    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-22-2014, 07:22 AM   #11341
Just wait for wiring version 3.0
And yes my RX is in my servo.. going to 3D print a case for it.. the RX had been modified a bit and I make a tiny board to move stuff and stuffed it the servo..
iMarky is offline   Reply With Quote
Old 12-22-2014, 07:44 AM   #11342
Amazing install! Look forward to seeing V3!
RogerM, sounds good! Hope we see a new high grip gearbox for the RB6, it's an amazing platform for 90% of surfaces but hopefully with this gearbox change it can take the fight to the front motor 2wd's
Headling is offline   Reply With Quote
Old 12-22-2014, 09:11 AM   #11343
Trident69's Avatar
Originally Posted by phillypete View Post
The MIP axles are long enough to use any aftermarket wheels with the standard locking nuts.
Also Durango makes a low profile serrated nut that will work with non KYO wheels on stock axles. I have been using them for the past month without issue.
As far as my spur gear issue. It appears the failures are related to the motor slipping out of position. I have sanded the motor plate in the mounting area with a 120grit sand paper to give the mounting bolts more friction to hold onto. So far it seems to be helping.
Thank you so much.. At least now I can use all my old wheels that fitted the 22 back.. Cheers!!
"Power is nothing without Control"
Yokomo - Yz-2/Yz-2 DT/ Yz-4 / Bmax2MR/Bmax 4/3
Xray - XB4'16
Awesomatix - Evo 2
Trident69 is offline   Reply With Quote
Old 12-22-2014, 09:15 AM   #11344
Originally Posted by katoom007 View Post
Ok another question. is it better to run shorty batterys or saddle packs??? thanks
Shorty packs are the way to go.. saddle are heavy.. I run 3200mah protek and I put weights where I want and need..
Old 12-22-2014, 10:31 AM   #11345
THanks imarky
katoom007 is offline   Reply With Quote
Old 12-22-2014, 11:35 AM   #11346
It depends. I went from shorty to saddle packs in the full rear position to gain a bit more forward bite. The saddles definitely locked in the rear but it feels like I lost the nimbleness from the shorty packs. Saddles makes it easier to drive consistently but have lost some of the responsiveness.
Vincent_Diesel is offline   Reply With Quote
Old 12-22-2014, 01:17 PM   #11347
seems to be a huge weight difference. almost 70 grams.
Old 12-22-2014, 03:52 PM   #11348
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Saddle will also exaggerate any condition you are feeling.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 12-23-2014, 04:40 AM   #11349
Testing has been fairly limited so far (not enough high bite tracks near me running meetings at the moment) but hopefully will pick up in the new year.
So far it is very quick, definitely more so than my previous forward motor car, and quicker than the RB6 on high bite stuff.
Bolts on to an otherwise stock RB6 chassis too
Kyosho UK RB6.6 & ZX6.6
RogerM is offline   Reply With Quote
Old 12-23-2014, 05:13 AM   #11350
[IMG][/IMG]
nitroargi is offline   Reply With Quote
Old 12-23-2014, 05:26 AM   #11351
Potoczak's Avatar
Trader Rating: 111 (100%+)
Are there any companies that do cut gears for the rb6???
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 12-23-2014, 05:54 AM   #11352
I'm pretty sure CB does.
http://shop.cbscustomrc.com/
https://www.facebook.com/CBsCustomRC
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 12-23-2014, 05:59 AM   #11353
Potoczak's Avatar
Originally Posted by Jason Snyder View Post
Thanks Jason.
Pete Potoczak
Old 12-23-2014, 02:23 PM   #11354
beedee's Avatar
Which Losi spring is equivalent to the Kyosho Pink? My buggy I bought came with Losi Silvers up front. I will be running indoors on high bite clay.
ASSOCIATED ★
beedee is offline   Reply With Quote
Old 12-23-2014, 04:15 PM   #11355
Potoczak's Avatar
Spring chart with the rates
http://www.rctech.net/forum/attachme...comparison.pdf
Pete Potoczak
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
