    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 01-13-2015, 01:13 PM   #11506
beedee's Avatar
Originally Posted by Everybody79x View Post
Do you guys use Kyosho springs or is there a cheaper alternative?
I use Kyosho springs, and have been advised by those whom are very familiar with the brand at my local track to do so. That's not to say that I might not notice a difference if I used Losi or AE, but I figured I'd run brand specific.
The cheapest place I have found them is at www.losipartshouse.com
ASSOCIATED ★
beedee is offline   Reply With Quote
Old 01-13-2015, 02:32 PM   #11507
Brian C.'s Avatar
losi parts house.
Brian C. is offline   Reply With Quote
Old 01-13-2015, 02:35 PM   #11508
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Yes I heard that the losi low freq springs work pretty well. I just already had a bunch of the tuning xgears so never bothered. I tend to replace them when I can no longer tell the colors haha. So next batch I will get some losis.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-13-2015, 03:12 PM   #11509
beedee's Avatar
Originally Posted by Brian C. View Post
losi parts house.
ironic name eh. lol.
http://www.losipartshouse.com/Shocks...show=20&page=2
ASSOCIATED ★
Old 01-13-2015, 04:37 PM   #11510
Potoczak's Avatar
Trader Rating: 112 (100%+)
Ok.. so I'm switching my rear motor over to mid motor. I'm a little confused with the shims that go below and on top of the rear,rear suspension holder. There is supposed to be one below the suspension holder and one above. So my question is on the setup sheets which one are they referring to??? And what is the point of the shim thats above the suspension holder?? It seems like it just raises the shock tower.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-13-2015, 04:52 PM   #11511
yodace's Avatar
R/C Tech Charter Subscriber
what are they putting in front of the battery ? what are u guys doing to the side pods to mount the battery sideway?
what are the bearing sizes when using the v2 hubs?
http://ultralinehobbies.com/products...sc-kyoumw704-0
yodace is offline   Reply With Quote
Old 01-13-2015, 05:55 PM   #11512
powerslave's Avatar
You want to keep the same distance between the chassis and the tower,so if it calls for the .5 put that below the suspension mount and the 1.0 above and vice versa.
At least that's my understanding.
powerslave is offline   Reply With Quote
Old 01-13-2015, 06:30 PM   #11513
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
These hub carriers feature 0 of outboard rear toe in, and bearing inserts that allow you to use either a 5x13/5x11mm axle bearing configuration, or a 5x10/5x10 bearing configuration. Additionally, the use of bearing inserts helps to improve drive train efficiency and extend the life of the hubs.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-13-2015, 06:40 PM   #11514
yodace's Avatar
Which bearings do u recommend ?
Old 01-13-2015, 06:45 PM   #11515
Super Moderator
Kraig's Avatar
From what I can remember, I would run the 5x10 inside and the 5x13 on the outside. I know that isn't a configuration I listed but the kit is 5x10 so you will have to get some 5x13's for the outside. I can't see myself buy a 5x11.
Old 01-13-2015, 09:13 PM   #11516
Trader Rating: 55 (100%+)
Pete you always want the total amount of shims equal 1mm. So if it calls for .5 then u put .5 under holder and the other .5 u under bulkhead. If it Calls for 1mm the 1mm under holder and 0 under bulkhead
Speedychris22 is offline   Reply With Quote
Old 01-13-2015, 10:19 PM   #11517
kdub's Avatar
Default split pistons 4 hole
Originally Posted by E73 View Post
Has anyone tried the Schelle 4-hole 1.4 + 1.1, 1.5 + 1.1, or 1.6 + 1.1 pistons? If so, please share you experiences including shock oil used etc. Going to try 1.4 in front and 1.6 in rear with 32/30 oil respectively.
The pistons come with a tuning guide that includes oil and track condition recommendations. Rule of thumb, use the same oils as:
1.6+1.1 is close to 2x1.7, use 30-32.5 wt in rear
1.5+1.1 is close to 2x1.6, use 27.5-30wt in rear; 30-32.5 in front
1.4+1.1 is close to 2 x 1.5, use in front with 32.5wt-35wt
The 4 hole pistons have less low speed damping= more traction and grip on small bumps, but they pack up on big jumps to prevent the car from bottoming.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 01-14-2015, 04:54 AM   #11518
Potoczak's Avatar
Got it. Thanks for the reply guys.
Pete Potoczak
Old 01-14-2015, 09:07 AM   #11519
yodace's Avatar
Are there pics of tebo's rb6 with the battery mounted sideways? Are u guys cutting the side pods?
Old 01-14-2015, 09:29 AM   #11520
Here you go...
cstoeltzing is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
