    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-23-2014, 04:34 PM   #11356
Trader Rating: 48 (100%+)
Anyone have a pic of the prototype front tower on tebo's car?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 12-23-2014, 05:45 PM   #11357
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
This is a good shot.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 12-23-2014, 07:06 PM   #11358
yodace's Avatar
R/C Tech Charter Subscriber
What does moving the front plastic collar spacers, from the inside of the front spindle to the out side of the front spindle?
yodace is offline   Reply With Quote
Old 12-23-2014, 07:06 PM   #11359
Looks the same, it does look taller. I wonder what effect will this give
My Credit Card
Old 12-23-2014, 07:43 PM   #11360
Super Moderator
Kraig's Avatar
There is no scientific proof to this thought but let me toss this out there. With the taller shock tower you have to regain the ride height that was lost. So that would mean you screw the collars down on the body farther. When that happens it pushes the shock shaft down and that means the piston is now also farther down in the body too. Now with the piston farther down in the body I would think that this would create more pack in the front of the car.
At least, that is my non-engineering degree idea.
Old 12-23-2014, 08:24 PM   #11361
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
More uptravel and steering mid corner.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 12-23-2014, 08:35 PM   #11362
Doesn't look taller, it looks more meaty/ stout.
CaseyD is offline   Reply With Quote
Old 12-23-2014, 08:40 PM   #11363
Trader Rating: 14 (100%+)
Looks a lil taller. Maybe a few mm?
RBraswell is offline   Reply With Quote
Old 12-23-2014, 10:36 PM   #11364
Enigma R/C's Avatar
For anyone that is interested, I just made a shock building video which is posted to my website and YouTube channel. Here is the link: https://www.youtube.com/watch?v=kUq__wtmS7c
BTW....that wiring on the car a few pages back is to dope! I likey.
Talk to yall soon.
Looking to buy/sell USED rc gear? www.rcshed.com
Enigma R/C is offline   Reply With Quote
Old 12-24-2014, 06:49 AM   #11365
Testing has been fairly limited so far (not enough high bite tracks near me running meetings at the moment) but hopefully will pick up in the new year.
So far it is very quick, definitely more so than my previous forward motor car, and quicker than the RB6 on high bite stuff.
Bolts on to an otherwise stock RB6 chassis too
Please tell us more! .... Have you developed a 3 gear gearbox? Or a laydown 4 gear gearbox??
Headling is offline   Reply With Quote
Old 12-25-2014, 05:33 AM   #11366
hacker's Avatar
Trader Rating: 140 (100%+)
Default forward traction
where is it?
cannot be found.
still looking....
what's wrong with this car??
has anyone tried putting the battery to the furthest rear position to where the ESC is supposed to be, and put the ESC between battery and servo??
done so far;
lighter rear oil
lighter spring
unscrewed front eyelets for more droop.
These alone should of made a difference.....but not at all!
so I pulled the wheels off my rb6 and put onto the b4.2......and wow I have sooo much traction.
what's wrong with the rb6?
hacker is offline   Reply With Quote
Old 12-25-2014, 08:26 AM   #11367
ThePanda's Avatar
Trader Rating: 64 (100%+)
try the rear mm weight set
ThePanda is offline   Reply With Quote
Old 12-25-2014, 09:46 AM   #11368
hollywood3705's Avatar
Try more anti squat. Shorter rear camber link. What's your shock setup? How many roll center shims? Is your car bound up? It's not just lighter rear shocks and weight. 90% of the people I see don't have the right tires or they aren't loose they just have to much steering in the setup. 2wd cars should push. Get it to push then dial in the steering to suit your needs. Easiest way to set the car up. That's the way I've always done it.....and it's never failed
hollywood3705 is offline   Reply With Quote
Old 12-25-2014, 11:20 AM   #11369
Originally Posted by hacker View Post
where is it?
cannot be found.
still looking....
done so far;
lighter rear oil
lighter spring
Sometimes setup changes work in the opposite manner of what you intuitively think. If I had to guess based on the changes you've tried, you've got the rear end of the car rolling way too much, possibly picking the inside rear tire off the ground. This will make the car very hard to drive. Give heavier rear springs and shocks than what you originally started with a try, you might be surprised.
Derek_Wood is offline   Reply With Quote
Old 12-25-2014, 05:48 PM   #11370
On Kevin Kings set-up it says the steering rack is reversed, but he's using a Shelle Racing rack. I too have the Shelle rack, but I can't see how you can reverse it, due to the nut holders?
Any help is greatly appreciated.
Cheers
RichD is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22944 Today 12:18 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
