    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 11-22-2014, 09:40 AM   #11146
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Jgins13 View Post
Hi all,
I'm about to buy this kit. Almost exclusively race on a large indoor clay track. New to 2wD buggy class, been racing 4x4SC (Tekin RX8.2, HW Xerun motor, AKA Typo Tires). I'm planning to run the 2wd mod buggy class, and would like your feedback on my proposed electronics and tires. So here's what I'm looking at so far:
Tekin RSX gen 2 (already use Tekin in my SC, and have all the hotwire/programming accessories already)
Not a bad choice for an ESC, and it's something, Mfg. wise you already know and use so it's a logical choice
Tekin 6.5 Turn motor (should I be looking at a 7.5 instead per the RB6 manual?)
Unless you are on a super high bite sugar track, a 6.5 will most likely be way too much motor. A 7.5 should be about the norm. Being new, I might even look at a 8.5, as you could always add a little boost if needed.
Savox 1257TG
Good servo, it's what I have in mine currently. As an optional choice, you could always go with the 1251 short servo. It'll give you more room to play with for esc and rx placement
Aka EVO Typos (I assume the downloadable manual incorrectly lists Short Course as the suggested tires to buy, and that I want 1/10 buggy tires).
If those are what works there, run them. Might have to ask at the track to be sure, but they should work
Planning to run the RM config. What's the best choice for 2S battery (straight, shorty, saddle)? Mains at my track are either 5 or 7 minutes.
In Rm, you can get away with the full size packs, but I'd probably look at the shorty pack, if you ever decide to go MM, you'll be happy you have that pack. You can also run the square/saddle packs in either and some do prefer the extra weight. It's a preference thing on that. The shorty packs should easily run way more that the mains times you're looking at, so that shouldn't be an issue.
What size pinions should I get as a starting point assuming mod racing with a 6.5 (or 7.5 if you think I should be getting that one instea)?
On a 7.5 I was running 24/76, running 21-22/76 would be about right for a 7.5. 24/76 should be pretty close for a 8.5 if you decide to go that way.
Thanks for all the help.
Hope that helps you out.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 11-22-2014, 10:12 AM   #11147
M03Racer's Avatar
Trader Rating: 32 (100%+)
I will be running an 8.5T motor, is a 45A ESC good enough or should I get something with more Amps. I ran 45A in my on road cars so I figured it should be enough in a 2wd buggy.
M03Racer is offline   Reply With Quote
Old 11-24-2014, 12:38 PM   #11148
tonyv2382's Avatar
Trader Rating: 64 (100%+)
Send a message via Yahoo to tonyv2382
Anyone try the LW chassis on carpet?
tonyv2382 is offline   Reply With Quote
Old 11-24-2014, 04:40 PM   #11149
Trader Rating: 14 (100%+)
for stock racing would you guys recommend going with ceramic bearings in the transmission or using the stock ones? if I go ceramic what manufacturers do you recommend?
RBraswell is offline   Reply With Quote
Old 11-24-2014, 04:44 PM   #11150
Acer racing makes a nice ceramic set for 67 bucks on ebay
glenng is offline   Reply With Quote
Old 11-24-2014, 05:24 PM   #11151
tobamiester's Avatar
Trader Rating: 274 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Or direct w/ Free shipping
tobamiester is offline   Reply With Quote
Old 11-24-2014, 09:05 PM   #11152
True. And dont forget 2 5x13x4 ceramic bearings if u run the kyosho rear hubs
Old 11-24-2014, 10:01 PM   #11153
Trader Rating: 81 (100%+)
Anybody out there running the gear diff? If so what weight oil are you using. I'm running on high bite indoor clay
dpcardoza is offline   Reply With Quote
Old 11-25-2014, 07:19 AM   #11154
I just picked up a rb6, and looked over the last few pages of this thread which have me a general idea of some good option parts to pick up, but would anyone like to weigh in on some "must have" option parts for a rb6 that's going to run in stock class?
I already ordered kyosho aluminum rear hubs, and the schelle steering rack.
J. Lowe
//RB6 // SC6 // RT6 // mr-03s Mini-Z //
epic1Designs
WhiTeyFU is offline   Reply With Quote
Old 11-25-2014, 07:40 AM   #11155
Aluminum hangars for rear and mid
Pucks
Old 11-25-2014, 08:11 AM   #11156
Gayosaka's Avatar
Be sure to check the first post on the first page
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Old 11-25-2014, 06:05 PM   #11157
For anybody running a low profile servo. How far did you have to shim the servo forward so that it doesn't hit the bulkhead. The tolerances are so tight I'm having a hell of a time getting it right
Old 11-25-2014, 07:32 PM   #11158
i used both shims on an rsx one10, stock kyosho horns clears perfect as does the alloy losi 22 horn. you can dremel the top plates underside for clearance if need be
Old 11-27-2014, 06:37 PM   #11159
Default Just sayin'
I have a SC6 and a RB6. I've just added a D413 after reading some very positive reviews. I seriously considered the ZX6 -- a very tough decision.
Although the Hot Bodies has some really innovative features and durability is proven, which sold me on it -- I must say that my Kyosho RCs are among the best built. Just something about the tolerances and the quality of the materials that really impress me. For example I am always careful about making sure my screws aren't overtightened. I managed to strip the plastic in the rear arm of my D413. Cripes. Don't get me wrong the D413 isn't exactly low grade because as mentioned it's pretty innovative and some of the materials are of higher quality... it's just after being spoiled by Kyosho the bar is pretty high. After spending a few days putting this new ride together I picked up my K cars and instantly noticed a difference, in favor of the Kyosho.
I hit the track for the first time tomorrow with the D413 hoping for a good first impression but I am thinking in the back of my mind what if I had purchased the ZX6.
Anyways I will be running my RB6 with a new square pack tomorrow. I have been struggling with rear traction (most 2WD buggies do) at my local track recently and thinking the only answer right now is the added weight. I've tried multiple setups with a shorty and nothing has worked. Stay tuned.
Vincent_Diesel is offline   Reply With Quote
Old 11-28-2014, 08:59 AM   #11160
cnelson3's Avatar
Trader Rating: 65 (100%+)
I ran saddles all the way back and rear traction went up considerably. For my local track it was too much but for the looser or dusty tracks, it was perfect.
cnelson3 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
