    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 01-26-2015, 05:56 PM   #11596
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
Which springs come in the kit?
pink_sleeve is offline   Reply With Quote
Old 01-26-2015, 06:25 PM   #11597
ThePanda's Avatar
Trader Rating: 64 (100%+)
Pink front red rear.
ThePanda is offline   Reply With Quote
Old 01-27-2015, 09:30 PM   #11598
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Car is awesome!
https://www.youtube.com/watch?v=WssaB3Cc79I
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 01-28-2015, 08:34 AM   #11599
Hunter15's Avatar
Car is a beast on the travk!
Hunter15 is offline   Reply With Quote
Old 01-29-2015, 02:54 AM   #11600
1fastdude's Avatar
Trader Rating: 15 (100%+)
Default Rear Arm Piece
Originally Posted by K_King View Post
How many would be interested in buying something like this?
Are you still going to try and get these made?
Team Horizon-Team Spektrum-Tekno-Kyosho*B-FAST R/C Performance*TQ Racing Wire Products-TNT-FX.COM-Avid RC-Dynamite-*AKA*92Zero Design*
1fastdude is offline   Reply With Quote
Old 01-30-2015, 07:45 AM   #11601
khartlauer's Avatar
Originally Posted by Greg Etter View Post
Looking for a little help. I'm using a savox sc 1251 servo and would like some reassurance that I used the correct servo spacer shim. For those that have used this combo which should I be using?
Thanks.....Greg.
Im wondering the same. Can someone finally answer this question?
Kyosho Ultima RB6.6 MM
AKA - 702 R/C Raceway - Hartlauer Signs
khartlauer is offline   Reply With Quote
Old 01-30-2015, 10:02 PM   #11602
3srcracing's Avatar
Trader Rating: 25 (100%+)
Didn't get much of a reply on Kyosho nation.. Try it here..
"Right now I'm running the zach Rogers Setup, with 3mm on the rear hub, (alunimum) in the long link position and it's pretty dang dialed. But I have a TON of steering. I have it tuned down to 60% on my remote. Am I better off running it like that, or putting in like 1.6 pistons to take out some steering, and turn the steering up on my radio?"
3srcracing is offline   Reply With Quote
Old 01-31-2015, 12:50 AM   #11603
Trader Rating: 81 (100%+)
Does anybody have a spare shock cartridge tool they would sell me. I have no idea where mine went and all the aftermarket tools are out of stock wherever I look.
dpcardoza is offline   Reply With Quote
Old 01-31-2015, 07:06 AM   #11604
cnelson3's Avatar
Trader Rating: 65 (100%+)
well, I think the best response is going to be one I've said many times. If it works for you, run it. Set ups are EXTREMELY driver and track specific. I found the 2x1.6 hole pistons to actually increase steering for me. I run the 3x1.4's up front and 2x1.6's in the back. If you have made sure your droop and ride height are the same as the Rogers set up, maybe its something besides your shocks.
Kyosho America
Peak Racing
Trackside Hobbies & Raceway - Milwaukee, WI
cnelson3 is offline   Reply With Quote
Old 01-31-2015, 07:40 AM   #11605
3srcracing's Avatar
So on his setup, set rear shock length at 27 and front at 20.5 with no shock rebound and no limiters.
And I should be set to go?
Old 01-31-2015, 07:49 AM   #11606
I'm having a hard time finding a description of what blocks do what for the rear hangers. I want narrow and 3 degrees toe.
scoobyrs25 is offline   Reply With Quote
Old 01-31-2015, 08:04 AM   #11607
tobamiester's Avatar
Trader Rating: 275 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
You need this:
http://www.petitrc.com/setup/kyosho/...5UMW706UMW707/
tobamiester is offline   Reply With Quote
Old 01-31-2015, 12:04 PM   #11608
Thanks!
Old 01-31-2015, 12:23 PM   #11609
K_King's Avatar
Anyone have success running 25+4 caster?
Old 01-31-2015, 02:44 PM   #11610
Okay folks I'm new to racing so bare with me. I finally figured out how to properly measure droop but now I don't know how to adjust it. I put the Zach Rogers setup on last night and it felt pretty good but I didn't mess with the droop at all.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22941 Today 04:55 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
