    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 03-12-2015, 03:54 PM   #11776
Originally Posted by K_King View Post
Yup. 18mm from the sway hole I believe.
Is there a pic that shows the new arms? Did they do 18 and 17.5mm?
CaseyD is offline   Reply With Quote
Old 03-12-2015, 04:46 PM   #11777
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
From my understanding they made the new hole on the 2 hole side to be 18mm and on the 1 hole side the new inside hole will be basically the half distance of the other side.
K_King is offline   Reply With Quote
Old 03-12-2015, 05:40 PM   #11778
Trader Rating: 55 (100%+)
I do see a revision of the rear arms coming out this month, maybe they will have the hole drilled already
Edit just read the other post.
Speedychris22 is offline   Reply With Quote
Old 03-13-2015, 10:06 AM   #11779
cnelson3's Avatar
Trader Rating: 66 (100%+)
The hole between the 18 is what I have been running along with the brass toe block. I'm excited for these to come out.
cnelson3 is offline   Reply With Quote
Old 03-13-2015, 10:17 AM   #11780
K_King's Avatar
The inside hole on the current arm is what you run? It's not bad either. I will go out there sometimes.
Basically it will be like this.
2-4
1-3-5
4 and 5 will be the new hole. 4 will be a nice option to try also.
But once the arms come out we can measure the actual distance of hole 5.
Old 03-13-2015, 12:05 PM   #11781
cnelson3's Avatar
2-4
1-3-5
Actually 20mm from the sway bar hole. I'm guessing it will be the hole next to the old 2 hole considering I could only drill the "20" hole on that side. It supports the back of the car better and you don't loose steering. Lands a little better (in my opinion) and you don't sacrifice much rear grip. To me at least, it's a much more balanced car.
Old 03-13-2015, 01:36 PM   #11782
Well whatever the distance it's cool to see such a large company listen the "people".
Old 03-13-2015, 02:53 PM   #11783
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Sumo Racing now do a Graphite Battery Brace w/hold down.
eBay - Sumo Racing RB6 Battery Brace.
Drift_Buggy is offline   Reply With Quote
Old 03-14-2015, 09:50 AM   #11784
alex4r's Avatar
Send a message via AIM to alex4r
Just got an email saying the arms are in stock at Kyosho America.
Alex Kennedy
Shifty's RC
Sanwa M12S | Kyosho RB6.6 | Kyosho ZX6.6 | Kyosho RT6 | Kyosho MP9 TKi4
alex4r is offline   Reply With Quote
Old 03-14-2015, 06:31 PM   #11785
Trader Rating: 90 (100%+)
I have plenty of 1.6 AE pistons ....anybody running the associated pistons? Any issues?
dan-o is offline   Reply With Quote
Old 03-14-2015, 10:48 PM   #11786
A lot of the guys at my track including myself will run the AE piston to mess with set up but then buy the Kyosho pistons once you figure it out. The only "issue"'is the AE pistons aren't as thick so you'll get a little click in your shock as it goes up and down. If you just leave you are getting a tiny bit of free play before the piston starts working. I would imagine only the top top racers could really notice while driving. Some guys have thrown axle shims between the piston and E clip and it takes care of the problem.
Old 03-15-2015, 05:44 AM   #11787
Thank you!
Old 03-17-2015, 10:45 AM   #11788
Lonestar's Avatar
what blank pistons do you guys use to build your own?
thanks!
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 03-17-2015, 11:32 AM   #11789
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
thanks!
Paul
I use the Kyosho ones, W5303-08, because they have little dimples in them which should prevent the bit from walking around the face of it when I try and drill.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-18-2015, 11:33 AM   #11790
Trader Rating: 18 (100%+)
I want to use different ball studs/cups because I hate popping off the ball cup to make adjustments. Has anyone switched theirs out for another company? I was gonna use associated but their quality sucks so I was thinking about Yokomo. Does anyone have any input?
Chris Brown is offline   Reply With Quote
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Yesterday 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
