    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree15Likes
Old 05-10-2015, 01:52 PM   #11986
Trader Rating: 138 (100%+)
[QUOTE=Jpdanger;13986441]I dremeled the chassis sides flush and cut the sideguards so the battery can lie flat on the chassis and fit underneath the hold down brace. Otherwise, people use double sided tape, tape around the battery and chassis, or shim up the hold down brace and shelf (if you aren't going to dremel the sides of the chassis). I've even seen someone cut slits in the sideguards and use velcro straps.
There are so many tuning options for this car that the old saying "There are many ways to skin a cat" rings true. I've found sideways gives me more rear traction at the expense of steering because the battery CoG is further rearward than inline. If you're willing to cut up your car, the sideways option offers more weight tuning options since you're able to move the battery more forward/rearward whereas inline is limited to a couple inches by the motor or servo.
I hav not done it on my car, but on a friends car I did not like how it flung the rear around, and the lose of steering hindered me on smallish tight tracks. My wiring is perfect with my speed control behind the battery.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, B64D (Temporqary 4 wheel), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 05-10-2015, 03:10 PM   #11987
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Put the brass on the front and the car gets really good.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 05-12-2015, 07:51 PM   #11988
GIHOSU's Avatar
Speaking of the front, JTP RC just put up a reworked front shock tower. This explains Tebo's use of long shock ends up front. Even though I just picked up an RB6 from a buddy this has me thinking it may work well on my home track.
Cruizin with RC's in Waldwick, NJ... check it out!
KYOSHO - RB6.6 17.5 Turf ~ RB6 17.5 ~ RB6 ~ RZ6 Turf ~ RT6 Turf ~ SC6 17.5 ~ SC6 ~ SC6 Turf ~ ST-RR Evo.2E
TEKNO - SCT-410 ~ SCT-410.3
GIHOSU is offline   Reply With Quote
Old 05-12-2015, 09:44 PM   #11989
Jpdanger's Avatar
Link please! I didn't see anything on a new shock tower. Jared does reference using an older tower from an earlier version of the RB6. I would guess the longer ends are used since the shocks may be too short for the tower.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 05-13-2015, 08:14 AM   #11990
orangutanracer's Avatar
http://jtprc.bigcartel.com/product/r...on-front-tower
orangutanracer is offline   Reply With Quote
Old 05-13-2015, 09:10 PM   #11991
Jpdanger's Avatar
Originally Posted by orangutanracer View Post
Hmmm I just ordered one, so I'll let you what think.
Old 05-14-2015, 10:51 AM   #11992
nitro2be's Avatar
Originally Posted by K_King View Post
I tried the gear diff today, all machined internals, with the new cover. Felt really good tonight, didnt seem to drive any differently except it felt like it had more forward drive. Low speed felt fine and the high speed was pretty smooth as well.
King help me with this.im new to 2wd im running fully converted rtr to mid motor except the chassis and gear diff. Using 7.5t lrp with tebo 15 reedy setup.i put 3k in diff and this thing just does donuts, can't even make it down the straight. ?adjusting the slipper is where I'm confused because it's gear not ball diff.is it the same test, front wheels lift or since we're fix gear we have to do different? Please help me understand
nitro2be is offline   Reply With Quote
Old 05-14-2015, 12:51 PM   #11993
Does anyone know what the SP motor plate weighs compared to the stock motor plate? I race mod buggy, and prefer a heavier car. thanks guys.
cooper126 is offline   Reply With Quote
Old 05-14-2015, 02:56 PM   #11994
Default updated buggy
v2 version, 34301 seems like a new verision of the RB6 is soon out, BUT i downloaded the manual and the only upgrade are the new rear arms with 3 holes.
Or did I miss any? I was hoping new sideguards to try shorty sideways too
http://www.kyosho.com/jpn/support/in...IMA_RB6_IM.pdf
edit: Topmount of shocks seems to have got at flanged ball insted of the "just ball"
edit2: Gold rear springs too
/Patrik
RB-6.6
zx-6
RT-6
Heda is offline   Reply With Quote
Old 05-14-2015, 03:35 PM   #11995
I get mine tomorrow.
Old 05-14-2015, 03:44 PM   #11996
Yes. That's been updated which means kits probably will be as well. As for calling it anything else then an RB6 I doubt. What I would like to see as well is a flat chassis, and side guards that allow both configs without having to mill out the chassis.
Old 05-14-2015, 03:46 PM   #11997
Think it's 3 grams lighter then standard.
Tom87 is offline   Reply With Quote
Old 05-16-2015, 05:12 PM   #11998
Which shock tool is everyone using besides the one that comes in the box?
Old 05-16-2015, 05:55 PM   #11999
E73
E73's Avatar
This:
http://www.avidrc.com/product/5/acce...cessories.html
Use it to loosen only. Use finger pressure to tighten the seal cartridge.
E73 is offline   Reply With Quote
Old 05-19-2015, 07:01 PM   #12000
oPAULo's Avatar
Just picked up a used RB6 that is supposed to be here on time to race Saturday. All we've ever raced is SCT so all I have is standard stick batteries.
Will they fit in a mid motor setup or do I need to find some shortys?
I plan to run shortys or something else but I'm just wanting to get through the weekend until I figure out what I want.
oPAULo is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22968 Today 04:05 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
05PSD
