    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 05-30-2015, 11:13 PM   #12061
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Originally Posted by yodace View Post
Need a starting setup for high bite carpet ?
https://jtprc.files.wordpress.com/20...var-carpet.pdf
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 05-31-2015, 12:43 PM   #12062
yodace's Avatar
R/C Tech Charter Subscriber
Thx
yodace is offline   Reply With Quote
Old 06-01-2015, 01:24 AM   #12063
Originally Posted by cnelson3 View Post
I think the idea is to increase the distance between the hinge pin on the hub and the hex. When you compare what some other brands are doing, that distance is considerably greater than what is on the 6 series of hubs. Essentially you are increasing leverage the chassis puts on the suspension and causes the weight to transfer back farther/faster. The last time I tried it, I had too much grip and I couldn't get the car to keep weight forward enough to turn on power. I didn't spend much time working with it because we had a big race coming up and I thought it would be better to run what I knew versus trying to figure something out during the race program. I ordered a set of 3 line axles with the 62.5 bones to try out. I have plenty of 65.5 bones if I need to switch them out.
Do you have a part number for these longer axles?
potatobed409 is offline   Reply With Quote
Old 06-01-2015, 04:57 AM   #12064
cnelson3's Avatar
Trader Rating: 65 (100%+)
um510-02. I recommend getting the axles only. I bought the axles with the bones and the 62.5 bones are just too short.
I worked on my setup this last weekend and raced both Friday and Saturday. By Saturday, the car felt better than it ever had for me. I ended up going back to the inside hole on the old arms with the long eyelets and 26.5 droop. I really like the 3 line axle setup.
Kyosho America
Peak Racing
Trackside Hobbies & Raceway - Milwaukee, WI
cnelson3 is offline   Reply With Quote
Old 06-02-2015, 06:10 PM   #12065
Trader Rating: 115 (98%+)
What does toe all do. I see so many different set ups c in d in so on. I know what makes what degree but what's that translate in to.
ashxxx is offline   Reply With Quote
Old 06-03-2015, 05:12 AM   #12066
Trader Rating: 22 (100%+)
I have been having sort of the same question lately. When looking at the chart, it would appear that different options of the inserts offer the same degree of toe; for example, B-in + B-in = 3.0 degrees and D-in + D-in = 3.0 degrees. I used the B-in + B-in on my buggy since it would seem to offer the most options to easily change the toe while still using the "in" blocks (up to 4.0 degrees). Most setups I see use C-in or D-in for both, however. Does that really make a difference?
joncmack is offline   Reply With Quote
Old 06-03-2015, 09:16 AM   #12067
It translates to toe in and track width and it make a huge difference. When you use the same pill front and back the toe in will be 3' but at different widths. D-in/D-in is narrow and D-out/D-out is wide. In general narrow locks in the rear and wide helps it rotate. Hope this helps.
http://www.petitrc.com/setup/kyosho/...structions.pdf
Jeremy Clark
RB6 for Mid, ZX6 and an untold number of Axial crawlers for family fun...
Arcain41 is offline   Reply With Quote
Old 06-03-2015, 11:35 AM   #12068
Correct....however, what I'm asking is, is there a difference between using D-in/D-in vs. using B-in/B-in?
Old 06-03-2015, 11:45 AM   #12069
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
Both are 3 degrees of toe, so no difference in the toe in for either. Mainly a pivot/track width difference/feel. Depending on how you want the car to feel/react would be the biggest difference in which one you'd want to run, B-in/B-in or D-in/D-in.
About 1.5mm in hinge pin pivot width between the two if I measured it out right.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 06-03-2015, 02:45 PM   #12070
It translates to wider track width. The complete rear end is more narrow or wider without changing toe.
Old 06-03-2015, 08:57 PM   #12071
Carl Giordano's Avatar
Trader Rating: 23 (100%+)
Can anyone tell me what the gearbox ratio for the 3 gear and 4 gear system. Thanks
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 06-03-2015, 09:02 PM   #12072
Trader Rating: 91 (100%+)
The transmission ratio is 2.6 to 1. Same for rear, mid, 3 or 4 gear.
Just leave him alone, he knows what he's doing!
Eric Tomczyk is offline   Reply With Quote
Old 06-04-2015, 03:33 PM   #12073
Jpdanger's Avatar
When are we going to see the optional three gear tranny available for sale?
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is online now   Reply With Quote
Old 06-05-2015, 05:10 AM   #12074
oPAULo's Avatar
Anyone know of a rear shock shaft that's the same as RB6? Just found a bent one and hoping to race tomorrow. Nobody around here carries Kyosho. Might have to try to straighten it....
oPAULo is offline   Reply With Quote
Old 06-05-2015, 11:55 AM   #12075
If I had to guess,
Possibly sometime after the worlds. Kyosho doesn't always get some stuff designed and produced quickly, albeit, there could be times when they should. But the time line is just a guess on my part. Who knows, they could have things already done up and ready to go and just not telling anyone so they can debut the stuff at the worlds. Just a thought.
J.Mikoliczyk
RB6 - MBX7R Eco
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 10-20-2017 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
