    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 02-01-2015, 08:22 PM   #11611
cnelson3's Avatar
Trader Rating: 65 (100%+)
Originally Posted by K_King View Post
Anyone have success running 25+4 caster?
it's all I run.
Kyosho America
Peak Racing
Trackside Hobbies & Raceway - Milwaukee, WI
cnelson3 is offline   Reply With Quote
Old 02-01-2015, 08:28 PM   #11612
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Have you tried 25+0?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 02-02-2015, 12:23 AM   #11613
Camp-Dog's Avatar
Trader Rating: 20 (100%+)
Originally Posted by cnelson3 View Post
it's all I run.
What surface and traction level do you run on?
Do you have any video?
Camp-Dog is offline   Reply With Quote
Old 02-02-2015, 06:17 AM   #11614
hacker's Avatar
Trader Rating: 140 (100%+)
Default alu hubs V2 0*
I had aquired a 2nd hand rb6 and its in RM and has the right hubs on left and vice versa. Is this normal? Why did he/she do that?
hacker is offline   Reply With Quote
Old 02-02-2015, 08:38 AM   #11615
cnelson3's Avatar
Yeah. To me, it never felt quite right. I run at Trackside in Milwaukee. Medium to high grip. Track is a little bumpy but nothing overboard. I've run it on all types of layouts and it works well. It definitely changes the handling characteristics so their will be some time getting used to it.
Old 02-02-2015, 08:49 AM   #11616
cnelson3's Avatar
Originally Posted by 3srcracing View Post
So on his setup, set rear shock length at 27 and front at 20.5 with no shock rebound and no limiters.
And I should be set to go?
Are you running the long eyelets in back?
Old 02-02-2015, 09:03 AM   #11617
cnelson3's Avatar
Depending on the hole used on the hub, the camber link can rub on the springs. I switched them around to get a little more clearance. Obviously this is only good for 0* hubs.
Old 02-02-2015, 09:09 AM   #11618
cnelson3's Avatar
Sorry, I don't have a video.
Old 02-02-2015, 10:21 AM   #11619
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by khartlauer View Post
Im wondering the same. Can someone finally answer this question?
Based on the specs on the Savox site and what is listed in the manual it looks like you should start with 3mm of spacers. I set mine up so the servo linkage to the bell crank is in a straight line.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-03-2015, 07:31 AM   #11620
Default wtf
Hey guys hoping someone could shed some light.. so I recently replaced the out drives on my diff. No big deal got it all back together and adjusted correctly. ( i think) Then started the problem. . I've been eating through spur gears..the first one broke the pinion too where the set screw goes in. Replaced it with a team assosiated 26t. Seemed noisy still. And have now eaten thru 2 more spurs adjusting slipper and just trying to get it all to quiet down. I'm using the paper method to set mesh. And I dont know what it could be unless the top shaft is bent or the actual motor shaft is bent. Idk any ideas?
Chansharp318 is offline   Reply With Quote
Old 02-03-2015, 08:22 AM   #11621
Trader Rating: 14 (100%+)
I would look at both your top shaft and motor shaft. I run the avid aluminum top shaft and slipper system and I have actually had one warp on me. Gear mesh could also be the ticket..I actually never use the paper trick. I do it by feel and sound.
RBraswell is offline   Reply With Quote
Old 02-03-2015, 12:40 PM   #11622
subzero2k's Avatar
Hi.
Ive got my kit today. What is a good pinion to start.
I plan to use a 8,5t on a high grip carpet track.
Greetings
subzero2k is offline   Reply With Quote
Old 02-03-2015, 02:11 PM   #11623
Can someone please send me a direct link to Zach Rogers set up I dumb I guess can't find it! Thanks! Lol
Dirtysideup is offline   Reply With Quote
Old 02-03-2015, 02:30 PM   #11624
tobamiester's Avatar
Trader Rating: 274 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
http://www.petitrc.com/setup/kyosho/...nmans20140821/
tobamiester is offline   Reply With Quote
Old 02-04-2015, 06:59 AM   #11625
3srcracing's Avatar
Trader Rating: 25 (100%+)
What gearing do you guys recommend for 13.5?
3srcracing is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
