    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0į/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 02-27-2015, 12:13 PM   #11761
Tebo had this to day about it.
Something is bound up in your suspension. Take your shocks off, and give it the hang test. Hold your car on its side, in the air, with shocks off. Your arms should swing freely when you lightly rock your car. If they donít, something is bound up. If thatís not it, then your shock o-rings are swollen and tight. Rebuilding your shocks, did you put in new o-rings, or just replace the oil?
Chansharp318 is offline   Reply With Quote
Old 02-27-2015, 05:07 PM   #11762
E73
E73's Avatar
I like that suggestion. Got the rear end fixed...was binding where the shock meets the arm (2mm screw was secured too tight). I'll try Tebo's suggested technique with the front which hasn't completely resolved. To answer your question, everything in the shock was replaced with new as well as all the geometry: arms, blocks etc. Thanks for your help.
E73 is offline   Reply With Quote
Old 02-28-2015, 08:27 AM   #11763
For me I didn't replace the orings. So that could be the problem and haven't had time to check binding. Plan to do that today at the track.
Old 03-02-2015, 02:58 PM   #11764
killer501872000's Avatar
Trader Rating: 55 (100%+)
? i have an rb6 on the way and need to know the rear width with tires on, i am making it an mod dirt oval and want to get an body ordered, but need to know how wide it is.
thanks mark REALLY NO ONE!
killer501872000 is offline   Reply With Quote
Old 03-03-2015, 01:32 PM   #11765
BQRacer's Avatar
Trader Rating: 29 (100%+)
Wont have my K springs in time for the weekend. What AE or Losi spring would be simlar to a pink front spring ?
Jasper
My Sponsors Are Visa and Mastercard
BQRacer is offline   Reply With Quote
Old 03-07-2015, 05:47 AM   #11766
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
^^^^ not sure on the springs. Xgear handle so much better than the others so I never tried them.
Is it worth trying the sideways Lipo mod? Currently I still run motor, inline shorty, esc, servo. I like it but feel I can't push it as hard as I would like on exit.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 03-08-2015, 09:04 PM   #11767
Trader Rating: 115 (98%+)
new here but what front and rear wheels work for the rb6 switching over the the 22 2.0 pile
ashxxx is offline   Reply With Quote
Old 03-08-2015, 09:13 PM   #11768
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Anything that will fit a B5.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 03-08-2015, 10:06 PM   #11769
Losi rears won't work then.
Old 03-09-2015, 10:20 AM   #11770
alex4r's Avatar
Send a message via AIM to alex4r
They will, but they don't give you much room for a standard wheel nut. When I use my 22 rears I use these: http://www.amain.com/jconcepts-4mm-l...lack-4/p273896
Alex Kennedy
Bellgate Distributors | Highest RC
Sanwa M12S | Kyosho RB6.6 | Kyosho ZX6.6 | Kyosho MP9 TKi4
alex4r is offline   Reply With Quote
Old 03-10-2015, 06:42 AM   #11771
Moderator
Posvar's Avatar
I also run the Jconcepts low profile serrated wheel nuts along with Avid HD axles which are a little longer. That combo works well and you get a full nut on the axle.
Old 03-10-2015, 02:49 PM   #11772
will the j concepts bellcrank work with the exotek rack
Old 03-10-2015, 02:58 PM   #11773
Moderator
Posvar's Avatar
It should. Yes
Old 03-12-2015, 02:18 PM   #11774
cnelson3's Avatar
Trader Rating: 65 (100%+)
UM713B. New rear arms! Check them out on the Kyosho America web site. 2 new holes!
cnelson3 is offline   Reply With Quote
Old 03-12-2015, 02:27 PM   #11775
K_King's Avatar
Yup. 18mm from the sway hole I believe.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
