    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 01-23-2015, 09:15 AM   #11566
ThePanda's Avatar
Trader Rating: 64 (100%+)
Originally Posted by motorfinger View Post
Panda, You coming to The Clubhouse this weekend?
I'm not sure about this weekend, but I will certainly be getting there.
Mind sharing any information about the place?
ThePanda is offline   Reply With Quote
Old 01-23-2015, 09:25 AM   #11567
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
What do you want to know?
Team Kyosho (RB6, RT6, ZX6 & SC6)
Team Orion R10.1 Pro
Team Orion Touch Duo Charger
Team Orion Pro Carbon 100C Batteries
motorfinger is offline   Reply With Quote
Old 01-23-2015, 10:25 AM   #11568
ThePanda's Avatar
A little of the lay of the land would be nice. Like how is the place run, stuff like that.
Old 01-23-2015, 10:38 AM   #11569
Originally Posted by K_King View Post
I've never had issues with steering on the RB6. Our servo is mounted a lot further than most cars, but I have a 10g aluminum pivot in case I ever needed more.
Oh right on i'm getting alot of push with my rear motor and full size lipo so I've been considering moving to mid motor. Also could someone clear me up on which side the diff adjustment screw should be on (direction of the diff)in the manual it appears they call for the screw to be adjusted from the left side of the car. But that goes against any other car, video, or forum I have seen. Anybody know which way it should sit.
Chansharp318 is offline   Reply With Quote
Old 01-23-2015, 10:48 AM   #11570
ThePanda's Avatar
It won't matter. most run it on the side opposite the motor plate.
Old 01-23-2015, 11:25 AM   #11571
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Everybody79x View Post
What about the upgrade 6.5" wing? I'm brand new to this car so excuse the n00b questions.
Yes that wing will work too, is one of my favorite ones.
The only issue you may run into with the UG Vortex, PL Trifecta, LMR (not sure if it's one particular or all of them) is the thickness of those wings can make getting the body clips that hold the wing in place hard to get in and out. I know a couple guys that have started using screws to hold the wing on. Seems to work pretty good from what I have seen. They use the exotek or JC alum wing buttons to do it.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 01-23-2015, 12:30 PM   #11572
beedee's Avatar
Quick question for you guys. I am converting my RB6 to mid-motor and i dont have any of the shims to put above or below the rear pivot. Running at OCRC (indoor, med/high bite clay)17.5 if that matters. Would a .5 above and below the pivot be good?
Thanks!
ASSOCIATED ★
beedee is offline   Reply With Quote
Old 01-23-2015, 09:17 PM   #11573
Thanks!
Yeah that would work it doesn't matter which side you put it on as long as it equals 1mm of shim I believe. And it has different effects on each side
Old 01-23-2015, 09:18 PM   #11574
So that would be the left side looking from the rear of the car. Which is strange to everything I've seen but I suppose I'll switch it back unless anyone on here knows different? ?
Old 01-25-2015, 01:55 AM   #11575
Trader Rating: 14 (100%+)
Any advice on how I can prevent the battery from sliding back onto the motor? I've seen a few folks run this batter setup but have not figured out how they keep the battery off.
RBraswell is offline   Reply With Quote
Old 01-25-2015, 01:56 AM   #11576
Double post
Old 01-25-2015, 07:16 AM   #11577
Potoczak's Avatar
Trader Rating: 112 (100%+)
I have been running my battery this way for a few weeks now since I switched to mid motor. My battery sits right up against the motor. Haven't had any issues at all.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-25-2015, 07:40 AM   #11578
You could use the battery stop from the rt/sc6
www.beachrc.com
phillypete is offline   Reply With Quote
Old 01-25-2015, 08:06 AM   #11579
tef
You are looking for KYOUM707
Thanks to my sponsors Kyosho America*O.S. Engines*TrakPower*Pro-Line Racing*Futaba*O'Donnell fuel*Team Scream Racing
tef is offline   Reply With Quote
Old 01-25-2015, 09:29 AM   #11580
A shock tower?
invalidprotocol is offline   Reply With Quote
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Today 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
M3CSLDreamin
