    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 10-06-2012, 10:14 AM   #1141
savageboy69's Avatar
Trader Rating: 88 (100%+)
when i did my shocks i just used one of the big id washers ( like for the axles) and slid it over the bushing and snugged it to the shock, fits nice, no play
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 10-06-2012, 10:22 AM   #1142
I too was wondering why they reverted back to the old slipper. I run a hybrid slipper assembly; white pad and non-vented plate in the rear and the red pad with the vented disc up front, I also use the WC spring retaining washers. This set up provides the most consistency I've found. Finally drove the buggy last night, and I have to say, it is awesome. Stuck to the track and has good steering out of the box. I have added 14g of weight behind my servo (KO low profile) and the car rotated incredibly well. Can't wait to race it tonight.... Just FYI, I am pretty much running tebo's nat set up, with a few minor changes.
Entr0phy is offline   Reply With Quote
Old 10-06-2012, 10:36 AM   #1143
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by jpcopeland1 View Post
Mine were on the tree with the old useless plastic Hexes. But loose in the bag.
All-be-damned... there they are. Two tiny little plastic things. How disappointing! Im going to have to go buy another WC slipper assembly for my RB6. Thanks for finding those in my bag for me
Another thing that just amazes me, is how far off the cut lines are on the front of the body! I never use body clips, I always use velcro, so I just cut the entire front piece of the body off. Much better.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-06-2012, 11:13 AM   #1144
t8rtot's Avatar
Trader Rating: 14 (94%+)
I think the t-nut for my diff wasn't included.. Only bag left is the shocks and I've looked thru them.. Any other brand that will fit for now?
I'm contacting Kyosho America, but I want to get this thing out of the living room today
Sfida
t8rtot is offline   Reply With Quote
Old 10-06-2012, 11:34 AM   #1145
Trader Rating: 138 (100%+)
The actual nut? or the whole thing including the white thingie it goes into? Durango has the correct size nut you need. Hope you know of a local dealer who stocks Durango parts. All of my diff stuff came in one bag.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, B64D (Temporary 4 wheel) YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-06-2012, 11:37 AM   #1146
fastestwon's Avatar
Trader Rating: 15 (94%+)
FYI guys Avid has a slipper unit in the works for this transmission . like the triad system . thats what i am going to wait for
fastestwon is offline   Reply With Quote
Old 10-06-2012, 01:18 PM   #1147
I built one for my brother B4 last night, It is very nice. All they need to go is change the holes. Shouldn't take long at all.
Old 10-06-2012, 01:44 PM   #1148
John.C's Avatar
Trader Rating: 36 (100%+)
I'm new to electric offroad. Are we to drill small holes in the front wheels? The rear wheels had 2 holes pre-drilled. I'm pretty sure I do but wanted to make sure. Also, I ordered and received front tires (Sweep 10Droids) that are intended for 4wd buggies. They fit on the wheels fine. Can I run theses? I'll be racing on a med/high bite indoor clay track.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 10-06-2012, 01:57 PM   #1149
Not the best choice of tire I would think for indoor clay, I would have gone either Gold Bar Codes or V1. clay compound Scrubs. As far as the tire size. You can run them if your track or club doesn't adhere to any types of rules such as no boost on speed control if running blinky mode in stock spec class, weight, car width (those tires will make your car illegal width wise in the front). Things like that. I only drill holes in my rims if I am running closed cell foams in the front which I am finding I am doing less and less these days. If you see that your tires seem to have a balloon shape to them, or feel like they are full of air, the easiest thing to do would be to take a body reamer and make small holes in the rim to let the air escape. I don't punch holes in my tires anymore due to the fact that it seems to disintegrate Closed cell foams much faster then I would like.
Old 10-06-2012, 02:40 PM   #1150
Trader Rating: 91 (100%+)
It's in a square white plastic sprue, pictured in this link
Or you can use the alloy t-nut for the Tamiya diff if you want to upgrade
Eric Tomczyk is offline   Reply With Quote
Old 10-06-2012, 06:41 PM   #1151
Trader Rating: 18 (100%+)
Went a little different route and made the window one piece instead of two. What do you think?
Ryan Sagisi
Schelleracing.com | Raceaka.com | R1wurks.com
B5M | B44.2 | T4.2 | Top Photon
SAGISI is offline   Reply With Quote
Old 10-06-2012, 06:51 PM   #1152
Trader Rating: 1069 (100%+)
I have a bunch of them if you need one...
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 10-06-2012, 07:10 PM   #1153
t8rtot's Avatar
Guys I appreciate the help, my 5yr old thought the whole piece looked good as a take in her doll house.
Crisis averted.
I'll have pics up tomorrow
Sfida
Old 10-06-2012, 07:45 PM   #1154
Trader Rating: 27 (100%+)
Was thinking of getting this buggy but I race stock normally. I hav a ton of money tied up in my rb5 and it's awesome. Do you think this is more of a mod car Cause of its weight?
C_Money is offline   Reply With Quote
Old 10-06-2012, 07:54 PM   #1155
t8rtot's Avatar
its roller weight is within a few grams of the 22.. That's lighter than the 210.. I say it should be fine. I'll let you know in one week if you haven't purchased by then
Sfida
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
