    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 01-07-2015, 04:33 AM   #11446
I just bought some carbon fibre brackets to achieve the shock position as per Zack Roger's set up on the rear arm, which avoids the need to drill the extra hole. They cost me AUD $12 delivered. The same guy has supplied me a custom CF chassis for an RB5, a CF top deck for my ZX6 and shock towers for my old XB4. All have been excellent and very durable.
Check out Bezerk RC on FB if you're interested.
The guy's name is Paul Sims and he's the club president of one of our local clubs and invests a lot of time into the hobby. He may be able to make them out of aluminium if you'd rather as I've seen some of his CNC work too.
RichD is offline   Reply With Quote
Old 01-07-2015, 05:08 AM   #11447
I would rather have a machined Aluminum piece that I can use as a template. Mounting it to the arm by the sway bar mount and the outside shock hole. One piece and just flip it over for the other side. Better then that, Kyosho start making rear arms with the new hole.
potatobed409 is offline   Reply With Quote
Old 01-07-2015, 09:26 AM   #11448
Potoczak's Avatar
Trader Rating: 111 (100%+)
I'm sure we will see some new 3 hole arms soon.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-07-2015, 07:44 PM   #11449
Agreed, Kyosho should be doing this.
However, until then the exchange rate is great for those in the US. AUD $12 is about $9.50 US and the CF parts can be used as a template too. Alternatively, ask him if he'll do aluminium.
Old 01-08-2015, 06:24 PM   #11450
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
The problem with his version, is that the droop is effected when you mount it on the arm that way. The part I had done has the correct hole alignment so droop isnt affected.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 01-08-2015, 06:38 PM   #11451
I've seen the brackets you had made and they are sic looking. Best part if you happen to snap an arm you just screw them into the new one and the hole is perfect every time.
CaseyD is offline   Reply With Quote
Old 01-08-2015, 07:48 PM   #11452
K_King's Avatar
Yeah, I had about 6 arms with different distances. 17.7, .8 , .9, .5. I got really frustrated so I decided to make sure it's perfect 100% of the time with no drilling.
Old 01-08-2015, 09:26 PM   #11453
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
Anybody use futaba s9352hv servo or the bls471?
TEAM ASSOCIATED Rc10, rc10B6D ,FUTABA , TEAM ORION, KYOSHO RB6.
mdwaeracer is offline   Reply With Quote
Old 01-08-2015, 11:44 PM   #11454
I don't quite follow?
The screw coming out of the CF bracket, that the shock mounts to, is in the same place as where you'd drill the hole on the arm. So I'm not sure what you mean by the droop being effected?
Old 01-09-2015, 04:24 AM   #11455
Originally Posted by Jason Snyder View Post
try lower a rear roll center.....or maybe a bit longer rear link.
I was able to get around my issue by putting the white springs on the front and tuning a little dual rate.
The RB6 was the best its ever been last night.
www.beachrc.com
phillypete is offline   Reply With Quote
Old 01-09-2015, 07:10 AM   #11456
wittyname's Avatar
My buggy was awesome for a long time when my track was dry and grooved. Now they have rebuilt it , and I cant drive the dern car. The track is damp clay and cold, with no groove. Last outing I had tebos wet clay set up on it from petite and I couldnt even go full throttle without spinning. I ran the same tires as the winner that night . Most of the set ups i see are for med to high bite clay tracks , anyone point me towards something for damp , no grip tracks ? Thanks in advance ...
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
Old 01-09-2015, 07:41 AM   #11457
hacker's Avatar
Trader Rating: 140 (100%+)
good luck with that. It's been brought up so many times on this thread and its not just me.
this car is crap when traction is low.
My other brands MM cars have more forward traction than my RM rb6.
hacker is offline   Reply With Quote
Old 01-09-2015, 10:53 AM   #11458
K_King's Avatar
Sorry I was relating it to the bracket I use.
Old 01-09-2015, 10:55 AM   #11459
K_King's Avatar
What problems are you having specifically? What is the current setup you have, please be detailed, electronic layout and tired used.
I run on a medium bite track where traction is lacking and I have my car pretty good right now.
Old 01-09-2015, 11:02 AM   #11460
aloksatoor's Avatar
Trader Rating: 42 (100%+)
RM with LW chassis. Thats got almost as much traction as my yok with a plastic tub. No need to run a MM just cos all the others are doing it .
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Today 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
