    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 10-06-2012, 08:40 PM   #1156
cnelson3's Avatar
Trader Rating: 65 (100%+)
Originally Posted by t8rtot View Post
I think the t-nut for my diff wasn't included.. Only bag left is the shocks and I've looked thru them.. Any other brand that will fit for now?
I'm contacting Kyosho America, but I want to get this thing out of the living room today
the blue tamiya diff nut is awesome. all aluminum and never gets stuck in the outdrive.
cnelson3 is offline   Reply With Quote
Old 10-06-2012, 09:01 PM   #1157
gelshocker's Avatar
Wouldn't you need to run the Tamiya screw and thrust washers as they are different to K? I bought some TRF HC thrust balls and the washers need a thinner screw. This is for the 201 and ff03
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 10-06-2012, 09:06 PM   #1158
gelshocker's Avatar
Originally Posted by SAGISI View Post
Went a little different route and made the window one piece instead of two. What do you think?
Very nice sir. You'll excuse me if I copy the idea. Would match my bulldog rb5 and fit in the arsenal. Cheers,
Kyosho RT5 | RB6
Old 10-06-2012, 09:45 PM   #1159
Trader Rating: 137 (100%+)
Can I send you my spare body to be painted That looks awesome. Right now Im stuck on all white due to time constraints. That paint job would look killer black/white/purple/ and some yellow.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-06-2012, 09:50 PM   #1160
Originally Posted by C_Money View Post
Was thinking of getting this buggy but I race stock normally. I hav a ton of money tied up in my rb5 and it's awesome. Do you think this is more of a mod car Cause of its weight?
Nope, my RB6 is fast as hell with a 70 tooth Losi spur and 33 tooth pinion (getting colder outside so peg that timing on the motor), was pulling on B4's all night long last Wednesday. This car isn't a DEX210 which is impossible to get going in stock. Plus it's so smooth even if your losing a bit of ground on the straight's you'll make it up in the infield cause the car is so much better balanced then anything else on the market. I can point and shoot with no spinout in the rear and plenty of on and off power steering. This was on a track with brand new tires, closed cell inserts, and no barely no break in time. Track was hard as a rock, everyone was spinning out at the end of the small straight that goes into a 180 degree turn, my RB6 just whipped around it like it wasn't there.
Old 10-06-2012, 09:51 PM   #1161
cnelson3's Avatar
I ran one on my rb5 a few months (maybe a year) ago. fit snug, worked exactly like it should have. it may not have been from the 201. I saw it on the rack and tried it on the diff screw and it worked perfect. it was definitely a diff nut and it had a diff screw in the bag. never used the screw.
Old 10-06-2012, 10:48 PM   #1162
gelshocker's Avatar
Cheers, it's good to know we have options.
Kyosho RT5 | RB6
Old 10-06-2012, 11:03 PM   #1163
Old habits die hard, but has anyone used the x-gear grease and lube instead of AE grease and lube? And is it better? My diff is unbelievably smooth but if the x-gear is better i'll tear it down and rebuild before I take it out again.
Old 10-06-2012, 11:25 PM   #1164
Trader Rating: 22 (100%+)
I had the same experience with my rb6 today running 17.5.
took 3rd unfortunatly but set tq for the day in a class against b4.1's, ran a d3.5 69/31 with timing cranked.
I took 3rd which was completely my fault had a few bobble's.
if anyone's on the fence about buying one, pull the trigger its worth it
noproblems209 is offline   Reply With Quote
Old 10-06-2012, 11:29 PM   #1165
Did the diff nut look like this?
Kyosho Ultima RB6 & RB6.6 Car Thread-%24-kgrhqv-pse8wvgylzrbpivotc-mg%7E%7E60_3.jpg
Old 10-06-2012, 11:30 PM   #1166
took 3rd and set tq for the day in the class against b4.1's, ran a d3.5 69/31 with timing cranked. I took 3rd which was completely my fault had a few bobble's.
And how.....
Old 10-06-2012, 11:49 PM   #1167
And how.....
should have been more clear, you had said pretty much said everything i was going to about how the car drove...
Old 10-06-2012, 11:54 PM   #1168
Cant wait to see what they do with the new Stadium Truck and Short Course. Both supposedly based off of the RB6 platform.
Old 10-07-2012, 05:30 AM   #1169
gelshocker's Avatar
Oh yeah, this is for the TA06
Kyosho RT5 | RB6
Old 10-07-2012, 06:01 AM   #1170
i hope so, they they've hit a home run this time.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Today 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
