    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 11-30-2014, 07:14 AM   #11176
How does this buggy compare to others ?? And thanks for your help
katoom007 is offline   Reply With Quote
Old 11-30-2014, 07:34 PM   #11177
LIVipers's Avatar
Trader Rating: 38 (100%+)
In terms of what? Steering? Traction? Parts cost/wear? Resale? Its a broad question so a bit more information will help us better give you the answers you're looking for
LIVipers is offline   Reply With Quote
Old 11-30-2014, 09:16 PM   #11178
Trader Rating: 14 (100%+)
In terms of quality it is top notch. Against other buggies it is a world champion platform and race proven vehicle. worth getting one imo
RBraswell is offline   Reply With Quote
Old 11-30-2014, 09:59 PM   #11179
The car is unbelievable, the only car that really works both MM and RM. However it is ridiculously expensive to own, 1.5"x 1.5" front bumper is 8 bucks and you go through those a lot, rear axles 15 bucks each, those are just a couple of examples. So if you're not worried a out the price of up keep then you'll love it.
CaseyD is offline   Reply With Quote
Old 12-01-2014, 10:35 AM   #11180
hairymuffin's Avatar
Trader Rating: 93 (100%+)
the quality is the best out there hands down,in terms of wear and breakage.. however,it needs a few things to help it bullet proof.. rear hinge pin holders,rear hubs,avid axles and the steering rack is debatable..i have the stock rack of one of my cars and it is still holding up fine.. the b5 is hard to beat because of price and handling,not sure what the b5 owners need to upgrade? i say get the rb6 ad upgrade as you go,run it stock 1st..
hairymuffin is offline   Reply With Quote
Old 12-02-2014, 07:55 PM   #11181
cactuskdogg's Avatar
Default rear arms
sorry if this has already been asked, i couldn't find the answer..
is the drilled hole on the zack rogers set up for the stock arms, or the flat arms? if it's the flat, does anyone have the part number please?
(this could be a dumb question as my rb6 hasn't shown up yet)
thank you!
cactuskdogg is offline   Reply With Quote
Old 12-02-2014, 08:12 PM   #11182
gelshocker's Avatar
Those with the JC RB6 motor plate (honeycomb), can you please post the weight? Is it lighter than the Kyosho finned plate? Thanks,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 12-02-2014, 08:18 PM   #11183
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
thank you!
It's mostly for the stock RB6 rear arms, but I suppose you could do the mod to the "flat" arms too if you really wanted to.
um521 and um521-1 are the two flat arms that most have used, with most opting for the 521-1.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 12-02-2014, 11:47 PM   #11184
gillbily23's Avatar
I have been wanting to do the mid motor conversion on my RTR RB6 which comes in the rear motor set up so I just want to verify that all I need is the mid motor rear tower. I plan on getting the LW chassis this week so I figure this will be the perfect opportunity to do the mid motor setup. I wish that I had just bought the kit at this point seeing I have dropped a load of money on upgrades but I wasn't real sure that I was going to be real thrilled with the car. So far I am loving it and am just trying to dial it in for my style.
gillbily23 is offline   Reply With Quote
Old 12-03-2014, 01:59 AM   #11185
You'll need,
Rear shock tower for MM
MM tranny case and waterfall brace (they come as a set)
Idler gear, shaft, and bearings
Rear MM bulkhead for the camber link
RR MM arm hanger
rear arm mount/bulkhead screws (3x20 if I remember right)
That should be it to do the conversion
J.Mikoliczyk
RB6 - MBX7R Eco
Old 12-03-2014, 02:13 AM   #11186
FallenAllDay's Avatar
Hey guys I've bought the V2 hubs 0* all Id like to know is which hole is the stock location. And/or which location is the most common people are running in mm. Thanks
TLR 8IGHT 4.0, OS Speed, Sanwa M12s/Ko servos
KYOSHO RB6, Orion, Sanwa M12s/Ko servo
Powered by my wallet.
FallenAllDay is offline   Reply With Quote
Old 12-03-2014, 12:10 PM   #11187
Rasheed's Avatar
Default CVD rebuild
I have been using the Avid axle and the kyosho dogbones for a while now. i have been replacing the dogbones when they wear out, but want to replace the pin and barrel that go between the axle and dogbone. I can't really find them for sale without buying kyosho axle, which I don't really want.
Will the MIP coupling fit?
http://www.amain.com/mip-c-cvd-coupl...screws/p192770
Is there any way to buy another coupling that will fit the avid axle?
Derek "The Speed" Rasheed - Sponsored by Kaiser Permanente. Thrive!
davesrctracks.net - a great offroad 1/10th scale track.
Rasheed is offline   Reply With Quote
Old 12-03-2014, 01:01 PM   #11188
gillbily23's Avatar
Originally Posted by Teufel Racing View Post
You'll need,
RR MM arm hanger
Thanks for the list! I am going to try and grab the parts today if the LHS has everything. Hopefully I will be running MM this weekend.
Old 12-03-2014, 01:53 PM   #11189
Forgot to add to the list,
Rear MM wing mounts as those are different than the RM ones
Rear MM bumper
If you buy the rear arm hangers and bulkhead, you'll get two shims that go between the rear arm mount and bulkhead, one is .5mm and the other is 1mm, those are super important to keep track of, as they take up the space when you change antisquat settings so that the tranny is sitting like it needs to be. You'll also need the rear arm shims that go between the rear arm hanger and chassis from you RM car or was in the box for your car. .5mm and 1mm just like the ones for between the arm hanger and bulkhead.
J.Mikoliczyk
RB6 - MBX7R Eco
Old 12-03-2014, 02:48 PM   #11190
2nd outer most is the stock hole, I run this hole 80% of the time and the outer most the other 20% in mid motor.
The longer link makes alittle more rear side bite and roll mostly in the middle of the corner, but you have less camber gain as the suspension compressers. I would test them both for yourself.
Tom87 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
