Kyosho Ultima RB6 & RB6.6 Car Thread
Tape a piece of foam on the back or some weather stripping foam. You have to have the new chassis to use the rt6 stop or drill holes.
There is a newer chassis part from Kyosho UM700B Aluminum Hard Main Chassis (A7075T6/RB6) KYOUM700B
No, has 2 extra holes for a speedo trey I think.
Don;t think its lighter. I have one from a kit 2 years old and one I built last month, the newer only has extra holes. Not extra machining like my LW chassis.
It's not lighter, just has more mounting holes.
I had the same problem. I used a thin piece of carbon fibre about 1.5mm thick drilled a hole in it, drilles a hole in the waterfall brace aswell from the backside and screwed the carbon fibre against the waterfall brace from the motor side.
Does 100% what it should as it prevents the battery from coming to close to the motor. Unfortunatelly you can only drill a hole on the opposite side of the motor plate as there is not enough romm between the motor plate and the waterfall brace to attach the carbon fibre to both sides. Not perfect but did not have any problems with it in about half a year.
Regards.
Dennis
Battery stop
Use part number um787.
I ended up cutting a piece of battery foam and shoe gooing it in the middle of the waterfall brace. it keeps the battery from the motor and the foam does not touch the motor so its win win and when i want to remove it all I have to do is peel the adhesive off!
Thanks for the ideas. BTW shoe goo is awesome.
What rear pivots are guys using? I'm trying to look at different things to try. Might look into Cin/Bin with the sideways pack. Din rolls too much for me. Bin/A may me too wide.
Is there an explanation somewhere of what wide vs narrow rear pivots does? Very interested in learning.
