    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 01-15-2015, 07:53 AM   #11536
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Just curious, are those of you who are running the battery sideways running a 17.5 class or are you running modified?
The reason why I ask is that I find it interesting that a lot of people with the B5M, who are racing 17.5, are modifying their cars to allow the batter to be in-line. I don't know if the mod guys are doing this or not.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-15-2015, 08:42 AM   #11537
Originally Posted by kyle3333 View Post
Is there anyone out there machining chassis for people? I have done my side pods, but I would like to mill the chassis down. Unfortunately I don't have the proper equipment to do it correctly.
Thank you to those who sent pictures of their side pods, very helpful.
Hopefully Kyosho will come out with a side ways battery chassis and side pod package.
My son did his with a dremel, locks good.
Kyosho MP-9 TKI3, Tekno SCT-410, AE B5M, AKA racing, Mel's Shells, Family Hobbies in Vineland NJ, Sjrc
purple rides is offline   Reply With Quote
Old 01-15-2015, 09:06 AM   #11538
jeff jenkins's Avatar
Trader Rating: 76 (100%+)
I have a mill in my garage. I can mill out the chassis for people if they want the clean machined look . But it aint going to be for free.
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 01-15-2015, 07:04 PM   #11539
Mod - I'd guess in mod vs 17.5, more weight is needed on the rear of the car to get the traction needed to drive out of the corner. 17.5T might not be as harsh on the rear tires when coming out of the corner, so less weight needed on the rear, want more steering so in-line would shift CG slightly forward, possibly avoiding issue of needing to add weight to the front of the car ... all speculation though! I've never run 17.5T so don't really know
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 01-17-2015, 06:38 AM   #11540
Has anyone heard if there will be a 3 gear MM gearbox coming or a YZ2 style laydown MM gearbox??
Headling is offline   Reply With Quote
Old 01-17-2015, 04:16 PM   #11541
Has anyone managed to mount a fan onto the motor plate in a mid motor config? I've been contemplating it, but not sure if it'll fit with the standard body.
I was thinking I could dremel a recess into the motor guard and fit an ESC sized fan, but was wondering if anyone had managed the next size up?
RichD is online now   Reply With Quote
Old 01-17-2015, 05:15 PM   #11542
Default Trying to convert to midmotorrrr
Hey guys I unfortunately bought my rb6 used and did come with all the extra pieces and none of the mid motor parts. I am trying to compile a list of everything so I can order it at once. So can ya guys look it over and let me know if I am looking over anything..thanks in advance
UM722 Rear Shock stay (MM)
UM723 Gear Box Set (MM)(Comes with motor guard)
UM724 Rear Bulkhead (MM)
UM725 Rear Bumper (MM)
UM726 Suspension Holder Set (MM)
2x BRG001TS Flourine Shield Bearing 5x10x4 (idle gear bearings)
UM125 Idler gear shaft
UMW512 SP Idler gear
1x 3x18mm f/h screw
Have I forgotten anything?? And another question I have is do I need any extra bolts or is pretty straight forward take out of rear motor parts and put in mid motor parts? I can only hope its that simple lol
Thanks for the help!
Chansharp318 is offline   Reply With Quote
Old 01-17-2015, 05:57 PM   #11543
Already added another piece..
UM709 Wing Stay Set
Old 01-17-2015, 08:21 PM   #11544
Rear Motor
10 3x8mm f/h hex
4 3x15mm button hex
5 3x35mm button screw
4 3x6x2 plastic collar
2 3x6mm button hex
2 3x8mm button hex
2 3x10mm f/h hex
2 3x12mm button hex
1 3x10mm button hex
Mid Motor
8 3x12mm button hex
3 3x18mm f/h hex
4 3x8mm f/h hex
3 3x10mm button hex
3 3x35mm button hex
2 3x10mm f/h hex
2 3x8mm button hex
3 3x6x3 plastic collars
difference
6 extra 3x8mm f/h hex
4 less 3x15mm button hex (none used)
2 extra 3x35mm button hex
1 extra 3x6x2mm plastic spacer
same 3x8 button hex
same 3x10mm f/h hex
6 needed 3x12mm button hex
2 needed 3x10mm button hex
Old 01-18-2015, 09:54 PM   #11545
HeavenlyHobbies's Avatar
Originally Posted by K_King View Post
How many would be interested in buying something like this?
I'm in on that as well
Heavenly Hobbies - NexGen Racing
www.NexGenReno.com
www.NexGenRoofs.com
www.ShingleShower.com
Reedy Racing on RC Files
HeavenlyHobbies is offline   Reply With Quote
Old 01-18-2015, 10:21 PM   #11546
Trader Rating: 14 (100%+)
Would anyone who runs competitive stock 17.5 upload a pic or recommend a electronic setup? Also, what gearing on smaller tracks do you recommend as a starting point. I have been fairly lax with my setup and it is costing me. Currently running 69/31 running electronics like tebo 2013.
RBraswell is offline   Reply With Quote
Old 01-18-2015, 10:41 PM   #11547
E73
E73's Avatar
Pic attached: servo, ESC, battery, motor. Always had a problem with oversteer with the RB6 so moving the battery back helped a bit. Also running 69/31 with R1Wurks motor @ 30 degrees. Gets to about 155F after 6 minute heat.
E73 is offline   Reply With Quote
Old 01-18-2015, 10:47 PM   #11548
beedee's Avatar
Originally Posted by Chansharp318 View Post
Rear Motor
10 3x8mm f/h hex
4 3x15mm button hex
2 3x6mm button hex
2 3x8mm button hex
2 3x10mm f/h hex
2 3x12mm button hex
1 3x10mm button hex
Mid Motor
8 3x12mm button hex
3 3x18mm f/h hex
4 3x8mm f/h hex
3 3x10mm button hex
3 3x35mm button hex
2 3x10mm f/h hex
2 3x8mm button hex
difference
same 3x8 button hex
same 3x10mm f/h hex
thanks for sharing this. i am currently RM but will be changing to MM soon. i have all of the parts but wasnt sure of what extra bolts may be needed. so thanks for doing the leg work on that!
ASSOCIATED ★
beedee is offline   Reply With Quote
Old 01-19-2015, 05:43 AM   #11549
Yep no worries!
Old 01-19-2015, 05:35 PM   #11550
Potoczak's Avatar
Trader Rating: 111 (100%+)
Question for the guys that did the sideways battery mod. How far back did you put the battery?? Up against the brace or a little foward???
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
