    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 02-04-2015, 07:15 AM   #11626
Originally Posted by Chansharp318 View Post
Hey guys hoping someone could shed some light.. so I recently replaced the out drives on my diff. No big deal got it all back together and adjusted correctly. ( i think) Then started the problem. . I've been eating through spur gears..the first one broke the pinion too where the set screw goes in. Replaced it with a team assosiated 26t. Seemed noisy still. And have now eaten thru 2 more spurs adjusting slipper and just trying to get it all to quiet down. I'm using the paper method to set mesh. And I dont know what it could be unless the top shaft is bent or the actual motor shaft is bent. Idk any ideas?
I had this problem too. I'm still not sure what caused it, but I replaced everything including the motor plate and housing. No issues since then.
www.beachrc.com
phillypete is offline   Reply With Quote
Old 02-04-2015, 07:19 AM   #11627
tobamiester's Avatar
Trader Rating: 279 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Originally Posted by subzero2k View Post
Hi.
Ive got my kit today. What is a good pinion to start.
I plan to use a 8,5t on a high grip carpet track.
Greetings
Hard to say, alot of variables. I run a 23T with an 8.5.
tobamiester is offline   Reply With Quote
Old 02-04-2015, 07:40 AM   #11628
Scrad's Avatar
Trader Rating: 15 (100%+)
Chansharp, This may sound stupid, but make sure all your bearings are in the diff case and that they are good. Somehow I just recently must have had a bearing fall out while putting a diff back together.
Scrad is offline   Reply With Quote
Old 02-04-2015, 08:19 AM   #11629
MrHistory's Avatar
Got car together with Zach Rogers setup. Need to know a starting ride height for high grip track with small jumps.
I used the long shock ball ends on Rr shocks as in the sheet but really need to back the spring adjuster way up to lower rearend. Should I try the medium shock ball ends?
MrHistory is offline   Reply With Quote
Old 02-04-2015, 09:31 AM   #11630
Default Rear wheels, EVO vs Stock?
I'm hoping someone can shed some light: I bought a few spare wheels (and tires/inserts), and got the "EVO" style rear wheels from AKA which are listed as Kyo compatible. I went to track yesterday to put them on, and noticed that the axle doesn't stick out far enough past the wheel for the nut to fully seat. I took a closer look at the stock wheels that came with the kit and noticed the center is recessed allowing the nut to be flush with the outside of the wheel, and the nut to be fully seated on the axle. Can anyone confirm if they use the EVO wheels and have solved this problem? Or should I only get the stock Kyosho wheels (and do the stock wheels work with EVO tires)?
Thank you for your patience with this newbie to buggy racing.
Jgins13 is offline   Reply With Quote
Old 02-04-2015, 09:58 AM   #11631
aloksatoor's Avatar
Trader Rating: 42 (100%+)
http://www.avidrc.com/product/5/acce...cessories.html
or get low profile serrated lock nuts. I would go with #1 for security (I myself just avoid any other wheels than kyosho).
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 02-04-2015, 12:03 PM   #11632
ThePanda's Avatar
Trader Rating: 64 (100%+)
Yes on serated locknuts. A cheaper option are the Durango ones. 10 for only a few bucks.
ThePanda is offline   Reply With Quote
Old 02-04-2015, 07:12 PM   #11633
Trader Rating: 81 (100%+)
Question for those running the v2 rear hubs. Are you guys running the inserts and smaller bearings or just running the larger bearings?
dpcardoza is offline   Reply With Quote
Old 02-04-2015, 09:00 PM   #11634
rosko's Avatar
Just order the rb6 going to b running mm on indoor med to high bite clay. R the stock piston worth trying?
rosko is offline   Reply With Quote
Old 02-04-2015, 11:57 PM   #11635
FallenAllDay's Avatar
Do these fit the rb6 http://www.amain.com/jconcepts-4mm-l...lack-4/p273896
Had the avid setup and the clamping hex fits poorly and binds up the drivetrain, tried shimming it and still no success, save yourself 20-30bucks and get some serrated wheel nuts.
TLR 8IGHT 4.0, OS Speed, Sanwa M12s/Ko servos
KYOSHO RB6, Orion, Sanwa M12s/Ko servo
Powered by my wallet.
FallenAllDay is offline   Reply With Quote
Old 02-05-2015, 01:22 AM   #11636
You can also run these axles instead, http://www.kyoshoamerica.com/Wheel-S...cs_p_4618.html use these to get the correct hub spacing, http://www.kyoshoamerica.com/Aluminu...u_p_10868.html
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Old 02-05-2015, 05:55 AM   #11637
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
I have the avid axle set up on my rb6 and it works great. The longer axle allows me to run any wheel and they have lifetime replacement!
I did notice that they bind up like all hubs when you forget the gold spacer between the bearings.
I run the serrated nylocks from traxxas. Cheap and they work great
Jaz406 is offline   Reply With Quote
Old 02-05-2015, 06:40 AM   #11638
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I ran the smaller bearings until I was able to get my hands on the larger bearing. For me, the larger bearing seemed to last longer that is why I went with that size.
If you can I would get 1.6mm x 2 and the 1.4mm x 3 hole pistons when you can. You can use the kit pistons but I think you will find the car not having enough pack in the shocks. You could try and compromise with heavier oil but even that has some drawbacks.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-05-2015, 09:48 AM   #11639
rosko's Avatar
Ok thanks I did order those pistons with the kit so I'll just put the 3h1.4 in the front and the 1.6 n rear. Not going to try the sideways lipo thing yet I will b running mod. just not sure if I want to go servo, esc,lipo, motor or servo lipo, esc motor....which one gives more rear bite or is it not much difference?
Old 02-05-2015, 11:12 AM   #11640
Does anybody know if the associated avid 12mm shock tool works on the kyosho shocks to bleed the shocks?
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Yesterday 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
