    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 02-25-2015, 06:42 AM   #11746
yodace's Avatar
R/C Tech Charter Subscriber
I am running tebo's fastlane setup with the battery sideways is there something, I could change when he track loses grip? I am using electrons
yodace is offline   Reply With Quote
Old 02-25-2015, 02:31 PM   #11747
E73
E73's Avatar
Originally Posted by Chansharp318 View Post
So just rebuilt my shocks. Put pink in the front. Gold In the rear. 32.5 all the way round and medium ends all the way around. And 2x1.6 pistons all the way around. Still no difference. My collars are all the way to bottom of the threads all the way around. I just don't get it. Bout to just say fuck it an run it lol the rear barely even bounces back. 24mm ride heights
Running into the same problem. Rebuilt the shocks w/ new shafts, seals & spacers, pistons, oil (35 front 30 rear), ball ends & springs (white front & rear). Ride height 24 front 23 rear. Shock shaft length 20 front 27 rear. No ballast. Setup MM. Shorty battery. Shock top 3rd hole in & stock inner hole on the arm. Shock collars are 80% down on the shock body. Even if I wanted 24mm of rear ride height the collar would be buried. I'm out of ideas. Thoughts?
Buggy runs great as is but heard excessive preload stiffens the ride.
E73 is offline   Reply With Quote
Old 02-25-2015, 03:03 PM   #11748
aloksatoor's Avatar
Trader Rating: 42 (100%+)
For the fronts it seems ok to be at that preload. What shock ends for rears? short medium or long. Most setups run long for rears with stock rb6 rear arms.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 02-25-2015, 04:53 PM   #11749
E73
E73's Avatar
I knew I forgot something. Stock ends: medium front & long rear.
Old 02-25-2015, 04:55 PM   #11750
3srcracing's Avatar
Trader Rating: 25 (100%+)
Mine's about the same.. With associated whites.. So with everyone having that problem, I'm going to assume it's right.
3srcracing is offline   Reply With Quote
Old 02-25-2015, 04:55 PM   #11751
aloksatoor's Avatar
No binding in the suspension as well? Like with shocks removed, car on stand, the arms falls smoothly and dont stick correct?
Old 02-25-2015, 05:26 PM   #11752
E73
E73's Avatar
No binding in the geometry. Shocks were bled properly: no air-rebound/no suction.
Just thought of something...could the screws that secure the shock to the arm be too tight and cause binding? If so, not sure why it would happen in the front as well.
Could be battery weight? Running a Fantom Racing 2s 4500mAh shorty...
Old 02-25-2015, 10:51 PM   #11753
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Check both the top and bottom shock mounts. Loosen them up just a tick. Might do the trick. My shock collars aren't that low, but seen a couple locals have the same issues.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 02-26-2015, 08:42 AM   #11754
Droop is probably wrong I tested this last night. With the long rear shock ends screwed all the way in will leave about 24mm of shaft exposed. If u try to set ride height at 23/24 your collars will be way down on the bodies. Same goes for the front with medium ends screwed all the way in gives the same result. Hope this helps...
Kyosho / Orion / AKA
Rgonzalez is offline   Reply With Quote
Old 02-26-2015, 01:12 PM   #11755
My exposed shafts are set to 19mm in front and 28mm in back..
Chansharp318 is offline   Reply With Quote
Old 02-26-2015, 02:45 PM   #11756
pumpkinfish's Avatar
Hey guys, quick question. I recently purchased an RT6 and put Tebo's CRCRC setup on it and it is an animal. My Yokomo YZ-2 and B5m have never felt like this. Would the RB6 have a similar feel to the truck or it is a bad comparison? If I could get a buggy to feel like the RT6 I would be so happy!
pumpkinfish is offline   Reply With Quote
Old 02-26-2015, 04:42 PM   #11757
E73
E73's Avatar
That was it, at least for the rear. Took the spring off and tested down travel with the screw both tight and loose. When tight, the arm (with tire mounted) didn't even descend. Loosened it 1/2 turn and it went down smoothly. Shock collar went up 3mm on the shock body from where it was.
Could not recreate the same with the front, however. Might just be my shock position: inner hole on the tower & outer hole on the arm. Thanks for the help!
Old 02-26-2015, 07:24 PM   #11758
Glad it worked out for ya,
Pretty amazing how something so simple can often be the culprit of so many headaches.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Old 02-27-2015, 06:16 AM   #11759
3srcracing's Avatar
Geez, maybe looking at alternatives for gearing in 17.5.. Usually I am geared 33/69.. But it seems on this layout it's getting really hot.. Like 160-180+. It's a fast layout (lots of straight away, and short run up to jumps.
Facebook link VV (dont know why it looks like a weird link).
https://scontent-sjc.xx.fbcdn.net/hp...8c&oe=558E6209
How would you guys gear?
Old 02-27-2015, 11:45 AM   #11760
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
What motor?
Team Kyosho (RB6, RT6, ZX6 & SC6)
Team Orion R10.1 Pro
Team Orion Touch Duo Charger
Team Orion Pro Carbon 100C Batteries
motorfinger is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22940 Today 03:24 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
