    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree18Likes
Old 01-03-2015, 12:50 PM   #11416
Originally Posted by Speedychris22 View Post
Yes u have to add the .5 mm shim up top as well. The shims always have to equal 1mm. So if don't have one on the bottom then use the 1mm on top.
Thanks,
So if I were to put more than 1mm under the rear hanger (trying pro squat) what would I need to do above the hanger? Otherwise I assume the rear shock tower and gearbox will be raised?
RichD is offline   Reply With Quote
Old 01-03-2015, 12:58 PM   #11417
ThePanda's Avatar
Trader Rating: 64 (100%+)
Originally Posted by ThePanda View Post
so I ordered the aluminum steering rack and rear aluminum blocks for my rb6, but only put the rack and blocks in the cart, not the cranks too (the bearing pieces) I didn't check and now I only have the rack and blocks coming. Should I go back and also order the cranks too?
anyone?
ThePanda is offline   Reply With Quote
Old 01-03-2015, 03:39 PM   #11418
beedee's Avatar
I acquired my used RB6 last week and had one practice session on it at my local track, OCRC. Last night I raced it in the Stock Sportsman Buggy class, we had two full heats of 12 racers. I qualified 6th in each heat, which put me in the 3rd spot for the B-main. I ended up winning the B-main and advanced to the A-main! Started 10th on the grid, finished 8th.
I could not have been happier with my RB6's performance! I dont race much so I was ecstatic with my results last night. It is set up rear motor and I was up against pretty much all mid motor AE, TLR, etc.
ASSOCIATED ★
beedee is offline   Reply With Quote
Old 01-03-2015, 04:45 PM   #11419
gillbily23's Avatar
anyone?
I bought cranks but have not installed them yet and really not sure that the cranks will really make much difference. I have the aluminum rack and blocks as well and the blocks really made the most difference because they can be adjusted more. The rack was nice because it took some play out of the steering but I also removed the servo saver as well. I don't think that the cranks flex enough that they really affect the steering response a lot but they do provide some flex in the steering so that the servo isn't taking too much punishment without the saver.
gillbily23 is offline   Reply With Quote
Old 01-03-2015, 06:02 PM   #11420
ThePanda's Avatar
thanks, thats what I was looking for.
Old 01-04-2015, 10:06 AM   #11421
MayorRC's Avatar
Having a ton of fun with my RB6. Took about a year off of the hobby to focus on my real racing, but really loving the RB6. Such a great, tunable, and quality car.
Been reading through the thread and learning a lot, thanks guys!
Kyle-Keenan.com | MayorRC.com | McKune Design | Hella Graphics | 2WDMod.com | Kyosho | Orion
MayorRC is offline   Reply With Quote
Old 01-04-2015, 01:03 PM   #11422
MikaR's Avatar
Yes, it is great! run a lot last summer, very little so far this winter, but again next summer with both mid and rear cars. I've dropped all other cars and classes, this is such great! I really enjoyed the rear setup on clay but will try running zack roger's rear setup outdoors, too. Have new motors and other electronics on both, just need buy a pile of rear tires to stay in the action. Which one do you guys prefer on loose dirt/clay, AKA or Proline ? Or some other? I was thinking of making an order from amain towards the season start for proline holeshots pre-glued on 2.2 wheel.
MikaR is offline   Reply With Quote
Old 01-05-2015, 04:59 AM   #11423
Lochlan/kyosho's Avatar
what pinion gear size is the best for all round track and would some one be able to link me to one on amain
Kyosho Mp9 Tki3
Kyosho ST-RR Evo
Reds Racing
Pro-Line
Hei International
Lochlan/kyosho is offline   Reply With Quote
Old 01-05-2015, 05:03 AM   #11424
Unfortunately, there's no such thing as best pinion gear for all round track as there's no such thing as an all round track. Ask the guys that are running at your track first, given you should know what powerplant you are using and if they're not running the RB6, then figure out what gear ratio they're running and you can work it out from there
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 01-05-2015, 07:09 AM   #11425
gelshocker's Avatar
Hey guys can anyone post a pic of the new Aluminum Steering Support UMW724 installed? Thx,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 01-05-2015, 10:52 AM   #11426
For those of you who have dabbled in the black magic that is Zach Roger's OCRC setup:
What would you do to gain a bit more rear side bite?
... and I've already been through the tire and sauce gauntlet to get everything I can out of that department.
www.beachrc.com
phillypete is offline   Reply With Quote
Old 01-05-2015, 01:28 PM   #11427
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Go in on the rear tower.
I am getting an estimate ok how much it would cost for a batch of the brackets. Depending on the estimate I will know how much to sell them if there's enough interest.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 01-05-2015, 01:50 PM   #11428
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Thanks. The steering sleeve is supposed to reduce slop?
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-05-2015, 01:57 PM   #11429
I may be interested if it's no more than $10. Otherwise my drilling skills will suffice.
Kevin, have you experimented with removing the motor guard screws in the chassis for more grip?
Old 01-05-2015, 01:59 PM   #11430
K_King's Avatar
The brace is to prevent twisting under load from my understanding.
You can remove the screws from the waterfall to get more grip, it's a quick adjustment that you can definitely tell.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22972 Today 04:13 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
