    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 04-28-2015, 11:23 PM   #11971
nitro2be's Avatar
Originally Posted by nitro2be View Post
what weight diff. fluid did you used in the gear diff?I just bought a 7.5 and wondering where to start with .3k 5k 7k?
If you read over a hundred pages u will find lots of your questions answered. 3k works great in gear diff.page 668 to 672.lol
nitro2be is offline   Reply With Quote
Old 04-29-2015, 09:32 PM   #11972
Jpdanger's Avatar
Originally Posted by ashxxx View Post
How is everyone holding in there shortly sideways and will this give more grip outside.
I dremeled the chassis sides flush and cut the sideguards so the battery can lie flat on the chassis and fit underneath the hold down brace. Otherwise, people use double sided tape, tape around the battery and chassis, or shim up the hold down brace and shelf (if you aren't going to dremel the sides of the chassis). I've even seen someone cut slits in the sideguards and use velcro straps.
There are so many tuning options for this car that the old saying "There are many ways to skin a cat" rings true. I've found sideways gives me more rear traction at the expense of steering because the battery CoG is further rearward than inline. If you're willing to cut up your car, the sideways option offers more weight tuning options since you're able to move the battery more forward/rearward whereas inline is limited to a couple inches by the motor or servo.
Personally, the sideways option is more visually appealing IMHO. I think it looks cleaner and easier to access the electronics. I tried the inline, but couldn't make my electronics fit without it being a spaghetti wire mess that was aesthetically nauseating.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 04-30-2015, 02:53 AM   #11973
Trader Rating: 115 (98%+)
I ended up just throwing a square pack in it it's pretty good on a blown out track little sluggish but easy to drive Car weighed 1674 with smc square and alum steering and hanger and brass front hanger . I think I'm going to take off the brass.
ashxxx is offline   Reply With Quote
Old 05-01-2015, 08:29 AM   #11974
cnelson3's Avatar
Trader Rating: 65 (100%+)
I just recently stuck a saddle pack back in my car as well. It's just easier to drive. It's hard for me to say it "feels" heavy because I went up in spring rates and it's almost as nimble as before it was at 1580. I'm at 1640 now. I'm still working on the setup but so far so good. Rear grip goes way up once you add the weight.
cnelson3 is offline   Reply With Quote
Old 05-02-2015, 10:11 PM   #11975
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
I tried the gear diff today, all machined internals, with the new cover. Felt really good tonight, didnt seem to drive any differently except it felt like it had more forward drive. Low speed felt fine and the high speed was pretty smooth as well.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 05-02-2015, 10:15 PM   #11976
Trader Rating: 137 (100%+)
What fluid?
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 05-02-2015, 11:11 PM   #11977
K_King's Avatar
Tried 3k. I want to try 4 and 5 also.
Old 05-03-2015, 11:22 AM   #11978
What spring and oil. Where u at. And where u now
Old 05-03-2015, 04:25 PM   #11979
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
Ashley,
What track?
Serpent,Sanwa,Fantom Racing
92zero.com,Lunsford Racing,AKA Racing
TXD Snake Skin Graphix
1armed1 is offline   Reply With Quote
Old 05-04-2015, 04:52 PM   #11980
nitro2be's Avatar
Default tebo ocrc reedy 15 setup ?
(Rear arm hole drilled narrow 17.5 from sway bar.) Is this for shock mounting hole ?
Old 05-04-2015, 07:26 PM   #11981
cnelson3's Avatar
white fronts and gold rears. I tried golds fronts as well but it was a little too much. 32.5 front and 30 rear. So far so good but right this moment, I'm running a sway bar set up that feels awesome. same weight without the saddle packs but switched to white rears and the pink sway bar. same oil as well.
Kyosho America
Peak Racing
Trackside Hobbies & Raceway - Milwaukee, WI
Old 05-04-2015, 07:28 PM   #11982
cnelson3's Avatar
Originally Posted by 1armed1 View Post
Ashley,
What track?
Trackside in Milwaukee
Kyosho America
Peak Racing
Old 05-05-2015, 05:05 PM   #11983
Trader Rating: 89 (100%+)
Anyone 3d print a battery tray for mounting the shorty sideways? I have a sketch but do not want to reinvent the wheel if its not needed.
dan-o is offline   Reply With Quote
Old 05-08-2015, 08:32 PM   #11984
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
ive read about the third hole being 17.5mm from where? anybody post a picture of what it looks like?
TEAM ASSOCIATED Rc10, rc10B6D ,FUTABA , TEAM ORION, KYOSHO RB6.
mdwaeracer is offline   Reply With Quote
Old 05-08-2015, 10:00 PM   #11985
Jpdanger's Avatar
From the sway bar hole. Kyosho sells an updated arm with the hole pre drilled. It's part number 713b.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
