    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 04-06-2015, 02:14 PM   #11896
M03Racer's Avatar
Trader Rating: 33 (100%+)
Thanks guys for the heads up it was a Nova spur and I already ordered a larger spur.
M03Racer is offline   Reply With Quote
Old 04-06-2015, 04:07 PM   #11897
SoCalMX's Avatar
Originally Posted by phillypete View Post
hmmmm....
First make sure the slipper is assembled properly. It can be a little tricky. Make sure all the washers and pads are in the proper places. While doing this have an experienced racer check your pads. You don't want them to look glazed. If they are a quick lap around some high grit sand paper will clean them up. Also check for build up the metal discs.
Next have an experienced racer check and adjust your diff. If it needs to be tightened you may want to run it in a couple of times (hold one wheel and apply 1/4 throttle, allowing the other wheel to spin freely for approximately 20 seconds) and check it again.
Finally do a slipper test on the bench. Place your buggy pointing away from you. While holding your radio in your throttle hand; hold one rear wheel firmly with your free hand and then firmly press down on the other rear wheel with base of the radio. Now give the throttle a firm blip. Don't hold it just a quick blip of full throttle. Note how high or if the front wheels lift off the ground. Also note any sounds that may result. A high pitched squeak is the slipper. A midrange "bark" is the diff. Another way to know if it is the diff or the slipper is to watch the reaction of racers near-by. They won't react to a slipper chirp, but a diff bark will send them into convulsions. Barking the diff is bad, one small bark won't kill it, but more than a couple will ruin a brand new diff. You want to see the wheels lift off the table by about 2" to start. Not enough lift and you'll find it difficult to accelerate rapidly, too much and the car will become difficult to drive.
Above all, don't be afraid to ask for help. I have come across very few racers who won't help if asked, but even less racers have the ability to tell that you are having difficulty with out you asking.
Had the guys at OCRC help me out & looks like my diff is shot! Time for my 1st ever ball diff rebuild.
EDIT- What all goes wrong in there? While I am in should I blow the whole thing apart and replace everything including cases? Or clean and re grease?
Losi 5ive-T monster
Kyosho RB6 mid...
Kyosho SC6 mid...
Kyosho RT6 mid...
SoCalMX is offline   Reply With Quote
Old 04-06-2015, 06:21 PM   #11898
Just an FYI, Amazon has the RB6 for $379.
-Ryan-
TLR 22 4.0SR
CTRJ is offline   Reply With Quote
Old 04-06-2015, 07:16 PM   #11899
M03Racer's Avatar
Originally Posted by CTRJ View Post
Actually you can get it at Amazon for $370.73 w/free shipping, but it ships from Japan.
Old 04-06-2015, 07:45 PM   #11900
jelly's Avatar
new plates, balls, thrust bearing. just clean the rest.
jelly is offline   Reply With Quote
Old 04-06-2015, 07:50 PM   #11901
SoCalMX's Avatar
Thanks Jelly! That was your 1000th post!
Losi 5ive-T monster
Kyosho RB6 mid...
Kyosho SC6 mid...
Kyosho RT6 mid...
Old 04-06-2015, 09:31 PM   #11902
3srcracing's Avatar
Trader Rating: 25 (100%+)
Well last minute tonight pulled out the wire cutters and the dremel and switched everything over to sideways. Going to try out tomorrow, kinda have high hopes for it!
I can pull wheelies in my basement now with my 17.5, seems like it has a lot more rear traction, which I think will help me. If I lose some steering I'll turn my dual rate up from 72% to 85-87%.
3srcracing is offline   Reply With Quote
Old 04-07-2015, 05:23 AM   #11903
Trader Rating: 137 (100%+)
Second race with the RB6. Tq and won stock buggy by a lap. Car is so good I'm not changing a thing. Same for my ZX6, and RT6. TQ and wins in both other classes.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 04-07-2015, 05:44 AM   #11904
Care to show me how you are running your battery?
Mattgee87 is offline   Reply With Quote
Old 04-07-2015, 07:02 AM   #11905
SoCalMX's Avatar
Second on the battery placement request! Also, where are you racing, was it OCRC? I am also still considering a RT6, is there a lot of cross compatibility between the B and the T?
Losi 5ive-T monster
Kyosho RB6 mid...
Kyosho SC6 mid...
Kyosho RT6 mid...
Old 04-07-2015, 07:32 AM   #11906
Other then chassis, arms, towers, and axles, both cars are indentical. It was at LRH which is still high bite SoCal clay. Truck would be even better at OC/RC, but I cant race Wednesday or Friday cause of school. Wish they would run again on Saturdays. I think the truck would be much better there cause its smoother, but LRH makes you drive better cause of the ruts
Old 04-07-2015, 07:51 AM   #11907
Here is how I did It. But kep in kind I do have rhe brass block so my weight us right where I want it. Could probably get rid of it in stock, but I like a very balanced car better then a light weight all of the place car.
Old 04-07-2015, 01:20 PM   #11908
MayorRC's Avatar
Quick question here, tried to search the thread but couldn't find an answer, but what's the advantage to running the steel RB5 axles (UM506) on the front? Seeing it on a few of the setups on Kyosho's site, but what's the reasoning? Thanks!
Kyle-Keenan.com | MayorRC.com | McKune Design | Hella Graphics | 2WDMod.com | Kyosho | Orion
MayorRC is offline   Reply With Quote
Old 04-07-2015, 07:08 PM   #11909
M03Racer's Avatar
Here is my set up. I will be running a mid battery set up. Some of the guys at the track ran rear battery set up last year and they where just a bit off balanced on the jumps so I figured to try a mid battery set up. Now I just have to test the car to see how it handles but the track is still closed here since it's still cold hope we will get better weather soon.
Old 04-07-2015, 07:47 PM   #11910
any concerns with traction w that setup?
glenng is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
