    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 03-18-2015, 10:53 AM   #11791
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by Chris Brown View Post
I want to use different ball studs/cups because I hate popping off the ball cup to make adjustments. Has anyone switched theirs out for another company? I was gonna use associated but their quality sucks so I was thinking about Yokomo. Does anyone have any input?
I picked up a set of Lunsford ball studs and then used my tire punch to make the holes in the Kyosho ball cups so I could get the wrench into the ball stud. No issues so far.
The B5 series ball studs are bigger than the B4 so they have new ball cups too. From what I have seen, they are pretty strong too and guys/girls are putting them on their 44.3's.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-18-2015, 05:17 PM   #11792
Potoczak's Avatar
Trader Rating: 111 (100%+)
I actually used Losi 22 series ball studs on my rb6 and then just used a tire punch to make a hole in my stock ball cups. Works great and cheap.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 03-23-2015, 12:31 AM   #11793
Trader Rating: 115 (98%+)
whats the front block do 25 or 30 degree.
ashxxx is offline   Reply With Quote
Old 03-23-2015, 03:35 AM   #11794
Both. It depends on which way it's put on. I haven't seen anyone use the 30 degree side.
potatobed409 is offline   Reply With Quote
Old 03-23-2015, 07:21 AM   #11795
mjbtaco's Avatar
Picked up a used rb6 that was in pretty rough shape this weekend. I've already replaced the front/rear arms. Installed the clear x-rings. New bulkhead and front shock tower. New sideguards and top deck are on order along with the aluminum rear arm mounts. Also ordered the schelle slipper and top shaft for it. Gonna be racing stock with it.
Almost done wiring it up just waiting for the new side guards to come in. I also swapped out the stock ball cups and turnbuckles for some with holes in the ball cups. I'll be swapping over the ball studs today.
mjbtaco is offline   Reply With Quote
Old 03-24-2015, 06:13 AM   #11796
yodace's Avatar
R/C Tech Charter Subscriber
Is it better to run a sideways battery or inline battery when you race stock?
yodace is offline   Reply With Quote
Old 03-24-2015, 06:17 AM   #11797
Trader Rating: 81 (100%+)
I ran it both ways and didn't notice a drastic difference either way. That being said, all the fast guys at my track are running it in-line
dpcardoza is offline   Reply With Quote
Old 03-24-2015, 06:23 AM   #11798
mjbtaco's Avatar
i really couldnt tell you. i've never driven an rb6 before. im coming from a b5m and i always ran the batter sideways. but most rb6's i see in at my local track run inline setups.
Old 03-25-2015, 06:51 AM   #11799
mjbtaco's Avatar
So i finally got my car ready to go and i weighed it. this is completely rtr with 2.2 tires front and rear. only light weight parts i know of for sure installed on the car are pucks and schelle top shaft and nova slipper. My question is, are these cars always this light? Im coming from a b5m that weighed 1535g with a ton of light weight parts installed...
Old 03-25-2015, 06:53 AM   #11800
3srcracing's Avatar
Trader Rating: 25 (100%+)
Mines 1550 with no light weight parts either at all. So I would say it's just a light car.
3srcracing is offline   Reply With Quote
Old 03-25-2015, 07:17 AM   #11801
mjbtaco's Avatar
Just not used to my car being so light lol. it was A LOT of work to get my b5m down to even 1535g lol
Old 03-25-2015, 02:37 PM   #11802
rpboggs1's Avatar
Trader Rating: 19 (100%+)
If you ever get inspected at the track, I'm pretty sure the roar minimum is 1499 grams. Nice looking buggy!
rpboggs1 is offline   Reply With Quote
Old 03-25-2015, 05:38 PM   #11803
can you get us a picture of your car with the body off and on the scale. Your car is 100g lighter than i could ever get mine. What chassis are do you have?
CaseyD is offline   Reply With Quote
Old 03-25-2015, 06:38 PM   #11804
Trader Rating: 137 (100%+)
I have one almost new B5M with all the goodies on it, and it's still a tank. Another Purpose built (almost) a lightweight b5m (no aluminum anywhere) and it's not even finished, and nowhere close to being in the 1500s. Should sell em all and run a stock RB6 lol....
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 03-25-2015, 06:42 PM   #11805
Is that Kevin Smiths old car? It does have pucks installed.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Yesterday 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Kkrazy
