    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-04-2014, 10:26 AM   #11191
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
Any rumors on a 3gear transmisson for MM like The B5M?
TEAM ASSOCIATED Rc10, rc10B6D ,FUTABA , TEAM ORION, KYOSHO RB6.
mdwaeracer is offline   Reply With Quote
Old 12-05-2014, 04:52 AM   #11192
Fellow RB6er's,
I have a tremendous problem with my usually well behaved RB6. As of late I cannot finish a heat without something in my transmition failing. It is mostly spur gears and idlers. I did also have an axle come apart as well, but that may have been unrelated.
This started when I made the move from a very small indoor track with very small jumps to a decent sized indoor track with some nice jumps.
I've replaced everything in the transmition system several times, new pinions new spur gear, new slipper, new top shaft, new idlers, new bearings, switched between ball diff and gear diff as well.
I am in desperate need of help. My kyosho has been very good to me in the past, but I my next move is to try a different brand.
Thanks!
www.beachrc.com
phillypete is offline   Reply With Quote
Old 12-05-2014, 05:24 AM   #11193
Moderator
Posvar's Avatar
Trader Rating: 461 (100%+)
Never had those issues before...what motor are you running? Some guys who stay on the throttle hard upon landing can have those issues. Mid motor or rear? Motor plate loose?
I am jealous that you race at BeachRc!
Awesome track. It looks smooth enough and you should not be having those issues. Sotck spur or avid/schelle?
Looking forward to coming down and racing with you. Did you run last night?
Matt
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 12-05-2014, 06:20 AM   #11194
rpboggs1's Avatar
Originally Posted by phillypete View Post
Fellow RB6er's,
Thanks!
Make sure you didn't over tighten the transmission screws... especially the short screw that doesn't attach to the motor plate and the 2 behind the shock tower that attach to the rear bulkhead (in mm).
rpboggs1 is offline   Reply With Quote
Old 12-05-2014, 06:26 AM   #11195
cactuskdogg's Avatar
what elec set-ups are best for mm, high bite? run everything back? i'll be running shorty packs.
thank you!
cactuskdogg is offline   Reply With Quote
Old 12-05-2014, 06:29 AM   #11196
Originally Posted by Teufel Racing View Post
It's mostly for the stock RB6 rear arms, but I suppose you could do the mod to the "flat" arms too if you really wanted to.
um521 and um521-1 are the two flat arms that most have used, with most opting for the 521-1.
Thank you for the feedback!!
Old 12-05-2014, 06:45 AM   #11197
Trader Rating: 81 (100%+)
Fellow RB6er's,
Thanks!
Also make sure you are using the correct idler gear and the bearings are free and smooth. A bad bearing can destroy your tranny of you aren't careful
dpcardoza is offline   Reply With Quote
Old 12-05-2014, 07:15 AM   #11198
cnelson3's Avatar
Trader Rating: 65 (100%+)
Fellow RB6er's,
Thanks!
Is it possible the slipper is too tight? Are you running an aluminum idler?
cnelson3 is offline   Reply With Quote
Old 12-05-2014, 07:33 AM   #11199
Matt
I'm running a 7.5, but I turn it down depending on the grip.
I'm an 1/8th scale nitro buggy guy at heart, so I might be guilty of being hard on the throttle when I land. Is it that I can't be on the throttle at all at landing or just not full wood. I usually like to jump nose down and then use the throttle to push the rear tires down on landing. Like I said at our old track we didn't have jumps that were big enough to even worry about flying the buggy, so I'm new to this.
I'm running the stock slipper, but I'm thinking of upgrading whats the best avid or schelle?
The new facility is so much fun. The track is so much fun to drive. That's why I hate having these issues. I love the way it all flows together.
We did run our usual club race last night. Turn out was decent, but we didn't expect too many folks to make it out because of the race this weekend at the badlands. We did have a bunch of racers stop by to check it out. Adam Drake stopped in for a tour and hung out in the pits for a little while. He even posted up some photos on his FB page!
There should be an announcement going up very soon about the weekend of March 21st and 22nd... so you might want to keep that weekend open... wink wink!
www.beachrc.com
Old 12-05-2014, 07:46 AM   #11200
I always check that the transmission is free before install it too the chassis, but I never thought about those two screws that go into the shock tower. I usually tighten them down all the way, so maybe that is causing an issue.
Thanks!
www.beachrc.com
Old 12-05-2014, 07:48 AM   #11201
I have run with and without the aluminum idler, just to make sure that wasn't propigating the issue.
I am going to set my slipper slightly looser to try to help protect everything.
www.beachrc.com
Old 12-05-2014, 08:36 AM   #11202
Try a new gearbox case. There cheap and you have changed everything but... Might have a hair line crack in it.
I've run this car since it's release and only done one idler gear but that was on carpet.
Tom87 is offline   Reply With Quote
Old 12-05-2014, 06:40 PM   #11203
hairymuffin's Avatar
Trader Rating: 93 (100%+)
is that little gold spacer on the top shaft? asking because you said you stripped spurs too? tranny screws like others said and also check that the slipper not too tight..i had idler probles but my top shaft was worn..the stock parts work fine..also when you strip a gear,make sure you clean all the little particles out..one little piece can cause the gears to not mesh
hairymuffin is offline   Reply With Quote
Old 12-06-2014, 08:42 AM   #11204
Hi
What are the benefits of a lowprofile servo, because I just got me a RB6 and are looking for a servo for it?
I have been told to search for a servo, faster than 0.10 sec. and around 15 kg strong and stay away from lowprofile servos cause they strip gear the hole time.
Jan
racerkorer is offline   Reply With Quote
Old 12-06-2014, 12:07 PM   #11205
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
You're welcome
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
