    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 01-09-2015, 11:41 AM   #11461
beedee's Avatar
Originally Posted by aloksatoor View Post
RM with LW chassis. Thats got almost as much traction as my yok with a plastic tub. No need to run a MM just cos all the others are doing it .
I only have one race day under my belt with my RM RB6 but I ended up qualifying 11th out of 24 buggies, and almost all of them were MM. I went on to win the B-main (and bump up to the A-main) with my RM, again against all MM buggies. This was in Sportsman Stock (17.5) class against some pretty talented drivers (OCRC in SoCal).
My plan is to run it a few more months RM then switch it to MM to see if I like it and notice a big difference. Right now I have no reason to change it
ASSOCIATED ★
beedee is offline   Reply With Quote
Old 01-09-2015, 06:46 PM   #11462
3srcracing's Avatar
Trader Rating: 25 (100%+)
So I just went through my car again to make sure I was running exactly the Zach Rogers setup. Here is what I found.. Could some maybe tell me what each change will do?
Medium to long shock ends (rear)
Long to Med shock ends (front)
Rear Arms shimmed forward instead of backwards
No .5 shim under rear suspension arm
Caster Block shimmed 1.5mm on bottom now position to 1mm on bottom .5 on top
Caster Block shimmed 1mm on rear (was 1mm on the front)
Also are my springs right?
Pink Kyosho fronts
Associated Whites
3srcracing is offline   Reply With Quote
Old 01-09-2015, 07:54 PM   #11463
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Pink Kyosho fronts
Associated Whites
More rear droop gives you more traction through a corner, but will dump over harder on entry.
Long to medium, would give you less front droop and keep the front end flatter. Keeps more weight on the front of the car for more steering.
Forward will give you more forward bite and traction. Worse in the bumps though vs arms rear.
Ff you ran no rear shim you would jump better, but have less side bite and forward bite.
Moving the caster down would give you more bump in if you don't change the bumpsteer shim. Makes it easier to drive on exit and scrubs some speed on the face of jumps.
1mm on the rear makes the front end less reactive and have less steering (This is if you have a 25+0 setup so the shimming would be even on both sides)
Pink fronts are ok, so are whites. I am going to experiment with stiffer springs up front.
Not sure what AE whites are, I hear they are close to Golds so they should be fine.
For piston/oil I would be 32.5/30 with a 1.6x2 piston all around or a 35/30 3x1.4 and 2x1.6 piston setup
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 01-09-2015, 08:22 PM   #11464
bigl's Avatar
Trader Rating: 31 (100%+)
K_King whats the part # for the steering brace
bigl is offline   Reply With Quote
Old 01-09-2015, 08:53 PM   #11465
K_King's Avatar
http://www.kyoshoamerica.com/Aluminu...6_p_23658.html
Old 01-09-2015, 10:07 PM   #11466
3srcracing's Avatar
Thanks so much K_King!!!
So from what I did change wise..
Also installed the electronics like he has it..
What shouldi feel now compared to my previous version of his setup?
Old 01-09-2015, 10:24 PM   #11467
K_King's Avatar
You should have more rear grip overall.
Old 01-09-2015, 11:12 PM   #11468
joecool's Avatar
Trader Rating: 19 (100%+)
I got the new steering brace and installed it the way the directions explain to do it. You remove the 2 thin plastic spacers under the crank arms. I feel my bump steer has changed by doing it this way. The car drives slightly different too. It could be a mental thing but I know something is different. I was thinking of shaving down the plastic on the knuckle .5mm to compensate. Does this sound right?
Joe Cool
Kyosho America, Team Orion, Ko Propo
joecool is offline   Reply With Quote
Old 01-09-2015, 11:29 PM   #11469
K_King's Avatar
You could put the .5mm shim on top of the caster block of you think the bump changed.
Old 01-10-2015, 09:19 AM   #11470
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Dang, you do have all of the cool stuff!
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-10-2015, 10:02 AM   #11471
Default Slipper question and setup
Hey all, i'm a recent addition into the buggy world and built the RB6 over the holidays. Having never built a slipper clutch before (my other RC is a 4WD Tekno SCT410 which does not have one), i'm curious if anyone has any advice/thoughts on doing it correctly. I'm planning to start by running 2WD stock class (17.5) at SDRC. It was suggested that i install the slipper eliminator (Kimbrough 69T spur and slipper eliminator) for running stock.
My first question is, for those that run stock, do you still have the slipper installed? Or do you use the eliminator?
My second question is, for those who use the slipper (stock or otherwise), how do you assemble it so that the pad stays aligned with the plates as you are tightening everything down? I keep having the pads slip away from the center spur and then rotate slightly so that the edge holes on the pad no longer align with the little tabs on the gear. As a result i don't think i'm getting good contact between the plates and the pads, and i'm having a really tough time getting it adjusted correctly. Any advice on building and setting the slipper would be welcome. Thanks!
Josh
Tekno SCT410 | RX8.2 | Xerun 3656SD 4700 | Protek 150T
Kyosho RB6 | Reedy Blackbox 410R | Reedy 17.5 | Savox 1257TG
Jgins13 is offline   Reply With Quote
Old 01-10-2015, 10:56 AM   #11472
Potoczak's Avatar
Trader Rating: 111 (100%+)
Is there a parts listing somewhere on what is exactly needed to convert from rear motor to mid motor???
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-10-2015, 11:11 AM   #11473
ThePanda's Avatar
Trader Rating: 64 (100%+)
try keeping the pad pressed down with a small tool when you press the spur over the topshaft. if you are still unsure a small amount of glue can hold it down.
ThePanda is offline   Reply With Quote
Old 01-10-2015, 12:04 PM   #11474
yodace's Avatar
R/C Tech Charter Subscriber
When u buy Kyosho rear a arms part # 713, does it come with left and right arms? Or do u have to buy 2 sets?
yodace is offline   Reply With Quote
Old 01-10-2015, 12:24 PM   #11475
ThePanda's Avatar
Taken from infernos only
Description
The replacement rear arms for the Kyosho Ultima RB6. These come in a set of left and right. Made from a strong and stable composite material for performance and durability.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22953 Today 12:29 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
