    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 11-20-2014, 06:00 AM   #11131
tobamiester's Avatar
Trader Rating: 275 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Yeah I was thinking on the topic of inserts/pills. I have a bunch of B5 Rear rims.
Offset seems quite different than the wheels that come with RB6.
Haven't seen a conclusive answer on what people do here to run AE Rear rims (seen the question asked a few times).
Do folks just run the 'OUT' settings (i.e widening the track-width) to compensate for the offset differences with AE rims ?
tobamiester is offline   Reply With Quote
Old 11-20-2014, 07:57 AM   #11132
The offset are the same on RB5 and RB6.
hloland is offline   Reply With Quote
Old 11-20-2014, 08:29 AM   #11133
I'm talking about AE B5 rims ..
Old 11-20-2014, 10:24 AM   #11134
You can run them fine a hair narrower but not enough to make it drive much different.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 11-20-2014, 01:24 PM   #11135
MODELTECH22's Avatar
Trader Rating: 20 (100%+)
Originally Posted by MODELTECH22 View Post
Hey guys just picked up a used RB6, looks to be completly box stock except frt aluminium bulk head (hinge pin holder) what do i need or change? I run on indoor medium bite clay track.
anything????
22 3.0 Hobbywing
22 2.0 W/exotek chassis TEKIN
22T 2.0 Lrp Flow
SCT 22 2.0 Hobbywing
MODELTECH22 is offline   Reply With Quote
Old 11-20-2014, 03:02 PM   #11136
ThePanda's Avatar
Trader Rating: 64 (100%+)
anything????
You don't need to change anything, however, there are always things to be done to give the car a little more pazazz.
I would pickup an extra steering assembly, and plastic hangars, or just get both in aluminum if you have the money to. Those are typically the things that break first.
ThePanda is offline   Reply With Quote
Old 11-20-2014, 03:18 PM   #11137
E73
E73's Avatar
anything????
Agree with above post.
1) Aluminum steering assembly. Kyosho is good or Schelle.
2) Kyosho adjustable rear aluminum hangers UMW 705 and either 706 (rear motor) or 707 (mid motor)
3x1.4 front pistons and 2x1.6 rear pistons work very well as well as extra sets of springs f/r if you have the $$$.
E73 is offline   Reply With Quote
Old 11-20-2014, 07:45 PM   #11138
Trader Rating: 81 (100%+)
Originally Posted by Gayosaka View Post
If you use the same insert front to rear, you don't change toe-in, it stays at 3 per side. You only change overall width and roll center (wider means less roll).
C in/C in is 3 degrees, as D in/D in or B out/B out.
D in front/C in rear is 3.5 degrees
C in front/D in rear is 2.5 degrees
Etc.
This post just blew my mind. I'm so confused now.
dpcardoza is offline   Reply With Quote
Old 11-20-2014, 09:21 PM   #11139
Just make sure and not lose the chart that comes with the hinge pin holders. There's all kinds of combos, from 0 to 6 degrees of toe and you can mess with the track width a little at the same time.
CaseyD is offline   Reply With Quote
Old 11-21-2014, 10:51 AM   #11140
I have the one that goes on front of the tranny and am running d in x2 but I guess I didn't think about the fact that d in is relative to whatever is behind the tranny case. And for that I have no idea what I've got there. Didn't buy the adjustable one for the rear.
Old 11-21-2014, 10:56 AM   #11141
thanks this is what i was looking for. The pistons do the associated 3x1.4 and 2x1.6 work?
22 3.0 Hobbywing
22T 2.0 Lrp Flow
Old 11-21-2014, 11:44 AM   #11142
If you look on the right side of that chart it has pictures of the RF RF2, RR and RR2 and gives the toe in combos. That might be able to get an idea of what you are running?
Old 11-21-2014, 11:47 AM   #11143
As I just finished up my build, here is a pic of the Chart
Old 11-21-2014, 01:28 PM   #11144
Side note, and i think it was mentioned before....Fitted a JC Silencer (for B5M) to my RB6 with minor mods. Fits pretty good. Saves painting yet another body
Old 11-22-2014, 08:52 AM   #11145
Default Getting a RB6 - sanity check on required items
Hi all,
I'm about to buy this kit. Almost exclusively race on a large indoor clay track. New to 2wD buggy class, been racing 4x4SC (Tekin RX8.2, HW Xerun motor, AKA Typo Tires). I'm planning to run the 2wd mod buggy class, and would like your feedback on my proposed electronics and tires. So here's what I'm looking at so far:
Tekin RSX gen 2 (already use Tekin in my SC, and have all the hotwire/programming accessories already)
Tekin 6.5 Turn motor (should I be looking at a 7.5 instead per the RB6 manual?)
Savox 1257TG
Aka EVO Typos (I assume the downloadable manual incorrectly lists Short Course as the suggested tires to buy, and that I want 1/10 buggy tires).
Planning to run the RM config. What's the best choice for 2S battery (straight, shorty, saddle)? Mains at my track are either 5 or 7 minutes.
What size pinions should I get as a starting point assuming mod racing with a 6.5 (or 7.5 if you think I should be getting that one instea)?
Thanks for all the help.
Jgins13 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22937 Today 06:57 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
