    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 01-02-2015, 05:11 PM   #11401
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
How many would be interested in buying something like this?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 01-02-2015, 05:21 PM   #11402
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Sorry my phone attached it sideways for some reason.
I am. This for standing up the rear shocks on a MM right? Do you guys run long shock ends for this?
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-02-2015, 05:40 PM   #11403
Trader Rating: 14 (100%+)
I'd get down with that
RBraswell is offline   Reply With Quote
Old 01-02-2015, 07:03 PM   #11404
ThePanda's Avatar
Trader Rating: 64 (100%+)
so I ordered the aluminum steering rack and rear aluminum blocks for my rb6, but only put the rack and blocks in the cart, not the cranks too (the bearing pieces) I didn't check and now I only have the rack and blocks coming. Should I go back and also order the cranks too?
ThePanda is offline   Reply With Quote
Old 01-02-2015, 07:27 PM   #11405
cactuskdogg's Avatar
Originally Posted by glenng View Post
My mom likes zack rodgers too
Lol! Thanks for the replies guys!
cactuskdogg is offline   Reply With Quote
Old 01-02-2015, 09:03 PM   #11406
K_King's Avatar
Yup. It's better geometry as the bracket takes the guessing game out if it and it's inline with the 2 hole side to make the droop the same. I run long or medium. Doesn't seem to matter.
Old 01-02-2015, 09:54 PM   #11407
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
I would. How much ?
TEAM ASSOCIATED Rc10, rc10B6D ,FUTABA , TEAM ORION, KYOSHO RB6.
mdwaeracer is offline   Reply With Quote
Old 01-03-2015, 01:32 AM   #11408
Potoczak's Avatar
Trader Rating: 111 (100%+)
Would be interested.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-03-2015, 02:02 AM   #11409
Suspended
False, it is not to stand up the shocks (although that is a byproduct of moving the shocks in on he arm). The point of moving the shocks in on the arm is to change the amount of leverage the arm has over the shock. Physics 101.
Mantis Toboggan is offline   Reply With Quote
Old 01-03-2015, 03:31 AM   #11410
Hi Guys,
Almost finished building my mid motor and had a quick question.
After being totally confused by the pro squat discussion earlier on in the thread, I've decided to plagerise the Zach Rogers and Kevin King's most recent on Petit RC and play around between the two as we tend to have medium bite here on our local tracks.
Looking at the manual and my alloy sus hangers, I've placed a 0.5mm spacer under the rear hanger. Do I need to put the spacer above it too, under the rear bulkhead?
Can someone give me an idiots guide on what I'm supposed to do here?
Cheers
RichD is online now   Reply With Quote
Old 01-03-2015, 03:53 AM   #11411
Trader Rating: 81 (100%+)
I'd be in
dpcardoza is online now   Reply With Quote
Old 01-03-2015, 05:21 AM   #11412
Trader Rating: 50 (100%+)
Originally Posted by RichD View Post
Hi Guys,
Cheers
Yes u have to add the .5 mm shim up top as well. The shims always have to equal 1mm. So if don't have one on the bottom then use the 1mm on top.
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 01-03-2015, 09:06 AM   #11413
alex4r's Avatar
Send a message via AIM to alex4r
A little late trying the Zach Rogers setup, but I just got some rear 705/707 hangers and a few other goodies to give the RB6 another chance. Have a couple of questions about some missing information on the sheet (or maybe I looked right over it). Is it hole 1 or 2 on front arms? What inserts in the umw705/707 rear hangers, D-in/D-in? Lastly, antisquat is 0mm under front and 1mm under rear hanger, correct?
Thanks guys, I've gathered you really have to follow the sheet to the T for it to work well.
Alex Kennedy
Bellgate Distributors | Highest RC
Sanwa M12S | Kyosho RB6.6 | Kyosho ZX6.6 | Kyosho MP9 TKi4
alex4r is offline   Reply With Quote
Old 01-03-2015, 09:10 AM   #11414
I believe Zach uses c in c in on both hangers, it doesn't matter which side of the arm u use, u have to drill 17.8 from sway bar hole. And yes if his setup sheet states 1mm then u put the 1mm shim under rear hanger and nothing under front
My Credit Card
Old 01-03-2015, 09:30 AM   #11415
alex4r's Avatar
Thanks for the fast response.
Alex Kennedy
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 Today 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
albertv78
