    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-21-2014, 06:57 PM   #11326
Trident69's Avatar
Good day gents, just throwing another discussion onto this thread, as the 1/10 offroad buggy worlds happening in Oct 2015, will you guys think?
1. A new buggy to release from kyosho since yokomo has justt released one for high traction carpet/astro?
2. will the exisiting RB6 be somewhat re-engineered to meet the Astroturf at Yatabe?
Gents...just a discussion..pls dun take it out of context as Astro vs Dirt as we have another thread for that..
cheers!!
"Power is nothing without Control"
Yokomo - Yz-2/Yz-2 DT/ Yz-4 / Bmax2MR/Bmax 4/3
Xray - XB4'16
Awesomatix - Evo 2
Trident69 is offline   Reply With Quote
Old 12-21-2014, 07:26 PM   #11327
Brian C.'s Avatar
cheers!!
I don't think a new buggy but maybe new option parts at the most, Kyosho doesn't change stuff to often... And when the do its small things...
Brian C. is offline   Reply With Quote
Old 12-21-2014, 07:53 PM   #11328
Trident69's Avatar
Agree with you...but the RB6 is already a very versatile buggy on its own, have been running mine for both Astro and loose traction on MM platform and she handles it with flair.
wonder what upgrade parts will be made for the RB6 for the upcoming worlds or Kyosho will just leave without and upgraded parts for her..
On a side note, World Champion TC Narto has left Yokomo..wonder will he join kyosho?
Xray - XB4'16
Awesomatix - Evo 2
Old 12-21-2014, 08:58 PM   #11329
Originally Posted by phillypete View Post
My LHS is having great difficulty keeping Kyosho spur gears on the shelf. I know that between my RB6 and my RT6 I've been through 7, and the other RB6 driver that races with us has DNF'd at least a couple of times.
I just replaced my gearbox, bearings, top shaft and pinion. I made sure everything was super free in the gearbox and that my slipper was set so that it barely raised the front wheels.
Right now I'm debating whether it is spur gear #8 or b5m #1
Are you guys setting your slipper properly? Only time I ever have issues with spur gears is when the motor has come slightly loose and thats on any of my cars, regardless of pitch or type/make.
Originally Posted by katoom007 View Post
ok. went to the track today. had mine set up with sadle packs and Rm. had bar code tires on and couldnt get traction. conditions were not bad. not too wet. my sct had beams on it and never had a traction problem. is everyone running the mm setup ? is sadle packs not as good as teh shorty ?? thanks for your help in advance.
When you say traction, do you mean forward? I found plenty of traction in RM. Actually lacked some steering ...
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 12-21-2014, 10:27 PM   #11330
iMarky is offline   Reply With Quote
Old 12-21-2014, 10:45 PM   #11331
Trident69's Avatar
Gents, another quick question,
MIP C-CVD Kit (RB5/RB6)
[MIP12141]
When installing this on the Rb6, can we use TLR wheels?
i am on the Avid ones now but somehow or rather, i need a replacement set and avid a/o amains does not have the avid in stocks, the Avid CVD kit i am able to run all my old TLR wheels instead of the kyosho rear wheels.
Please advice if the MIP can do the same.
CHeers!
Xray - XB4'16
Awesomatix - Evo 2
Old 12-22-2014, 01:55 AM   #11332
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Originally Posted by iMarky View Post
Reminds me of the wiring we used to do back in the 1/12th scale days, getting the cleanest wiring was almost a competition in itself. Did you direct solder your rx connectors?
Dont think the wireless motor fad is gonna catch on though!
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 12-22-2014, 02:04 AM   #11333
It would be nice to see a 3 year transmission or a lay down transmission conversion (similar to YZ-2) for the car for the astro tracks
I wonder if anyone will get clever and 3d print a proto gearbox up?
In the UK quite a few of the kyosho drivers use the Rude Bits DB2 conversion which is a RB6 front end and a ZX5 rear end for the astro tracks
Headling is offline   Reply With Quote
Old 12-22-2014, 04:11 AM   #11334
The MIP axles are long enough to use any aftermarket wheels with the standard locking nuts.
Also Durango makes a low profile serrated nut that will work with non KYO wheels on stock axles. I have been using them for the past month without issue.
As far as my spur gear issue. It appears the failures are related to the motor slipping out of position. I have sanded the motor plate in the mounting area with a 120grit sand paper to give the mounting bolts more friction to hold onto. So far it seems to be helping.
www.beachrc.com
phillypete is offline   Reply With Quote
Old 12-22-2014, 04:44 AM   #11335
This "might" already be in progress ... maybe
Kyosho UK RB6.6 & ZX6.6
RogerM is offline   Reply With Quote
Old 12-22-2014, 05:58 AM   #11336
I am spinning out in the corners. seems the rear end just spins out and the front stays planted.
katoom007 is offline   Reply With Quote
Old 12-22-2014, 06:18 AM   #11337
Gayosaka's Avatar
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Old 12-22-2014, 06:21 AM   #11338
Gayosaka's Avatar
So the receiver is actually inside the servo box, and the cable on the right is from the ESC. I also suppose that the motor wires are soldered under the motor tabs, but I can"t see them. Crazy stuff!
Isn't Sanwa working on a ESC+Rx combo? Not really useful but so cool
Old 12-22-2014, 06:44 AM   #11339
I think i see a motor wire peeking under there... if that's the case then sweet baby jesus you did a good job!
Shawner85 is offline   Reply With Quote
Old 12-22-2014, 07:02 AM   #11340
Ok another question. is it better to run shorty batterys or saddle packs??? thanks
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
