Kyosho Ultima RB6 & RB6.6 Car Thread
#1126
Sorry, big wave Dave... I can't figure out why you're having such a hard time with simple shock bushings.... The standard shock bushings that go into the lower eyelets, also go into the tops. They fit loose until you start to tighten down the metal lock nut onto the bolt... Eventually the bushing gets squished, expanding into the shock cap. Tighten enough to take out the play, but loose enough that the shock still moves freely. You don't use the plastic nuts, you use the metal ones supplied with the kit. I just dont understand the confusion.
#1128
I get what you're saying now and see the confusion - the same part, #11, is used in both the shock cap and the lower shock eyelet. But the manual refers to it as a 5.8mm and a 4.8mm bushing. The manual is incorrect, but the design is correct. The upper shock cap bushings should be loose and do not snap into the shock caps like they did on the RB5. This was the way it was intended.
I don't really know about the quantity of locknuts in the kit, I ended up using anodized aluminum locknuts on my build. FWIW, if you look at the pics of Tebo's car used as the advertisement, it shows the plastic nuts being used. If your kit is missing parts you feel should be in there, give Kyosho America a call, I'm sure they'll be happy to rectify the situation. Hope the rest of the build has gone well for you. Once you hit the track, you'll forget all about the goofy manual
#1129
I finished my roller build tonight, and I have to say, it is the best/smoothest build iv ever done. Went together like butter.
I did have two things to mention (issues).
A) I find it strange the kit doesn't come with the new vented slipper system. And...
B) my kit was missing the washers that go on either side of the slipper spring. I had to steal the ones off my WC. Anybody have a phone number to call for my missing parts?
#1130
949-454-8854
#1131
#1132
B) like jpcopeland one of mine had fallen off and was loose in the bag. The other was still on the tree. I think I prefer the WC slipper system.
#1133
I couldn't find the slipper pieces and just went with the WC.
I've used flanged nylocks on my rb5 with success so went with them on the rb6 tower. A plastic shim to save the shock cap in between if you want to.
#1134
Tech Legend
#1135
Tech Legend
#1137
Thank RodneyB for taking the time.
on Amain site it shows the the shared parts but not as detailed as the the sheets you found, as far as every part goes.
but the pics help when referencing what i read and see their also Infernosonly, at Stormer you better already know what your lookn' for.
ems
ems
#1138
Manual clearly says plastic nuts. Manual clearly says 5.8mm bushing for the top. Manual says nothing about squishing the bushing in English or Japanese. I could understand if it was missed in translation. Its not that big of a deal. There just wasn't a clear answer here on how to make it work. I will call on Monday and see what kyosho says.
#1139
Tech Legend
Here's my issue with "squishing and expanding" the plastic bushings. Yeah it works to take up the slack when assembling the car, but the bushings will expand on both the OD and the ID, so when it comes time to remove the shocks for setup/service/whatever, the bushings will be stuck to the threads of the mounting bolt and be a PIA to remove. Then you will have to drill it out to make it serviceable. Shock bushings are not an easy part to drill. Starting to border on too much secret handshake custom work to make it right, maybe the big K did make a mistake, which isn't a big deal they're human after all.
