    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 02-15-2015, 01:50 PM   #11686
3srcracing's Avatar
Trader Rating: 25 (100%+)
Without getting to scientific on Zach rogers setup what does the third hole do?
I recently went back to the standard 2hole in the arm and it made the car better.
What conditions would the 3rd hole be better/or what does it do?
3srcracing is offline   Reply With Quote
Old 02-15-2015, 03:35 PM   #11687
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
It makes the shock softer
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 02-15-2015, 10:27 PM   #11688
3srcracing's Avatar
K..
So that gives the car more rear traction, but gets unstable faster.. Right?
K, then going to a shorter link gives the car more rear traction and helps it square up faster. So I did this, but did I basically cancel out that when i added a ballstud washer under the rear ballstud?
Old 02-16-2015, 08:46 AM   #11689
Trader Rating: 23 (100%+)
Originally Posted by 3srcracing View Post
K..
When you soften the rear it will make the car more responsive but also give it more traction and less overall steering. Depending on which side you placed the washer, a more level link or longer link will roll more. A shorter link should give more straight line traction but if you are trying to lock in the rear go longer. 1 washer under the ballstud is a minor adjustment as opposed to a longer link, major adjustment.
chevmaro is offline   Reply With Quote
Old 02-16-2015, 06:38 PM   #11690
K_King's Avatar
So I was thinking about stuff to try on the car and noticed the AE guys run limiters. I saw a buddy of mine's shock and saw that their pistons go to the top of the shock body, I'm not sure why but with our car it doesn't appear to be the case.
When I took mine apart I was running 19mm shaft exposure up front with long shock ends and 25.5 rear with long shock ends (100.5mm total shock length).
I added 1mm to the front and 2mm to the rear with the same amount of droop and was able to get the piston a tick higher. They dont hit the caps, but Im curious what this will do to the car.
Old 02-17-2015, 12:31 AM   #11691
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
Kevin,
I run 1mm internal spacers in my shocks. Partly a carry over from the 1/8th side. The theory Paul King gave me was that at full down travel, there's still some oil left under the piston so there's less of a chance the shock would feel inconsistent or get an air gap/flat feel when the oil has to go back through the piston. At least I think I remember that right. Been a while since I got that tip from Paul for the 1/8th shocks. I'm not sure if it helps or not, but I still build my shocks the same way.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 02-17-2015, 07:00 AM   #11692
A couple of my friends use an extra O ring so that it acts like a bump stop.
scoobyrs25 is offline   Reply With Quote
Old 02-17-2015, 07:02 AM   #11693
rosko's Avatar
I run my rb6 in mm tried the sideways lipo didn't like it..which way does most prefer to run electronics
Inline for indoor clay? Running mod. Esc in front of back
rosko is offline   Reply With Quote
Old 02-17-2015, 07:50 AM   #11694
I run stock so it might not be the same, I prefer ESC in front of the battery with a shorty up against the motor. I have tried the ESC in front of the motor. They feel very similar but I find it necessary to add weight when the ESC is behind the battery.
Old 02-17-2015, 07:57 AM   #11695
subzero2k's Avatar
Originally Posted by tobamiester View Post
Hard to say, alot of variables. I run a 23T with an 8.5.
Hi,
Thx i tryed it and it was good. Motor had 60C so there is room for more, but on the small track it was enought for me.
The only thing, i had Grip rolls, so i switched to the hardes Avid springs. It was the first time for me driving a 2wd. It was so much fun.
Got my gear diff today. Do you guys have suggestions what oil is good to start on high grip? Is it like the touring car 1k - 2k?
Greetings
Offroad: Kyosho MP9e TKI, Kyosho MP9 TKI3, Kyosho RB6
Onroad: ARC R10 2013, Schumacher Supastox, Tamiya M05 Vers.2 Pro, Sakura D3 CS
(Tamiya TT01, TA03R, R.I.P XD)
subzero2k is offline   Reply With Quote
Old 02-17-2015, 12:53 PM   #11696
Trader Rating: 91 (100%+)
Hi i am looking for a couple parts to piece together an RB5. if anyone has a motor plate and slipper plates left over from upgrading please shoot me a pm. Thanks, Eric
Just leave him alone, he knows what he's doing!
Eric Tomczyk is offline   Reply With Quote
Old 02-18-2015, 03:28 PM   #11697
3srcracing's Avatar
c-in/c-in vs d-in/d-in..
Whats the difference, which one for a medium wet/moist surface?
Old 02-18-2015, 03:32 PM   #11698
K_King's Avatar
Din in narrower which will give the car more roll, which can be more grip but not always.
Old 02-18-2015, 04:05 PM   #11699
3srcracing's Avatar
So C in makes it wider.. Which means less roll/traction?
Which would you go?
Not like thats an easy change after you put your car all back together unforutanetly.
Old 02-18-2015, 06:45 PM   #11700
K_King's Avatar
Go as narrow as your traction allows. It's actually pretty easy to change out. You can get both out with 6 screws.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Yesterday 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
