    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 04-04-2015, 07:36 PM   #11881
FallenAllDay's Avatar
Will the new hole in the rear arms be beneficial for mm on outdoor loose/ rough track conditions??
TLR 8IGHT 4.0, OS Speed, Sanwa M12s/Ko servos
KYOSHO RB6, Orion, Sanwa M12s/Ko servo
Powered by my wallet.
FallenAllDay is offline   Reply With Quote
Old 04-04-2015, 07:40 PM   #11882
3srcracing's Avatar
Trader Rating: 25 (100%+)
So is it really worth dremelling the chassis guards to run the battery sideways?
3srcracing is offline   Reply With Quote
Old 04-04-2015, 07:50 PM   #11883
Originally Posted by jpcopeland1 View Post
www.lapartshouse.com
Should be on the site tomorrow morning.
I just checked the site and do not see the Kyosho UM713B arms
Brandon Smith
fanfor18 is offline   Reply With Quote
Old 04-04-2015, 10:13 PM   #11884
mjbtaco's Avatar
I can tell you my own personal opinion next Friday when I get it back on the track. But I can say that when I tried the inline setup on my B5M I wasn't a fan.
mjbtaco is offline   Reply With Quote
Old 04-05-2015, 04:13 PM   #11885
Originally Posted by mjbtaco View Post
Switched the layout of my car and swapped in a normal size servo. Hopefully this helps.
What are you using to hold down the battery?
Mattgee87 is offline   Reply With Quote
Old 04-05-2015, 05:41 PM   #11886
Trader Rating: 137 (100%+)
They sold out very quickly.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 04-05-2015, 08:13 PM   #11887
M03Racer's Avatar
Trader Rating: 32 (100%+)
Can somebody help me with this. I got an RB6 from the for sale section on this forum during the winter and I just got around to setting it up. I got all the electronics set up and I never checked the spur until I took off the cover to install the motor and I saw this its a 66T spur with no markings whatsoever with a slipper I have never seen before I don't know who makes it. I guess the person I purchased this from ran 17.5T class since the spur is so small. Anyway can somebody tell me who makes this spur and can I get a larger size maybe a 72T or 82T since I will be running an 8.5T motor. The biggest pinion I have is a 28T and that still won't get close to this spur.
M03Racer is offline   Reply With Quote
Old 04-05-2015, 08:21 PM   #11888
racingdan's Avatar
it`s made by AVID
durango: DEX410v3 and v3.5 , dest210r ,dex210 ,desc410v3
kyosho: RT6 and ZX6
all tekin esc(rsx,rs gen2 and rx8
airtonic m11 with spektrum module
racingdan is offline   Reply With Quote
Old 04-05-2015, 10:35 PM   #11889
mjbtaco's Avatar
Double sided tape.
Old 04-06-2015, 12:38 AM   #11890
SoCalMX's Avatar
Looks just like the Schelle Racing Nova slipper ( http://www.amain.com/rc-cars/schelle...A25BoCtiTw_wcB )I just pulled out of mine. I could not get the thing set up and will be going back to stock.
Losi 5ive-T monster
Kyosho RB6 mid...
Kyosho SC6 mid...
Kyosho RT6 mid...
SoCalMX is offline   Reply With Quote
Old 04-06-2015, 03:55 AM   #11891
I love my nova slipper. I can't imagine what sort of issue you were having.
www.beachrc.com
phillypete is offline   Reply With Quote
Old 04-06-2015, 04:00 AM   #11892
mdowney's Avatar
Trader Rating: 21 (100%+)
You'll need to pick up a bigger spur gear if you're going to run an 8.5T motor. Order a new one from Schelle. The Novas are great. Amain also sells them.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 04-06-2015, 06:34 AM   #11893
SoCalMX's Avatar
Not sure as I am a bit of a novice, especially being I never dealt with a slipper. The car is WAY under powered and it has a Orion R10Pro ESC and a Reedy 7.5! Under any traction it seems to just slip out. I had a few locals try and adjust the slipper with no luck. Maybe it is not the slipper?
Losi 5ive-T monster
Kyosho RB6 mid...
Kyosho SC6 mid...
Kyosho RT6 mid...
Old 04-06-2015, 06:37 AM   #11894
mjbtaco's Avatar
could also be your diff. if the person was running a stock motor in it the diff is probably pretty loose.
Old 04-06-2015, 08:04 AM   #11895
hmmmm....
First make sure the slipper is assembled properly. It can be a little tricky. Make sure all the washers and pads are in the proper places. While doing this have an experienced racer check your pads. You don't want them to look glazed. If they are a quick lap around some high grit sand paper will clean them up. Also check for build up the metal discs.
Next have an experienced racer check and adjust your diff. If it needs to be tightened you may want to run it in a couple of times (hold one wheel and apply 1/4 throttle, allowing the other wheel to spin freely for approximately 20 seconds) and check it again.
Finally do a slipper test on the bench. Place your buggy pointing away from you. While holding your radio in your throttle hand; hold one rear wheel firmly with your free hand and then firmly press down on the other rear wheel with base of the radio. Now give the throttle a firm blip. Don't hold it just a quick blip of full throttle. Note how high or if the front wheels lift off the ground. Also note any sounds that may result. A high pitched squeak is the slipper. A midrange "bark" is the diff. Another way to know if it is the diff or the slipper is to watch the reaction of racers near-by. They won't react to a slipper chirp, but a diff bark will send them into convulsions. Barking the diff is bad, one small bark won't kill it, but more than a couple will ruin a brand new diff. You want to see the wheels lift off the table by about 2" to start. Not enough lift and you'll find it difficult to accelerate rapidly, too much and the car will become difficult to drive.
Above all, don't be afraid to ask for help. I have come across very few racers who won't help if asked, but even less racers have the ability to tell that you are having difficulty with out you asking.
www.beachrc.com
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
