to make more.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 06-06-2015, 12:10 PM   #12093
oPAULo's Avatar
LOL! Having a blast! He qualified on the podium.
Me, not so much..
Old 06-06-2015, 05:58 PM   #12094
oPAULo's Avatar
The anti-squat .5mm shims. My car has stacks of .25mm washers but they're all stacked to match the manual. What effect does this adjustment have? Just set it and forget it?
My car doesn't have the spacer under the front hinge pin carrier but it looks like this is normal.
Car felt great, I think. Still pretty green but it felt smooth and was stable when you opened it up and all the way down the straight and in the brakes. I need more wheel time. It feels balanced.
Are shock oil weights comparable across brands? I ended up 30wt all around and 2x1.6 all around. The top qualifier let me check out his B5M and he was way heavier on damping. All the cars I felt had firmer damping. It was pretty hot in there today so maybe 30 was light.
Getting some shock shafts and seals ordered up. Wheels and tires. Aluminum servo horn. (Pulled the ball out). Some other odds and ends.
Old 06-07-2015, 10:16 AM   #12095
gism17's Avatar
Trader Rating: 20 (100%+)
Default New to the rb6
Wats up guys I plan on getting back into racing 17.5 class with my new rb6 I believe this kit is a first run because previous owner said it was bought back in 2013 and never assembled.
Wat are some good upgrades that need to b done to the kit?
Good building tips?
Wat brand shock oil should I use on the shocks?
Any others tips much appreciated. Thanks
RB6
LUKE 4:18
gism17 is offline   Reply With Quote
Old 06-07-2015, 12:13 PM   #12096
Jpdanger's Avatar
Good building tips?
Aluminum rear hangers for the extra tuning options. I also got the lightweight top shaft and avid slipper system. MIP pucks will help drop weight as well as the lightweight aluminum chassis, but these two upgrades can be pricey. Titanium turnbuckles will help drop weight and are reasonably affordable.
I use AE oil since my LHS stocks AE oil. Oil doesn't really matter so long as your stick with one brand. There is no standard between the different manufactures, so Losi's 30 may or may not be the same as AE's 30.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 06-07-2015, 01:05 PM   #12097
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
I've been using AE oil recently as well.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 06-07-2015, 04:39 PM   #12098
oPAULo's Avatar
Are all buggy wheels created equal? Looking at some pre mounted tires.
Old 06-07-2015, 10:26 PM   #12099
Jpdanger's Avatar
No. They all have slightly different tolerances, clearances, and weights. Some have recessed nut wells while others may be flush.
I like AKA premounted Chain Links. The wheels fit with enough axle to screw a nut onto.
Old 06-08-2015, 02:54 AM   #12100
oPAULo's Avatar
Thanks kindly man!! That's exactly the tire I was looking at. I'm running the pucks setup so the axles are plenty long. Don't see premounted fronts though.
Speaking of which, when I got the car, the pucks were just about worn through to the shaft so I ordered some more plus the screws and pins and loctite cause I knew I was going to have to cut them off there after I ruined all the screws trying to get them apart. I'll be danged if every single one didn't come right apart. Super sweet setup! All I had to replace was $3 worth of pucks and it's just like new. Feels great! No binding. Wicked smooth and quiet. Highly recommended.
Anyway, I looked up the TQ at the track and searched him out in the pits and that's what he was running. Super softs. Super nice guy too. Answered all my questions. Said he was hardcore RB6 until he picked up an Associated sponsor. Those B5M's really are nice.
But my first RC car, some 26 years ago, was a by God Ultima so I'm tryna have some good karma here.
Old 06-08-2015, 03:40 AM   #12101
oPAULo's Avatar
I searched for almost an hour and found nothing...
What is the type-c front suspension mount??
I know type-b is original but stronger. Is type-c wider??
Old 06-08-2015, 09:29 AM   #12102
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
The "C" mount is for the RB5 SP. It is a wider suspension mount. Stick with the stock "B" mount.
Team Kyosho (RB6, RT6, ZX6 & SC6)
Team Orion R10.1 Pro
Team Orion Touch Duo Charger
Team Orion Pro Carbon 100C Batteries
motorfinger is offline   Reply With Quote
Old 06-08-2015, 09:34 AM   #12103
gism17's Avatar
Thanks for the help bro I'm looking into those parts latter today! Any other input is much appreciated
RB6
LUKE 4:18
Old 06-08-2015, 09:41 AM   #12104
cnelson3's Avatar
Trader Rating: 65 (100%+)
They are different widths. What specifically are you looking for? The the block or the aluminum piece that sits in the front bumper. Btw, stick with the type -b.
cnelson3 is offline   Reply With Quote
Old 06-08-2015, 11:47 AM   #12105
oPAULo's Avatar
Excellent. Amain kept bringing up both when I searched RB6. When I replaced the servo horn I found the block was cracked on both sides but luckily the car came with a spare. The aluminum support looks fine though. No slop in the holes and it's never come off.
Thanks again guys. Hopefully I can move up the ranks on Saturday. I got faster every heat but still 2 seconds off the pace at the front. I could click off 2 or 3 good laps though so I know the car is close. I just get so dang nervous on the stand. One heat they announced I was in second and just turned fast lap for the heat and I completly fell apart. I was physically shaking. Good lord....
Maybe I need to wear headphones. Or get me a lil' flask. Haha!
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Today 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
