    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-31-2015, 07:45 PM   #11851
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by nitro2be View Post
Hi, I have the rtr rb6 I bought last year.ive been upgrading it slowly. Servo, receiver, steering rack, turn buckles, shock caps, body,wing, now motor and esc..going LRP 8.5 and my question is being a gear diff what fluid would you run and any suggestions on slipper? I'm thinking 3 to 4k
I don't have any experience with a gear diff in the buggy but maybe someone else has. The only question I have at this time is what is the track like, loose or high bite? I would think that would play into the choice of what oil to use.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-31-2015, 10:31 PM   #11852
nitro2be's Avatar
IERC indoor clay med to high bite. Run sauced slicks in my d413 . I use this rb6 as a spare car and only ran it three times and it does great but slow.when I increase power I'm gonna need to play with diff and slipper .2x1.6 pistons,universal drive shafts, and using starter set up on 1st page.
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 03-31-2015, 10:40 PM   #11853
nitro2be's Avatar
I have read from page 150 to 323 so far and it's about when most are changing over to mm.
Old 04-01-2015, 02:34 AM   #11854
Trader Rating: 137 (100%+)
Yep. Especially if you hi go to IERC, OC/RC, SDRC, etc.....
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 04-01-2015, 01:47 PM   #11855
kyle3333's Avatar
Default Milled RB6 Chassis
Are there any companies or people out there selling milled RB6/RT6/SC6 chassis? I would think at this point there is a small market for that considering so many people run the sideways battery config.
Thanks.
JConcepts UpGrade RC
kyle3333 is offline   Reply With Quote
Old 04-01-2015, 02:34 PM   #11856
Thanks.
Don't you just milled out the side guards? The chassis isn't touched is it? If it is that's a sure fire no go for me. And I hope this isn't being done to try and make the car drive more like a B5M. That car was not as good for me.
Old 04-01-2015, 02:37 PM   #11857
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by jpcopeland1 View Post
Don't you just milled out the side guards? The chassis isn't touched is it? If it is that's a sure fire no go for me. And I hope this isn't being done to try and make the car drive more like a B5M. That car was utter crap.
Curious, how was it utter crap?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-01-2015, 03:59 PM   #11858
aloksatoor's Avatar
Trader Rating: 42 (100%+)
It sits a bit off the aluminum if you just mill sideguards. ARound 2 mm. So if you want it smack down low as possible you gotta mill. The folds on the sides cause the battery to be above.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 04-01-2015, 07:45 PM   #11859
kyle3333's Avatar
There are a couple reasons the chassis is milled. The first is to get the battery to sit properly in the car to get a lower center of gravity. The other reason is to give the chassis a bit more flex. There may be other reasons, but these the only two I'm aware of.
Old 04-01-2015, 10:37 PM   #11860
Yes... Those two reasons are legit, but is it necessary to mill it out to run this mod? I'm just saying I would not want to have to shave down the sides and worry about a tweaked chassis due to reduced strength.
Old 04-01-2015, 10:38 PM   #11861
For me, I meant to say. A lot of people like it, and I, sure are very happy. I was not really one of them. Getting my RB6 back was a breath of fresh air for me.
Old 04-01-2015, 10:40 PM   #11862
Picked up 4 sets of the new rear arms with new hole. Have not used them yet, what should I expect out if them?
Old 04-01-2015, 11:00 PM   #11863
mjbtaco's Avatar
+ YouTube Video
https://www.youtube.com/watch?v=9SiuXCe42Jg
mjbtaco is offline   Reply With Quote
Old 04-02-2015, 12:05 AM   #11864
HSV427's Avatar
Trader Rating: 21 (96%+)
Can you pls post the part number off the new arms. TIA
XRAY XB4 15, XRAY XB4 16, XRAY XB2, YOKOMO B-MAX4 III FACTORY KIT, YOKOMO YZ4, YOKOMO YZ2,KYOSHO RB6, TAMIYA TRF503, TAMIYA TRF201XMW, TAMIYA TRF 211XM
HSV427 is offline   Reply With Quote
Old 04-02-2015, 12:17 AM   #11865
Jinggoy's Avatar
Kyosho UM713B
i got mine from Pro Shop Futaba Japan
http://www.pro-s-futaba.co.jp/store/...ducts_id=35635
Jinggoy is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
