    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree15Likes
Old 06-05-2015, 01:13 PM   #12076
oPAULo's Avatar
FYI Kyosho shock shafts are harder than hammered pig s*@t!! Tried to straighten it and it shattered like carbide. Only thing I could find is a SLASH hardened titanium nitride coated shaft. It is identical in every way except it is 3.95mm longer. Trying to work out stroke and spacers right now. Mainly worried about bottoming the piston in the shock. Thoughts?
We gone race tomorrow byGod!!
oPAULo is offline   Reply With Quote
Old 06-05-2015, 01:37 PM   #12077
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
You could possibly cut down the shaft to almost the lower e clip line and then
Very carefully take a thin cut off wheel on the Dremel and grind in a new lower e clip line in the shaft. It's not a prefect solution, but was something I used to do back in the day in a pinch. I done right, it works pretty good, get it wrong (new e clip groove not deep enough to fully seat the clip) and the bottom e clip won't stay on.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 06-05-2015, 01:41 PM   #12078
oPAULo's Avatar
Stock shaft is 3.43mm away from bottoming the piston when it's assembled so it will need 3mm internal shim and 1mm external and this will give me the same stroke, 1mm longer shock, and .5mm piston clearance when the shock is bottomed.
Anyone see any issues with running the piston so close to the top of the shock?
Think 1mm longer shock is going to ruin it?
Best I can do and be on track in the morning.
Old 06-05-2015, 01:47 PM   #12079
oPAULo's Avatar
That's a beautiful idea. That would actually make them identical. I'm a machinist by trade but don't feel like driving all the way to the shop and not sure I have a groove tool that thin anyway. And I ain't spending half the day grinding a tool. Imma measure some cutoff wheels.
Thank you sir!
BTW tomorrow is the grand opening of SRI raceway in Louisville KY. From what I've heard, I'll have the only RB6.
Old 06-05-2015, 02:31 PM   #12080
oPAULo's Avatar
Muahahaaaa....
Did a few test cuts on the broken shaft.
I'm happy. Here we go.
Old 06-05-2015, 02:50 PM   #12081
cnelson3's Avatar
Trader Rating: 65 (100%+)
I may be thinking about this wrong but I would have used the short eyelet and put 3.5mm spacer(s) on the shaft externally. Should have gotten you through the day and been fairly close.
cnelson3 is offline   Reply With Quote
Old 06-05-2015, 02:54 PM   #12082
oPAULo's Avatar
I'm not yet up to speed on eyelet lengths but I think I have the shorts on already. Shorts on all 4 corners I believe.
Edit: This car came from Milwaukee.
Old 06-05-2015, 02:57 PM   #12083
oPAULo's Avatar
So ya, Tebo called me looking for a set of titanium nitride coated shock shafts. Imma hook him up. LOL!
Old 06-05-2015, 05:28 PM   #12084
Jpdanger's Avatar
Good enough for government.
I'd laugh if the cut shaft end has a negative effect on fluid dynamics within the shock...
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 06-05-2015, 05:54 PM   #12085
oPAULo's Avatar
I'm a long way away from knowing what your talking about and even farther from being able to feel the difference.
Old 06-05-2015, 07:57 PM   #12086
oPAULo's Avatar
Got it all buttoned up. Fresh carbide diff. Fresh pucks. Fresh gears. Fresh Schelle slipper pads. Fresh shock oil. 2x1.6 front and rear. 30wt. front. 27.5wt. rear. Took it down the road and WOW is this thing smooth and quiet. Can't wait to race tomorrow!
Old 06-05-2015, 08:02 PM   #12087
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
so, is that a Tire ring?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-05-2015, 08:04 PM   #12088
oPAULo's Avatar
Ya wife and I have a thing for dual sport bikes.
Old 06-05-2015, 09:54 PM   #12089
Carl Giordano's Avatar
Trader Rating: 23 (100%+)
Just purchased the new rear arms with the extra mounting holes. Hardto tell which if the three holes is the same as the single mounting hole from he older arms? Also, does anyone know the effct it will have on the handling if you move the shock bottom to the inner or outside hole. Thanks.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 06-06-2015, 12:15 AM   #12090
Thank you sir!
Glad you liked the idea. It's old school for sure, but if it works, it works. Lol
Muahahaaaa....
Looking good glad it appears to have worked out the way you needed it to. If I remember right, it doesn't take too long to do once you have it all ready to go.
J.Mikoliczyk
RB6 - MBX7R Eco
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22967 Yesterday 06:47 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
