    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 12-29-2014, 09:14 PM   #11386
3srcracing's Avatar
Trader Rating: 25 (100%+)
I just put the Zach Rogers setup up to a T on my car. Moved the speedo/battery and receiver in the same spots. Might try it out this weekend, not sure yet.
3srcracing is offline   Reply With Quote
Old 12-29-2014, 10:10 PM   #11387
rpboggs1's Avatar
Trader Rating: 19 (100%+)
Talking
Hope your competitors don't forget their wood screws... 'Cause you're gonna blow their doors completely off.
Kyosho RB6 * Kyosho ZX6 * Kyosho RT6
TLR 22SCT * TLR SCTE 2.0
Tekno NB48.3 * Tekno EB48.4 * Tekno EB48.3 * Tekno ET48.3
rpboggs1 is offline   Reply With Quote
Old 12-30-2014, 02:53 AM   #11388
gillbily23's Avatar
I went speedo in front of the battery because I want the battery as far back as I can get it for extra rear weight.
gillbily23 is offline   Reply With Quote
Old 12-30-2014, 03:39 AM   #11389
How does that compare with battery all the way back with ESC on the shelf above the battery by the motor guard?
RichD is offline   Reply With Quote
Old 12-30-2014, 10:14 PM   #11390
Steve081's Avatar
Originally Posted by K_King View Post
Finally finished how I wanted to mount it.
Did you drill extra holes to get the battery strap that far back?
Steve081 is offline   Reply With Quote
Old 12-31-2014, 09:47 AM   #11391
Default Slipper build question
Hi all,
I'm building my new RB6, and have a question about the slipper assembly. In the manual it says to "remove flashing" from the spur gear. Can anyone confirm what this is referring to? What is the "flashing" on the gear? Thanks!
Jgins13 is offline   Reply With Quote
Old 12-31-2014, 10:08 AM   #11392
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
If there would be any flashing (extra plastic from the molding process) on the spur gear, it would be in the hole that the shaft goes thru.
Team Kyosho (RB6, RT6, ZX6 & SC6)
Team Orion R10.1 Pro
Team Orion Touch Duo Charger
Team Orion Pro Carbon 100C Batteries
motorfinger is offline   Reply With Quote
Old 12-31-2014, 10:29 AM   #11393
Thanks.
Old 12-31-2014, 10:40 AM   #11394
Suspended
dominick i.'s Avatar
Trader Rating: 123 (97%+)
Originally Posted by Jgins13 View Post
Hi all,
are you sure they didnt spell it "frashing" like they did on the alum hub carrier instructions?
club racing is always great racing......
I am probably the only non sponsored racer in the usa.....:)
dominick i. is offline   Reply With Quote
Old 12-31-2014, 05:48 PM   #11395
cactuskdogg's Avatar
Default zack vs. flat
curious as to what others have felt in the difference between the z.r. extra hole vs. the flat rear arms, in regards to handling. I've tried both, and favor the 3 hole (and so does your mom). it seems to have a much more tame rear end and overall is easier to drive.. however, the flat were a little faster,(high bite track) when i was able to run "perfect" laps.
thoughts...?
cactuskdogg is offline   Reply With Quote
Old 12-31-2014, 06:18 PM   #11396
gillbily23's Avatar
I haven't tried it with the ESC up top but I may try that after running this way for a bit. I prefer to have as much weight down low as possible and I am not sure I would be able to fit the body on it with my ESC on top of the shelf. I could relocate the fan and see if it would fit that way.
Old 12-31-2014, 07:48 PM   #11397
rpboggs1's Avatar
thoughts...?
I agree the flat arms felt more nimble but also prefer the glue-like feeling of the ZR setup.
Old 12-31-2014, 08:26 PM   #11398
mdwaeracer's Avatar
Two ?'s anyone using Futaba bls471 servo and the third hole. Is it inside or out side?
TEAM ASSOCIATED Rc10, rc10B6D ,FUTABA , TEAM ORION, KYOSHO RB6.
mdwaeracer is offline   Reply With Quote
Old 12-31-2014, 10:07 PM   #11399
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
thoughts...?
Flat arms keeps the car flatter through the corners. I like how the RB6 arms jump as well.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 01-01-2015, 05:04 PM   #11400
thoughts...?
My mom likes zack rodgers too
glenng is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22978 Today 07:22 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
